Hello, kind folks!
I am done making changes and testing the new releases of ansible-qubes (which includes bombshell-client to run shell commands across VMs) and Qubes network server. The master branches of both projects are now compatible with Qubes 4.1 and work correctly as expected.
- Lets you automate actions between VMs using the qubes.VMShell service.
- Lets you expose AppVMs and StandaloneVMs to other equipment on your LAN.
You should be able to build packages for both projects and deploy these packages to your Qubes 4.1 setup. In the future I’ll explore building and publishing packages so that people can deploy directly from a repository. If there is interest, we could continue shepherding these projects directly into the Qubes OS organizational umbrella.
Enjoy!
– You received this message because you are subscribed to the Google Groups “qubes-users” group. To unsubscribe from this group and stop receiving emails from it, send an email to . To view this discussion on the web visit .
