Hi, I’m following the instructions here: https://github.com/qubenix/qubes-whonix-bitcoin/blob/master/1_joinmarket.md
After I run “qvm-connect-tcp 8332:bitcoind:8332” in the joinmarket vm
“telnet localhost 8332” works from bitcoind vm, but does not work from the joinmarket vm, where it says “Connection closed by foreign host.”
I tried adding this to my bitcoin config:
rpcbind=127.0.0.1
rpcallowip=0.0.0.0/0
rpcbind=bitcoind
and then running “sudo systemctl restart bitcoind”
after reading:
https://bitcoin.stackexchange.com/questions/87943/unable-to-bind-any-endpoint-for-rpc-server
but it didn’t help
Is there anywhere I can find a working example of using qvm-connect-tcp to connect to bitcoin core RPC server from another vm?
I tried in a fresh vm:
user@my-new-qube:~$ qvm-connect-tcp 8332:bitcoind:8332
Binding TCP ‘bitcoind:8332’ to ‘localhost:8332’…
user@my-new-qube:~$ telnet localhost 8332
Trying ::1…
Trying 127.0.0.1…
Connected to localhost.
Escape character is ‘^]’.
Request refused
2021/06/09 17:50:53 socat[992] E waitpid(): child 993 exited with status 126
How would bitcoin core even know that I’m connecting from a different VM, if it should also be as if from localhost?
– You received this message because you are subscribed to the Google Groups “qubes-users” group. To unsubscribe from this group and stop receiving emails from it, send an email to . To view this discussion on the web visit .
Wait, apparently I can’t even “netcat -l 5000” and “telnet localhost 5000” in the same debian vm? Even if I clear the iptables and set the default policies to accept? Clearly I don’t understand Qubes networking.
