I appreciate your response. This documentation is in reference to dom0. The
VM that produces this error log is sys-whonix, given that it is the current updateVM
Within sys-whonix, whenever the text is highlighted and copied using ctrl-c, the
terminal window closes for some reason.
The other interesting behaviour is that when right clicking within the terminal window,
it highlights the text, and doesn’t give an options window as it normally would.
I tried this and it registered the keystrokes and then returned the ASCII symbols on the
command line. It didn’t copy the text.
I don’t know where are you trying to copy the text from.
What’s the title of the window from which you’re trying to copy the text?
sys-whonix(sh)
When the
sudo qubes-dist-upgrade -s -f sys-whonix -k
command is launched from dom0, it opens a shell inside sys-whonix
and it returns an error log.
Ok, it seems to be a disposable qube window.
When you select the text in this window and press Ctrl+Insert → Ctrl+Shift+C then in another qube window press Ctrl+Shift+V → Ctrl+V (or Shift+Insert if it’s a terminal window) then is the selected text copied successfully?
UPD:
My bad, it seems to be xterm window.
Then press Ctrl+Middle mouse click → Select to clipboard, then select the text and press Ctrl+Shift+C to copy the text to global clipboard.
Ok! That worked my friend, so here is the error log:
Error:
Problem 1: cannot install the best update candidate for package kernel-devel-1000:6.1.57-1.qubes.fc32.x86_64
- problem with installed package kernel-devel-1000:6.1.57-1.qubes.fc32.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by kernel-devel-1000:6.6.31-1.qubes.fc37.x86_64
- nothing provides libcrypto.so.3()(64bit) needed by kernel-devel-1000:6.6.31-1.qubes.fc37.x86_64
- nothing provides libcrypto.so.3(OPENSSL_3.0.0)(64bit) needed by kernel-devel-1000:6.6.31-1.qubes.fc37.x86_64
Problem 2: problem with installed package qubes-core-dom0-4.1.36-1.fc32.noarch
- cannot install the best update candidate for package qubes-core-dom0-4.1.36-1.fc32.noarch
- qubes-core-dom0-4.1.36-1.fc32.noarch does not belong to a distupgrade repository
- nothing provides util-linux-core needed by qubes-core-dom0-4.2.13-1.fc37.noarch
- nothing provides util-linux-core needed by qubes-core-dom0-4.2.16-1.fc37.noarch
- nothing provides util-linux-core needed by qubes-core-dom0-4.2.17-1.fc37.noarch
- nothing provides util-linux-core needed by qubes-core-dom0-4.2.18-1.fc37.noarch
- nothing provides util-linux-core needed by qubes-core-dom0-4.2.19-1.fc37.noarch
- nothing provides util-linux-core needed by qubes-core-dom0-4.2.20-1.fc37.noarch
- nothing provides util-linux-core needed by qubes-core-dom0-4.2.21-1.fc37.noarch
- nothing provides util-linux-core needed by qubes-core-dom0-4.2.28-1.fc37.noarch
- nothing provides util-linux-core needed by qubes-core-dom0-4.2.10-1.fc37.noarch
- nothing provides util-linux-core needed by qubes-core-dom0-4.2.11-1.fc37.noarch
- nothing provides util-linux-core needed by qubes-core-dom0-4.2.12-1.fc37.noarch
- nothing provides util-linux-core needed by qubes-core-dom0-4.2.14-1.fc37.noarch
- nothing provides util-linux-core needed by qubes-core-dom0-4.2.15-1.fc37.noarch
Problem 3: cannot install the best update candidate for package kernel-qubes-vm-1000:6.1.57-1.qubes.fc32.x86_64
- package kernel-qubes-vm-1000:6.6.31-1.qubes.fc37.x86_64 requires kernel-devel = 6.6.31-1.qubes.fc37.x86_64, but none of the providers can be installed
- problem with installed package kernel-qubes-vm-1000:6.1.57-1.qubes.fc32.x86_64
Problem 4: problem with installed package anaconda-core-1000:32.24.5-8.fc32.x86_64
- cannot install the best update candidate for package anaconda-core-1000:32.24.5-8.fc32.x86_64
- anaconda-core-1000:32.24.5-8.fc32.x86_64 does not belong to a distupgrade repository
- nothing provides python(abi) = 3.11 needed by anaconda-core-1000:37.12.6-4.fc37.x86_64
- nothing provides python3-dasbus >= 1.3 needed by anaconda-core-1000:37.12.6-4.fc37.x86_64
- nothing provides python3-langtable >= 0.0.54 needed by anaconda-core-1000:37.12.6-4.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by anaconda-core-1000:37.12.6-4.fc37.x86_64
- nothing provides systemd-resolved needed by anaconda-core-1000:37.12.6-4.fc37.x86_64
- nothing provides python(abi) = 3.11 needed by anaconda-core-1000:37.12.6-5.fc37.x86_64
- nothing provides python3-dasbus >= 1.3 needed by anaconda-core-1000:37.12.6-5.fc37.x86_64
- nothing provides python3-langtable >= 0.0.54 needed by anaconda-core-1000:37.12.6-5.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by anaconda-core-1000:37.12.6-5.fc37.x86_64
- nothing provides systemd-resolved needed by anaconda-core-1000:37.12.6-5.fc37.x86_64
- nothing provides python(abi) = 3.11 needed by anaconda-core-1000:37.12.6-6.fc37.x86_64
- nothing provides python3-dasbus >= 1.3 needed by anaconda-core-1000:37.12.6-6.fc37.x86_64
- nothing provides python3-langtable >= 0.0.54 needed by anaconda-core-1000:37.12.6-6.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by anaconda-core-1000:37.12.6-6.fc37.x86_64
- nothing provides systemd-resolved needed by anaconda-core-1000:37.12.6-6.fc37.x86_64
- nothing provides python(abi) = 3.11 needed by anaconda-core-1000:37.12.6-2.fc37.x86_64
- nothing provides python3-dasbus >= 1.3 needed by anaconda-core-1000:37.12.6-2.fc37.x86_64
- nothing provides python3-langtable >= 0.0.54 needed by anaconda-core-1000:37.12.6-2.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by anaconda-core-1000:37.12.6-2.fc37.x86_64
- nothing provides systemd-resolved needed by anaconda-core-1000:37.12.6-2.fc37.x86_64
- nothing provides python(abi) = 3.11 needed by anaconda-core-1000:37.12.6-3.fc37.x86_64
- nothing provides python3-dasbus >= 1.3 needed by anaconda-core-1000:37.12.6-3.fc37.x86_64
- nothing provides python3-langtable >= 0.0.54 needed by anaconda-core-1000:37.12.6-3.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by anaconda-core-1000:37.12.6-3.fc37.x86_64
- nothing provides systemd-resolved needed by anaconda-core-1000:37.12.6-3.fc37.x86_64
Problem 5: problem with installed package anaconda-gui-1000:32.24.5-8.fc32.x86_64
- cannot install the best update candidate for package anaconda-gui-1000:32.24.5-8.fc32.x86_64
- anaconda-gui-1000:32.24.5-8.fc32.x86_64 does not belong to a distupgrade repository
- nothing provides python(abi) = 3.11 needed by anaconda-gui-1000:37.12.6-4.fc37.x86_64
- nothing provides anaconda-user-help >= 26.2-1 needed by anaconda-gui-1000:37.12.6-4.fc37.x86_64
- nothing provides python(abi) = 3.11 needed by anaconda-gui-1000:37.12.6-5.fc37.x86_64
- nothing provides anaconda-user-help >= 26.2-1 needed by anaconda-gui-1000:37.12.6-5.fc37.x86_64
- nothing provides python(abi) = 3.11 needed by anaconda-gui-1000:37.12.6-6.fc37.x86_64
- nothing provides anaconda-user-help >= 26.2-1 needed by anaconda-gui-1000:37.12.6-6.fc37.x86_64
- nothing provides python(abi) = 3.11 needed by anaconda-gui-1000:37.12.6-2.fc37.x86_64
- nothing provides anaconda-user-help >= 26.2-1 needed by anaconda-gui-1000:37.12.6-2.fc37.x86_64
- nothing provides python(abi) = 3.11 needed by anaconda-gui-1000:37.12.6-3.fc37.x86_64
- nothing provides anaconda-user-help >= 26.2-1 needed by anaconda-gui-1000:37.12.6-3.fc37.x86_64
Problem 6: problem with installed package anaconda-tui-1000:32.24.5-8.fc32.x86_64
- cannot install the best update candidate for package anaconda-tui-1000:32.24.5-8.fc32.x86_64
- anaconda-tui-1000:32.24.5-8.fc32.x86_64 does not belong to a distupgrade repository
- nothing provides python(abi) = 3.11 needed by anaconda-tui-1000:37.12.6-4.fc37.x86_64
- nothing provides python3-simpleline >= 1.9.0-1 needed by anaconda-tui-1000:37.12.6-4.fc37.x86_64
- nothing provides python(abi) = 3.11 needed by anaconda-tui-1000:37.12.6-5.fc37.x86_64
- nothing provides python3-simpleline >= 1.9.0-1 needed by anaconda-tui-1000:37.12.6-5.fc37.x86_64
- nothing provides python(abi) = 3.11 needed by anaconda-tui-1000:37.12.6-6.fc37.x86_64
- nothing provides python3-simpleline >= 1.9.0-1 needed by anaconda-tui-1000:37.12.6-6.fc37.x86_64
- nothing provides python(abi) = 3.11 needed by anaconda-tui-1000:37.12.6-2.fc37.x86_64
- nothing provides python3-simpleline >= 1.9.0-1 needed by anaconda-tui-1000:37.12.6-2.fc37.x86_64
- nothing provides python(abi) = 3.11 needed by anaconda-tui-1000:37.12.6-3.fc37.x86_64
- nothing provides python3-simpleline >= 1.9.0-1 needed by anaconda-tui-1000:37.12.6-3.fc37.x86_64
Problem 7: problem with installed package anaconda-widgets-1000:32.24.5-8.fc32.x86_64
- cannot install the best update candidate for package anaconda-widgets-1000:32.24.5-8.fc32.x86_64
- anaconda-widgets-1000:32.24.5-8.fc32.x86_64 does not belong to a distupgrade repository
- nothing provides python(abi) = 3.11 needed by anaconda-widgets-1000:37.12.6-4.fc37.x86_64
- nothing provides python(abi) = 3.11 needed by anaconda-widgets-1000:37.12.6-5.fc37.x86_64
- nothing provides python(abi) = 3.11 needed by anaconda-widgets-1000:37.12.6-6.fc37.x86_64
- nothing provides python(abi) = 3.11 needed by anaconda-widgets-1000:37.12.6-2.fc37.x86_64
- nothing provides python(abi) = 3.11 needed by anaconda-widgets-1000:37.12.6-3.fc37.x86_64
Problem 8: problem with installed package device-mapper-1:1.02.171-3.fc32.x86_64
- cannot install the best update candidate for package device-mapper-1:1.02.171-3.fc32.x86_64
- device-mapper-1:1.02.171-3.fc32.x86_64 does not belong to a distupgrade repository
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by device-mapper-1:1.02.171-5.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by device-mapper-1:1.02.171-6.fc37.x86_64
Problem 9: problem with installed package device-mapper-event-1:1.02.171-3.fc32.x86_64
- cannot install the best update candidate for package device-mapper-event-1:1.02.171-3.fc32.x86_64
- device-mapper-event-1:1.02.171-3.fc32.x86_64 does not belong to a distupgrade repository
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by device-mapper-event-1:1.02.171-5.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by device-mapper-event-1:1.02.171-6.fc37.x86_64
Problem 10: problem with installed package device-mapper-event-libs-1:1.02.171-3.fc32.x86_64
- cannot install the best update candidate for package device-mapper-event-libs-1:1.02.171-3.fc32.x86_64
- device-mapper-event-libs-1:1.02.171-3.fc32.x86_64 does not belong to a distupgrade repository
- nothing provides libc.so.6(GLIBC_2.33)(64bit) needed by device-mapper-event-libs-1:1.02.171-5.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.33)(64bit) needed by device-mapper-event-libs-1:1.02.171-6.fc37.x86_64
Problem 11: problem with installed package device-mapper-libs-1:1.02.171-3.fc32.x86_64
- cannot install the best update candidate for package device-mapper-libs-1:1.02.171-3.fc32.x86_64
- device-mapper-libs-1:1.02.171-3.fc32.x86_64 does not belong to a distupgrade repository
- nothing provides libc.so.6(GLIBC_2.33)(64bit) needed by device-mapper-libs-1:1.02.171-5.fc37.x86_64
- nothing provides libselinux.so.1(LIBSELINUX_1.0)(64bit) needed by device-mapper-libs-1:1.02.171-5.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.33)(64bit) needed by device-mapper-libs-1:1.02.171-6.fc37.x86_64
- nothing provides libselinux.so.1(LIBSELINUX_1.0)(64bit) needed by device-mapper-libs-1:1.02.171-6.fc37.x86_64
Problem 12: package kernel-1000:6.6.31-1.qubes.fc37.x86_64 requires dracut, but none of the providers can be installed
- cannot install the best update candidate for package kernel-1000:6.1.57-1.qubes.fc32.x86_64
- cannot install the best update candidate for package dracut-050-63.git20200529.fc32.x86_64
- dracut-050-63.git20200529.fc32.x86_64 does not belong to a distupgrade repository
- problem with installed package kernel-1000:6.1.57-1.qubes.fc32.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by dracut-059-5.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by dracut-059-4.fc37.x86_64
Problem 13: problem with installed package grub2-common-1000:2.04-2.fc32.noarch
- cannot install the best update candidate for package grub2-common-1000:2.04-2.fc32.noarch
- grub2-common-1000:2.04-2.fc32.noarch does not belong to a distupgrade repository
- nothing provides util-linux-core needed by grub2-common-1000:2.06-2.fc37.noarch
- nothing provides util-linux-core needed by grub2-common-1000:2.06-3.fc37.noarch
- nothing provides util-linux-core needed by grub2-common-1000:2.06-4.fc37.noarch
Problem 14: problem with installed package grub2-tools-1000:2.04-2.fc32.x86_64
- cannot install the best update candidate for package grub2-tools-1000:2.04-2.fc32.x86_64
- grub2-tools-1000:2.04-2.fc32.x86_64 does not belong to a distupgrade repository
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by grub2-tools-1000:2.06-2.fc37.x86_64
- nothing provides gettext-runtime needed by grub2-tools-1000:2.06-2.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by grub2-tools-1000:2.06-3.fc37.x86_64
- nothing provides gettext-runtime needed by grub2-tools-1000:2.06-3.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by grub2-tools-1000:2.06-4.fc37.x86_64
- nothing provides gettext-runtime needed by grub2-tools-1000:2.06-4.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by grub2-tools-efi-1000:2.06-2.fc37.x86_64
- nothing provides gettext-runtime needed by grub2-tools-efi-1000:2.06-2.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by grub2-tools-efi-1000:2.06-3.fc37.x86_64
- nothing provides gettext-runtime needed by grub2-tools-efi-1000:2.06-3.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by grub2-tools-efi-1000:2.06-4.fc37.x86_64
- nothing provides gettext-runtime needed by grub2-tools-efi-1000:2.06-4.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by grub2-tools-extra-1000:2.06-2.fc37.x86_64
- nothing provides gettext-runtime needed by grub2-tools-extra-1000:2.06-2.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by grub2-tools-extra-1000:2.06-3.fc37.x86_64
- nothing provides gettext-runtime needed by grub2-tools-extra-1000:2.06-3.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by grub2-tools-extra-1000:2.06-4.fc37.x86_64
- nothing provides gettext-runtime needed by grub2-tools-extra-1000:2.06-4.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by grub2-tools-minimal-1000:2.06-2.fc37.x86_64
- nothing provides gettext-runtime needed by grub2-tools-minimal-1000:2.06-2.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by grub2-tools-minimal-1000:2.06-3.fc37.x86_64
- nothing provides gettext-runtime needed by grub2-tools-minimal-1000:2.06-3.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by grub2-tools-minimal-1000:2.06-4.fc37.x86_64
- nothing provides gettext-runtime needed by grub2-tools-minimal-1000:2.06-4.fc37.x86_64
Problem 15: problem with installed package grub2-tools-efi-1000:2.04-2.fc32.x86_64
- cannot install the best update candidate for package grub2-tools-efi-1000:2.04-2.fc32.x86_64
- grub2-tools-efi-1000:2.04-2.fc32.x86_64 does not belong to a distupgrade repository
Problem 16: problem with installed package grub2-tools-extra-1000:2.04-2.fc32.x86_64
- cannot install the best update candidate for package grub2-tools-extra-1000:2.04-2.fc32.x86_64
- grub2-tools-extra-1000:2.04-2.fc32.x86_64 does not belong to a distupgrade repository
Problem 17: problem with installed package grub2-tools-minimal-1000:2.04-2.fc32.x86_64
- cannot install the best update candidate for package grub2-tools-minimal-1000:2.04-2.fc32.x86_64
- grub2-tools-minimal-1000:2.04-2.fc32.x86_64 does not belong to a distupgrade repository
Problem 18: problem with installed package libvirt-client-1000:6.6.0-8.fc32.x86_64
- cannot install the best update candidate for package libvirt-client-1000:6.6.0-8.fc32.x86_64
- libvirt-client-1000:6.6.0-8.fc32.x86_64 does not belong to a distupgrade repository
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by libvirt-client-1000:8.9.0-5.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by libvirt-client-1000:8.9.0-6.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by libvirt-client-1000:8.9.0-7.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by libvirt-client-1000:8.9.0-4.fc37.x86_64
Problem 19: problem with installed package libvirt-daemon-1000:6.6.0-8.fc32.x86_64
- cannot install the best update candidate for package libvirt-daemon-1000:6.6.0-8.fc32.x86_64
- libvirt-daemon-1000:6.6.0-8.fc32.x86_64 does not belong to a distupgrade repository
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by libvirt-daemon-1000:8.9.0-5.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by libvirt-daemon-1000:8.9.0-6.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by libvirt-daemon-1000:8.9.0-7.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by libvirt-daemon-1000:8.9.0-4.fc37.x86_64
Problem 20: problem with installed package libvirt-daemon-driver-interface-1000:6.6.0-8.fc32.x86_64
- cannot install the best update candidate for package libvirt-daemon-driver-interface-1000:6.6.0-8.fc32.x86_64
- libvirt-daemon-driver-interface-1000:6.6.0-8.fc32.x86_64 does not belong to a distupgrade repository
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by libvirt-daemon-driver-interface-1000:8.9.0-5.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by libvirt-daemon-driver-interface-1000:8.9.0-6.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by libvirt-daemon-driver-interface-1000:8.9.0-7.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by libvirt-daemon-driver-interface-1000:8.9.0-4.fc37.x86_64
Problem 21: problem with installed package libvirt-daemon-driver-libxl-1000:6.6.0-8.fc32.x86_64
- cannot install the best update candidate for package libvirt-daemon-driver-libxl-1000:6.6.0-8.fc32.x86_64
- libvirt-daemon-driver-libxl-1000:6.6.0-8.fc32.x86_64 does not belong to a distupgrade repository
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by libvirt-daemon-driver-libxl-1000:8.9.0-5.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by libvirt-daemon-driver-libxl-1000:8.9.0-6.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by libvirt-daemon-driver-libxl-1000:8.9.0-7.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by libvirt-daemon-driver-libxl-1000:8.9.0-4.fc37.x86_64
Problem 22: problem with installed package libvirt-daemon-driver-nodedev-1000:6.6.0-8.fc32.x86_64
- cannot install the best update candidate for package libvirt-daemon-driver-nodedev-1000:6.6.0-8.fc32.x86_64
- libvirt-daemon-driver-nodedev-1000:6.6.0-8.fc32.x86_64 does not belong to a distupgrade repository
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by libvirt-daemon-driver-nodedev-1000:8.9.0-5.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by libvirt-daemon-driver-nodedev-1000:8.9.0-6.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by libvirt-daemon-driver-nodedev-1000:8.9.0-7.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by libvirt-daemon-driver-nodedev-1000:8.9.0-4.fc37.x86_64
Problem 23: problem with installed package libvirt-daemon-driver-nwfilter-1000:6.6.0-8.fc32.x86_64
- cannot install the best update candidate for package libvirt-daemon-driver-nwfilter-1000:6.6.0-8.fc32.x86_64
- libvirt-daemon-driver-nwfilter-1000:6.6.0-8.fc32.x86_64 does not belong to a distupgrade repository
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by libvirt-daemon-driver-nwfilter-1000:8.9.0-5.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by libvirt-daemon-driver-nwfilter-1000:8.9.0-6.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by libvirt-daemon-driver-nwfilter-1000:8.9.0-7.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by libvirt-daemon-driver-nwfilter-1000:8.9.0-4.fc37.x86_64
Problem 24: problem with installed package libvirt-daemon-driver-secret-1000:6.6.0-8.fc32.x86_64
- cannot install the best update candidate for package libvirt-daemon-driver-secret-1000:6.6.0-8.fc32.x86_64
- libvirt-daemon-driver-secret-1000:6.6.0-8.fc32.x86_64 does not belong to a distupgrade repository
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by libvirt-daemon-driver-secret-1000:8.9.0-5.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by libvirt-daemon-driver-secret-1000:8.9.0-6.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by libvirt-daemon-driver-secret-1000:8.9.0-7.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by libvirt-daemon-driver-secret-1000:8.9.0-4.fc37.x86_64
Problem 25: problem with installed package libvirt-daemon-driver-storage-core-1000:6.6.0-8.fc32.x86_64
- cannot install the best update candidate for package libvirt-daemon-driver-storage-core-1000:6.6.0-8.fc32.x86_64
- libvirt-daemon-driver-storage-core-1000:6.6.0-8.fc32.x86_64 does not belong to a distupgrade repository
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by libvirt-daemon-driver-storage-core-1000:8.9.0-5.fc37.x86_64
- nothing provides libselinux.so.1(LIBSELINUX_1.0)(64bit) needed by libvirt-daemon-driver-storage-core-1000:8.9.0-5.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by libvirt-daemon-driver-storage-core-1000:8.9.0-6.fc37.x86_64
- nothing provides libselinux.so.1(LIBSELINUX_1.0)(64bit) needed by libvirt-daemon-driver-storage-core-1000:8.9.0-6.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by libvirt-daemon-driver-storage-core-1000:8.9.0-7.fc37.x86_64
- nothing provides libselinux.so.1(LIBSELINUX_1.0)(64bit) needed by libvirt-daemon-driver-storage-core-1000:8.9.0-7.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by libvirt-daemon-driver-storage-core-1000:8.9.0-4.fc37.x86_64
- nothing provides libselinux.so.1(LIBSELINUX_1.0)(64bit) needed by libvirt-daemon-driver-storage-core-1000:8.9.0-4.fc37.x86_64
Problem 26: problem with installed package libvirt-libs-1000:6.6.0-8.fc32.x86_64
- cannot install the best update candidate for package libvirt-libs-1000:6.6.0-8.fc32.x86_64
- libvirt-libs-1000:6.6.0-8.fc32.x86_64 does not belong to a distupgrade repository
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by libvirt-libs-1000:8.9.0-5.fc37.x86_64
- nothing provides libselinux.so.1(LIBSELINUX_1.0)(64bit) needed by libvirt-libs-1000:8.9.0-5.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by libvirt-libs-1000:8.9.0-6.fc37.x86_64
- nothing provides libselinux.so.1(LIBSELINUX_1.0)(64bit) needed by libvirt-libs-1000:8.9.0-6.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by libvirt-libs-1000:8.9.0-7.fc37.x86_64
- nothing provides libselinux.so.1(LIBSELINUX_1.0)(64bit) needed by libvirt-libs-1000:8.9.0-7.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by libvirt-libs-1000:8.9.0-4.fc37.x86_64
- nothing provides libselinux.so.1(LIBSELINUX_1.0)(64bit) needed by libvirt-libs-1000:8.9.0-4.fc37.x86_64
Problem 27: problem with installed package lvm2-1:2.03.09-3.fc32.x86_64
- cannot install the best update candidate for package lvm2-1:2.03.09-3.fc32.x86_64
- lvm2-1:2.03.09-3.fc32.x86_64 does not belong to a distupgrade repository
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by lvm2-1:2.03.09-5.fc37.x86_64
- nothing provides libselinux.so.1(LIBSELINUX_1.0)(64bit) needed by lvm2-1:2.03.09-5.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by lvm2-1:2.03.09-6.fc37.x86_64
- nothing provides libselinux.so.1(LIBSELINUX_1.0)(64bit) needed by lvm2-1:2.03.09-6.fc37.x86_64
Problem 28: problem with installed package lvm2-libs-1:2.03.09-3.fc32.x86_64
- cannot install the best update candidate for package lvm2-libs-1:2.03.09-3.fc32.x86_64
- lvm2-libs-1:2.03.09-3.fc32.x86_64 does not belong to a distupgrade repository
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by lvm2-libs-1:2.03.09-5.fc37.x86_64
- nothing provides libselinux.so.1(LIBSELINUX_1.0)(64bit) needed by lvm2-libs-1:2.03.09-5.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by lvm2-libs-1:2.03.09-6.fc37.x86_64
- nothing provides libselinux.so.1(LIBSELINUX_1.0)(64bit) needed by lvm2-libs-1:2.03.09-6.fc37.x86_64
Problem 29: problem with installed package python3-blivet-1000:3.2.1-2.fc32.noarch
- cannot install the best update candidate for package python3-blivet-1000:3.2.1-2.fc32.noarch
- python3-blivet-1000:3.2.1-2.fc32.noarch does not belong to a distupgrade repository
- nothing provides python(abi) = 3.11 needed by python3-blivet-1000:3.5.0-1.fc37.noarch
- nothing provides python3.11dist(pyudev) needed by python3-blivet-1000:3.5.0-1.fc37.noarch
- nothing provides python3.11dist(six) needed by python3-blivet-1000:3.5.0-1.fc37.noarch
Problem 30: problem with installed package python3-kickstart-1000:3.24-2.fc32.noarch
- cannot install the best update candidate for package python3-kickstart-1000:3.24-2.fc32.noarch
- python3-kickstart-1000:3.24-2.fc32.noarch does not belong to a distupgrade repository
- nothing provides python(abi) = 3.11 needed by python3-kickstart-1000:3.41-1.fc37.noarch
- nothing provides python3.11dist(requests) needed by python3-kickstart-1000:3.41-1.fc37.noarch
Problem 31: problem with installed package python3-libvirt-1000:6.6.0-8.fc32.x86_64
- cannot install the best update candidate for package python3-libvirt-1000:6.6.0-8.fc32.x86_64
- python3-libvirt-1000:6.6.0-8.fc32.x86_64 does not belong to a distupgrade repository
- nothing provides python(abi) = 3.11 needed by python3-libvirt-1000:8.9.0-5.fc37.x86_64
- nothing provides python(abi) = 3.11 needed by python3-libvirt-1000:8.9.0-6.fc37.x86_64
- nothing provides python(abi) = 3.11 needed by python3-libvirt-1000:8.9.0-7.fc37.x86_64
- nothing provides python(abi) = 3.11 needed by python3-libvirt-1000:8.9.0-4.fc37.x86_64
Problem 32: problem with installed package qubes-anaconda-addon-4.1.12-1.fc32.noarch
- cannot install the best update candidate for package qubes-anaconda-addon-4.1.12-1.fc32.noarch
- qubes-anaconda-addon-4.1.12-1.fc32.noarch does not belong to a distupgrade repository
- nothing provides python3-looseversion needed by qubes-anaconda-addon-4.2.6-1.fc37.noarch
- nothing provides python3-looseversion needed by qubes-anaconda-addon-4.2.7-1.fc37.noarch
Problem 33: problem with installed package xdotool-1:3.20210804.2-3.fc32.x86_64
- cannot install the best update candidate for package xdotool-1:3.20210804.2-3.fc32.x86_64
- xdotool-1:3.20210804.2-3.fc32.x86_64 does not belong to a distupgrade repository
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xdotool-1:3.20210804.2-3.fc37.x86_64
Problem 34: problem with installed package xen-libs-2001:4.14.6-9.fc32.x86_64
- cannot install the best update candidate for package xen-libs-2001:4.14.6-9.fc32.x86_64
- xen-libs-2001:4.14.6-9.fc32.x86_64 does not belong to a distupgrade repository
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xen-libs-2001:4.17.0-8.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xen-libs-2001:4.17.0-9.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xen-libs-2001:4.17.1-1.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xen-libs-2001:4.17.1-4.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xen-libs-2001:4.17.2-1.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xen-libs-2001:4.17.2-2.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xen-libs-2001:4.17.2-4.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xen-libs-2001:4.17.2-5.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xen-libs-2001:4.17.2-7.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xen-libs-2001:4.17.2-8.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xen-libs-2001:4.17.3-2.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xen-libs-2001:4.17.3-4.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xen-libs-2001:4.17.3-5.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xen-libs-2001:4.17.4-2.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xen-libs-2001:4.17.0-4.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xen-libs-2001:4.17.0-5.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xen-libs-2001:4.17.0-6.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xen-libs-2001:4.17.0-7.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xen-libs-2001:4.17.1-2.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xen-libs-2001:4.17.1-3.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xen-libs-2001:4.17.2-3.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xen-libs-2001:4.17.2-6.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xen-libs-2001:4.17.3-1.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xen-libs-2001:4.17.3-3.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xen-libs-2001:4.17.4-1.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xen-libs-2001:4.17.4-3.fc37.x86_64
Problem 35: problem with installed package xen-runtime-2001:4.14.6-9.fc32.x86_64
- cannot install the best update candidate for package xen-runtime-2001:4.14.6-9.fc32.x86_64
- xen-runtime-2001:4.14.6-9.fc32.x86_64 does not belong to a distupgrade repository
- nothing provides python(abi) = 3.11 needed by xen-runtime-2001:4.17.0-8.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xen-runtime-2001:4.17.0-8.fc37.x86_64
- nothing provides python(abi) = 3.11 needed by xen-runtime-2001:4.17.0-9.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xen-runtime-2001:4.17.0-9.fc37.x86_64
- nothing provides python(abi) = 3.11 needed by xen-runtime-2001:4.17.1-1.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xen-runtime-2001:4.17.1-1.fc37.x86_64
- nothing provides python(abi) = 3.11 needed by xen-runtime-2001:4.17.1-4.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xen-runtime-2001:4.17.1-4.fc37.x86_64
- nothing provides python(abi) = 3.11 needed by xen-runtime-2001:4.17.2-1.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xen-runtime-2001:4.17.2-1.fc37.x86_64
- nothing provides python(abi) = 3.11 needed by xen-runtime-2001:4.17.2-2.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xen-runtime-2001:4.17.2-2.fc37.x86_64
- nothing provides python(abi) = 3.11 needed by xen-runtime-2001:4.17.2-4.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xen-runtime-2001:4.17.2-4.fc37.x86_64
- nothing provides python(abi) = 3.11 needed by xen-runtime-2001:4.17.2-5.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xen-runtime-2001:4.17.2-5.fc37.x86_64
- nothing provides python(abi) = 3.11 needed by xen-runtime-2001:4.17.2-7.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xen-runtime-2001:4.17.2-7.fc37.x86_64
- nothing provides python(abi) = 3.11 needed by xen-runtime-2001:4.17.2-8.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xen-runtime-2001:4.17.2-8.fc37.x86_64
- nothing provides python(abi) = 3.11 needed by xen-runtime-2001:4.17.3-2.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xen-runtime-2001:4.17.3-2.fc37.x86_64
- nothing provides python(abi) = 3.11 needed by xen-runtime-2001:4.17.3-4.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xen-runtime-2001:4.17.3-4.fc37.x86_64
- nothing provides python(abi) = 3.11 needed by xen-runtime-2001:4.17.3-5.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xen-runtime-2001:4.17.3-5.fc37.x86_64
- nothing provides python(abi) = 3.11 needed by xen-runtime-2001:4.17.4-2.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xen-runtime-2001:4.17.4-2.fc37.x86_64
- nothing provides python(abi) = 3.11 needed by xen-runtime-2001:4.17.0-4.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xen-runtime-2001:4.17.0-4.fc37.x86_64
- nothing provides python(abi) = 3.11 needed by xen-runtime-2001:4.17.0-5.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xen-runtime-2001:4.17.0-5.fc37.x86_64
- nothing provides python(abi) = 3.11 needed by xen-runtime-2001:4.17.0-6.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xen-runtime-2001:4.17.0-6.fc37.x86_64
- nothing provides python(abi) = 3.11 needed by xen-runtime-2001:4.17.0-7.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xen-runtime-2001:4.17.0-7.fc37.x86_64
- nothing provides python(abi) = 3.11 needed by xen-runtime-2001:4.17.1-2.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xen-runtime-2001:4.17.1-2.fc37.x86_64
- nothing provides python(abi) = 3.11 needed by xen-runtime-2001:4.17.1-3.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xen-runtime-2001:4.17.1-3.fc37.x86_64
- nothing provides python(abi) = 3.11 needed by xen-runtime-2001:4.17.2-3.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xen-runtime-2001:4.17.2-3.fc37.x86_64
- nothing provides python(abi) = 3.11 needed by xen-runtime-2001:4.17.2-6.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xen-runtime-2001:4.17.2-6.fc37.x86_64
- nothing provides python(abi) = 3.11 needed by xen-runtime-2001:4.17.3-1.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xen-runtime-2001:4.17.3-1.fc37.x86_64
- nothing provides python(abi) = 3.11 needed by xen-runtime-2001:4.17.3-3.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xen-runtime-2001:4.17.3-3.fc37.x86_64
- nothing provides python(abi) = 3.11 needed by xen-runtime-2001:4.17.4-1.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xen-runtime-2001:4.17.4-1.fc37.x86_64
- nothing provides python(abi) = 3.11 needed by xen-runtime-2001:4.17.4-3.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xen-runtime-2001:4.17.4-3.fc37.x86_64
Problem 36: problem with installed package xfwm4-1000:4.14.2-3.fc32.x86_64
- cannot install the best update candidate for package xfwm4-1000:4.14.2-3.fc32.x86_64
- xfwm4-1000:4.14.2-3.fc32.x86_64 does not belong to a distupgrade repository
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xfwm4-1000:4.16.1-3.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xfwm4-1000:4.16.1-4.fc37.x86_64
Problem 37: problem with installed package xorg-x11-drv-intel-2.99.917-49.20210126.fc32.x86_64
- cannot install the best update candidate for package xorg-x11-drv-intel-2.99.917-49.20210126.fc32.x86_64
- xorg-x11-drv-intel-2.99.917-49.20210126.fc32.x86_64 does not belong to a distupgrade repository
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xorg-x11-drv-intel-2.99.917-50.20210126.fc37.x86_64
Problem 38: problem with installed package xscreensaver-base-2:6.06-1.43.fc32.x86_64
- cannot install the best update candidate for package xscreensaver-base-2:6.06-1.43.fc32.x86_64
- xscreensaver-base-2:6.06-1.43.fc32.x86_64 does not belong to a distupgrade repository
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xscreensaver-base-2:6.06-1.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xscreensaver-base-2:6.06-2.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xscreensaver-base-2:6.08-1.fc37.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by xscreensaver-base-1:5.45-6.fc37.x86_64
Problem 39: problem with installed package salt-3001.7-1.fc32.noarch
- cannot install the best update candidate for package salt-3001.7-1.fc32.noarch
- nothing provides python(abi) = 3.11 needed by salt-3005.1-4.fc37.noarch
- nothing provides ((python3.11dist(msgpack) < 0.5.5 or python3.11dist(msgpack) > 0.5.5) with python3.11dist(msgpack) >= 0.5) needed by salt-3005.1-4.fc37.noarch
- nothing provides python3.11dist(distro) >= 1.0.1 needed by salt-3005.1-4.fc37.noarch
- nothing provides python3.11dist(psutil) >= 5 needed by salt-3005.1-4.fc37.noarch
- nothing provides python3.11dist(pycryptodomex) >= 3.9.8 needed by salt-3005.1-4.fc37.noarch
- nothing provides python3.11dist(requests) >= 1 needed by salt-3005.1-4.fc37.noarch
- nothing provides python3.11dist(pyzmq) >= 19.0.2 needed by salt-3005.1-4.fc37.noarch
- nothing provides python3.11dist(jinja2) needed by salt-3005.1-4.fc37.noarch
- nothing provides python3.11dist(jmespath) needed by salt-3005.1-4.fc37.noarch
- nothing provides python3.11dist(markupsafe) needed by salt-3005.1-4.fc37.noarch
- nothing provides python3.11dist(pyyaml) needed by salt-3005.1-4.fc37.noarch
- nothing provides python(abi) = 3.11 needed by salt-3006.1-2.fc37.noarch
- nothing provides ((python3.11dist(msgpack) < 0.5.5 or python3.11dist(msgpack) > 0.5.5) with python3.11dist(msgpack) >= 0.5) needed by salt-3006.1-2.fc37.noarch
- nothing provides python3.11dist(distro) >= 1.0.1 needed by salt-3006.1-2.fc37.noarch
- nothing provides python3.11dist(psutil) >= 5 needed by salt-3006.1-2.fc37.noarch
- nothing provides python3.11dist(pycryptodomex) >= 3.9.8 needed by salt-3006.1-2.fc37.noarch
- nothing provides python3.11dist(requests) >= 1 needed by salt-3006.1-2.fc37.noarch
- nothing provides python3.11dist(packaging) >= 21.3 needed by salt-3006.1-2.fc37.noarch
- nothing provides python3.11dist(pyzmq) >= 20 needed by salt-3006.1-2.fc37.noarch
- nothing provides python3.11dist(jinja2) needed by salt-3006.1-2.fc37.noarch
- nothing provides python3.11dist(jmespath) needed by salt-3006.1-2.fc37.noarch
- nothing provides python3.11dist(markupsafe) needed by salt-3006.1-2.fc37.noarch
- nothing provides python3.11dist(pyyaml) needed by salt-3006.1-2.fc37.noarch
- nothing provides python3.11dist(looseversion) needed by salt-3006.1-2.fc37.noarch
- nothing provides python(abi) = 3.11 needed by salt-3006.2-2.fc37.noarch
- nothing provides ((python3.11dist(msgpack) < 0.5.5 or python3.11dist(msgpack) > 0.5.5) with python3.11dist(msgpack) >= 0.5) needed by salt-3006.2-2.fc37.noarch
- nothing provides python3.11dist(distro) >= 1.0.1 needed by salt-3006.2-2.fc37.noarch
- nothing provides python3.11dist(psutil) >= 5 needed by salt-3006.2-2.fc37.noarch
- nothing provides python3.11dist(pycryptodomex) >= 3.9.8 needed by salt-3006.2-2.fc37.noarch
- nothing provides python3.11dist(requests) >= 1 needed by salt-3006.2-2.fc37.noarch
- nothing provides python3.11dist(packaging) >= 21.3 needed by salt-3006.2-2.fc37.noarch
- nothing provides python3.11dist(pyzmq) >= 20 needed by salt-3006.2-2.fc37.noarch
- nothing provides python3.11dist(jinja2) needed by salt-3006.2-2.fc37.noarch
- nothing provides python3.11dist(jmespath) needed by salt-3006.2-2.fc37.noarch
- nothing provides python3.11dist(markupsafe) needed by salt-3006.2-2.fc37.noarch
- nothing provides python3.11dist(pyyaml) needed by salt-3006.2-2.fc37.noarch
- nothing provides python3.11dist(looseversion) needed by salt-3006.2-2.fc37.noarch
- nothing provides python(abi) = 3.11 needed by salt-3006.4-2.fc37.noarch
- nothing provides ((python3.11dist(msgpack) < 0.5.5 or python3.11dist(msgpack) > 0.5.5) with python3.11dist(msgpack) >= 0.5) needed by salt-3006.4-2.fc37.noarch
- nothing provides python3.11dist(distro) >= 1.0.1 needed by salt-3006.4-2.fc37.noarch
- nothing provides python3.11dist(psutil) >= 5 needed by salt-3006.4-2.fc37.noarch
- nothing provides python3.11dist(pycryptodomex) >= 3.9.8 needed by salt-3006.4-2.fc37.noarch
- nothing provides python3.11dist(requests) >= 1 needed by salt-3006.4-2.fc37.noarch
- nothing provides python3.11dist(packaging) >= 21.3 needed by salt-3006.4-2.fc37.noarch
- nothing provides python3.11dist(pyzmq) >= 20 needed by salt-3006.4-2.fc37.noarch
- nothing provides python3.11dist(jinja2) needed by salt-3006.4-2.fc37.noarch
- nothing provides python3.11dist(jmespath) needed by salt-3006.4-2.fc37.noarch
- nothing provides python3.11dist(markupsafe) needed by salt-3006.4-2.fc37.noarch
- nothing provides python3.11dist(pyyaml) needed by salt-3006.4-2.fc37.noarch
- nothing provides python3.11dist(looseversion) needed by salt-3006.4-2.fc37.noarch
- nothing provides python(abi) = 3.11 needed by salt-3006.5-1.fc37.noarch
- nothing provides ((python3.11dist(msgpack) < 0.5.5 or python3.11dist(msgpack) > 0.5.5) with python3.11dist(msgpack) >= 0.5) needed by salt-3006.5-1.fc37.noarch
- nothing provides python3.11dist(distro) >= 1.0.1 needed by salt-3006.5-1.fc37.noarch
- nothing provides python3.11dist(psutil) >= 5 needed by salt-3006.5-1.fc37.noarch
- nothing provides python3.11dist(pycryptodomex) >= 3.9.8 needed by salt-3006.5-1.fc37.noarch
- nothing provides python3.11dist(requests) >= 1 needed by salt-3006.5-1.fc37.noarch
- nothing provides python3.11dist(packaging) >= 21.3 needed by salt-3006.5-1.fc37.noarch
- nothing provides python3.11dist(pyzmq) >= 20 needed by salt-3006.5-1.fc37.noarch
- nothing provides python3.11dist(jinja2) needed by salt-3006.5-1.fc37.noarch
- nothing provides python3.11dist(jmespath) needed by salt-3006.5-1.fc37.noarch
- nothing provides python3.11dist(markupsafe) needed by salt-3006.5-1.fc37.noarch
- nothing provides python3.11dist(pyyaml) needed by salt-3006.5-1.fc37.noarch
- nothing provides python3.11dist(looseversion) needed by salt-3006.5-1.fc37.noarch
- nothing provides python(abi) = 3.11 needed by salt-3006.1-1.fc37.noarch
- nothing provides ((python3.11dist(msgpack) < 0.5.5 or python3.11dist(msgpack) > 0.5.5) with python3.11dist(msgpack) >= 0.5) needed by salt-3006.1-1.fc37.noarch
- nothing provides python3.11dist(distro) >= 1.0.1 needed by salt-3006.1-1.fc37.noarch
- nothing provides python3.11dist(psutil) >= 5 needed by salt-3006.1-1.fc37.noarch
- nothing provides python3.11dist(pycryptodomex) >= 3.9.8 needed by salt-3006.1-1.fc37.noarch
- nothing provides python3.11dist(requests) >= 1 needed by salt-3006.1-1.fc37.noarch
- nothing provides python3.11dist(packaging) >= 21.3 needed by salt-3006.1-1.fc37.noarch
- nothing provides python3.11dist(pyzmq) >= 20 needed by salt-3006.1-1.fc37.noarch
- nothing provides python3.11dist(jinja2) needed by salt-3006.1-1.fc37.noarch
- nothing provides python3.11dist(jmespath) needed by salt-3006.1-1.fc37.noarch
- nothing provides python3.11dist(markupsafe) needed by salt-3006.1-1.fc37.noarch
- nothing provides python3.11dist(pyyaml) needed by salt-3006.1-1.fc37.noarch
- nothing provides python3.11dist(looseversion) needed by salt-3006.1-1.fc37.noarch
Problem 40: problem with installed package plymouth-core-libs-0.9.4-14.20200325gite31c81f.fc32.x86_64
- cannot install the best update candidate for package plymouth-core-libs-0.9.4-14.20200325gite31c81f.fc32.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by plymouth-core-libs-22.02.122-4.fc37.x86_64
Problem 41: problem with installed package plymouth-0.9.4-14.20200325gite31c81f.fc32.x86_64
- cannot install the best update candidate for package plymouth-0.9.4-14.20200325gite31c81f.fc32.x86_64
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by plymouth-22.02.122-4.fc37.x86_64
Problem 42: problem with installed package initial-setup-gui-0.3.80-2.fc32.x86_64
- cannot install the best update candidate for package initial-setup-gui-0.3.80-2.fc32.x86_64
- nothing provides python(abi) = 3.11 needed by initial-setup-gui-0.3.95-4.fc37.x86_64
- nothing provides python(abi) = 3.11 needed by initial-setup-gui-0.3.95-5.fc37.x86_64
- nothing provides python(abi) = 3.11 needed by initial-setup-gui-0.3.95-3.fc37.x86_64
Problem 43: problem with installed package initial-setup-0.3.80-2.fc32.x86_64
- cannot install the best update candidate for package initial-setup-0.3.80-2.fc32.x86_64
- nothing provides python(abi) = 3.11 needed by initial-setup-0.3.95-4.fc37.x86_64
- nothing provides python(abi) = 3.11 needed by initial-setup-0.3.95-5.fc37.x86_64
- nothing provides python(abi) = 3.11 needed by initial-setup-0.3.95-3.fc37.x86_64
Problem 44: problem with installed package xen-2001:4.14.6-9.fc32.x86_64
- cannot install the best update candidate for package xen-2001:4.14.6-9.fc32.x86_64
- package xen-2001:4.17.0-8.fc37.x86_64 requires xen-runtime = 2001:4.17.0-8.fc37, but none of the providers can be installed
- package xen-2001:4.17.0-9.fc37.x86_64 requires xen-runtime = 2001:4.17.0-9.fc37, but none of the providers can be installed
- package xen-2001:4.17.1-1.fc37.x86_64 requires xen-runtime = 2001:4.17.1-1.fc37, but none of the providers can be installed
- package xen-2001:4.17.1-4.fc37.x86_64 requires xen-runtime = 2001:4.17.1-4.fc37, but none of the providers can be installed
- package xen-2001:4.17.2-1.fc37.x86_64 requires xen-runtime = 2001:4.17.2-1.fc37, but none of the providers can be installed
- package xen-2001:4.17.2-2.fc37.x86_64 requires xen-runtime = 2001:4.17.2-2.fc37, but none of the providers can be installed
- package xen-2001:4.17.2-4.fc37.x86_64 requires xen-runtime = 2001:4.17.2-4.fc37, but none of the providers can be installed
- package xen-2001:4.17.2-5.fc37.x86_64 requires xen-runtime = 2001:4.17.2-5.fc37, but none of the providers can be installed
- package xen-2001:4.17.2-7.fc37.x86_64 requires xen-runtime = 2001:4.17.2-7.fc37, but none of the providers can be installed
- package xen-2001:4.17.2-8.fc37.x86_64 requires xen-runtime = 2001:4.17.2-8.fc37, but none of the providers can be installed
- package xen-2001:4.17.3-2.fc37.x86_64 requires xen-runtime = 2001:4.17.3-2.fc37, but none of the providers can be installed
- package xen-2001:4.17.3-4.fc37.x86_64 requires xen-runtime = 2001:4.17.3-4.fc37, but none of the providers can be installed
- package xen-2001:4.17.3-5.fc37.x86_64 requires xen-runtime = 2001:4.17.3-5.fc37, but none of the providers can be installed
- package xen-2001:4.17.4-2.fc37.x86_64 requires xen-runtime = 2001:4.17.4-2.fc37, but none of the providers can be installed
- package xen-2001:4.17.0-4.fc37.x86_64 requires xen-runtime = 2001:4.17.0-4.fc37, but none of the providers can be installed
- package xen-2001:4.17.0-5.fc37.x86_64 requires xen-runtime = 2001:4.17.0-5.fc37, but none of the providers can be installed
- package xen-2001:4.17.0-6.fc37.x86_64 requires xen-runtime = 2001:4.17.0-6.fc37, but none of the providers can be installed
- package xen-2001:4.17.0-7.fc37.x86_64 requires xen-runtime = 2001:4.17.0-7.fc37, but none of the providers can be installed
- package xen-2001:4.17.1-2.fc37.x86_64 requires xen-runtime = 2001:4.17.1-2.fc37, but none of the providers can be installed
- package xen-2001:4.17.1-3.fc37.x86_64 requires xen-runtime = 2001:4.17.1-3.fc37, but none of the providers can be installed
- package xen-2001:4.17.2-3.fc37.x86_64 requires xen-runtime = 2001:4.17.2-3.fc37, but none of the providers can be installed
- package xen-2001:4.17.2-6.fc37.x86_64 requires xen-runtime = 2001:4.17.2-6.fc37, but none of the providers can be installed
- package xen-2001:4.17.3-1.fc37.x86_64 requires xen-runtime = 2001:4.17.3-1.fc37, but none of the providers can be installed
- package xen-2001:4.17.3-3.fc37.x86_64 requires xen-runtime = 2001:4.17.3-3.fc37, but none of the providers can be installed
- package xen-2001:4.17.4-1.fc37.x86_64 requires xen-runtime = 2001:4.17.4-1.fc37, but none of the providers can be installed
- package xen-2001:4.17.4-3.fc37.x86_64 requires xen-runtime = 2001:4.17.4-3.fc37, but none of the providers can be installed
- xen-2001:4.14.6-9.fc32.x86_64 does not belong to a distupgrade repository
Problem 45: problem with installed package salt-minion-3001.7-1.fc32.noarch
- cannot install the best update candidate for package salt-minion-3001.7-1.fc32.noarch
- package salt-minion-3005.1-4.fc37.noarch requires salt = 3005.1-4.fc37, but none of the providers can be installed
- package salt-minion-3006.1-2.fc37.noarch requires salt = 3006.1-2.fc37, but none of the providers can be installed
- package salt-minion-3006.2-2.fc37.noarch requires salt = 3006.2-2.fc37, but none of the providers can be installed
- package salt-minion-3006.4-2.fc37.noarch requires salt = 3006.4-2.fc37, but none of the providers can be installed
- package salt-minion-3006.5-1.fc37.noarch requires salt = 3006.5-1.fc37, but none of the providers can be installed
- package salt-minion-3006.1-1.fc37.noarch requires salt = 3006.1-1.fc37, but none of the providers can be installed
Problem 46: problem with installed package plymouth-plugin-script-0.9.4-14.20200325gite31c81f.fc32.x86_64
- cannot install the best update candidate for package plymouth-plugin-script-0.9.4-14.20200325gite31c81f.fc32.x86_64
- package plymouth-plugin-script-22.02.122-4.fc37.x86_64 requires libply-splash-core.so.5()(64bit), but none of the providers can be installed
- package plymouth-plugin-script-22.02.122-4.fc37.x86_64 requires libply.so.5()(64bit), but none of the providers can be installed
Problem 47: problem with installed package plymouth-plugin-label-0.9.4-14.20200325gite31c81f.fc32.x86_64
- cannot install the best update candidate for package plymouth-plugin-label-0.9.4-14.20200325gite31c81f.fc32.x86_64
- package plymouth-plugin-label-22.02.122-4.fc37.x86_64 requires libply-splash-core.so.5()(64bit), but none of the providers can be installed
This is an addendum containing truncated text, due to the character limitation
of the Forum post box:
- nothing provides util-linux-core needed by qubes-core-dom0-4.2.23-1.fc37.noarch
- nothing provides util-linux-core needed by qubes-core-dom0-4.2.25-1.fc37.noarch
- nothing provides util-linux-core needed by qubes-core-dom0-4.2.26-1.fc37.noarch
- nothing provides util-linux-core needed by qubes-core-dom0-4.2.27-1.fc37.noarch
- nothing provides util-linux-core needed by qubes-core-dom0-4.2.29-1.fc37.noarch
- nothing provides util-linux-core needed by qubes-core-dom0-4.2.30-1.fc37.noarch
- nothing provides util-linux-core needed by qubes-core-dom0-4.2.7-1.fc37.noarch
- nothing provides util-linux-core needed by qubes-core-dom0-4.2.8-1.fc37.noarch
- nothing provides util-linux-core needed by qubes-core-dom0-4.2.9-1.fc37.noarch
Not sure where did it go wrong.
Maybe you had some errors during stage 2?
Check the repository files in dom0 /etc/yum.repos.d/fedora.repo and /etc/yum.repos.d/fedora-updates.repo to see that it has fedora 37 inside and not fedora 32.
A new file called fedora.repo.rpmnew was created and this contains the f37
string.
fedora.repo and fedora-updates.repo both contain the f32 string
Well, I’m not sure how qubes-dist-upgrade works, but I’d replace fedora* files with fedora*.rpmnew files and try to run stage 3 again. But make a copy of original fedora* files just in case.
What you’re saying is that we want to copy the contents of fedora.repo.rpmnew
into fedora.repo and fedora-updates.repo? Or, conversely we want the qubes-dist-
upgrade script to use fedora.repo.rpmnew as a parameter.
cp /etc/yum.repos.d/fedora.repo /etc/yum.repos.d/fedora.repo.bak
cp /etc/yum.repos.d/fedora-updates.repo /etc/yum.repos.d/fedora-updates.repo.bak
cp /etc/yum.repos.d/fedora.repo.rpmnew /etc/yum.repos.d/fedora.repo
cp /etc/yum.repos.d/fedora-updates.repo.rpmnew /etc/yum.repos.d/fedora-updates.repo
I just did
cp fedora.repo fedora2.repo
cp fedora-updates.repo fedora-updates2.repo
and then
cp fedora.repo.rpmnew fedora.repo
cp fedora-updates.repo.rpmnew fedora-updates.repo
Transaction Summary
Install 227 Packages
Upgrade 1214 Packages
Remove 5 Packages
Downgrade 2 Packages
The requests for the f37 repo succeeded for the most part but there is an error log for
failed mirror requests as follows:
Total download size: 1.2 G
DNF will only download packages for the transaction.
Downloading Packages:
(1/1443): zlib-1.2.12-5.fc37.x86_64.rpm 43 kB/s | 94 kB 00:02
(2/1443): zlib-devel-1.2.12-5.fc37.x86_64.rpm 19 kB/s | 44 kB 00:02
(3/1443): SDL2_gfx-1.0.4-8.fc37.x86_64.rpm 12 kB/s | 40 kB 00:03
(4/1443): chrony-4.3-1.fc37.x86_64.rpm 80 kB/s | 324 kB 00:04
(5/1443): GraphicsMagick-1.3.38-3.fc37.x86_64.rpm 229 kB/s | 1.6 MB 00:07
(6/1443): dmraid-libs-1.0.0.rc16-53.fc37.x86_64.rpm 76 kB/s | 126 kB 00:01
(7/1443): double-conversion-3.1.5-7.fc37.x86_64.rpm 66 kB/s | 48 kB 00:00
(8/1443): duktape-2.6.0-3.fc37.x86_64.rpm 236 kB/s | 165 kB 00:00
(9/1443): fuse3-3.10.5-5.fc37.x86_64.rpm 27 kB/s | 54 kB 00:01
(10/1443): exempi-2.6.2-2.fc37.x86_64.rpm 204 kB/s | 568 kB 00:02
(11/1443): fftw-libs-single-3.3.10-3.fc37.x86_64.rpm 255 kB/s | 947 kB 00:03
(12/1443): fuse3-libs-3.10.5-5.fc37.x86_64.rpm 83 kB/s | 92 kB 00:01
(13/1443): gawk-all-langpacks-5.1.1-4.fc37.x86_64.rpm 223 kB/s | 237 kB 00:01
(14/1443): gcr3-base-3.41.1-3.fc37.x86_64.rpm 78 kB/s | 275 kB 00:03
(15/1443): gperftools-libs-2.9.1-4.fc37.x86_64.rpm 54 kB/s | 307 kB 00:05
(16/1443): gcr-libs-3.92.0-1.fc37.x86_64.rpm 87 kB/s | 507 kB 00:05
(17/1443): gtkmm2.4-2.24.5-15.fc37.x86_64.rpm 129 kB/s | 821 kB 00:06
(18/1443): hiredis-1.0.2-3.fc37.x86_64.rpm 20 kB/s | 42 kB 00:02
(19/1443): gtkmm3.0-3.24.7-2.fc37.x86_64.rpm 91 kB/s | 1.0 MB 00:11
(20/1443): hunspell-en-0.20140811.1-23.fc37.noarch.rpm 31 kB/s | 180 kB 00:05
(21/1443): hunspell-en-GB-0.20140811.1-23.fc37.noarch.rpm 76 kB/s | 225 kB 00:02
(22/1443): hunspell-filesystem-1.7.0-21.fc37.x86_64.rpm 3.8 kB/s | 8.8 kB 00:02
(23/1443): highcontrast-icon-theme-3.28-15.fc37.noarch.rpm 209 kB/s | 3.2 MB 00:15
(24/1443): iceauth-1.0.9-2.fc37.x86_64.rpm 15 kB/s | 26 kB 00:01
(25/1443): iio-sensor-proxy-3.4-2.fc37.x86_64.rpm 40 kB/s | 63 kB 00:01
(26/1443): iw-5.9-5.fc37.x86_64.rpm 33 kB/s | 112 kB 00:03
(27/1443): khmer-os-content-fonts-5.0-36.fc37.noarch.rpm 22 kB/s | 75 kB 00:03
(28/1443): khmer-os-system-fonts-5.0-36.fc37.noarch.rpm 146 kB/s | 105 kB 00:00
(29/1443): ipxe-roms-qemu-20220210-2.git64113751.fc37.noarch.rpm 358 kB/s | 1.5 MB 00:04
(30/1443): libb2-0.98.1-7.fc37.x86_64.rpm 29 kB/s | 25 kB 00:00
(31/1443): libcanberra-gtk2-0.30-29.fc37.x86_64.rpm 55 kB/s | 26 kB 00:00
(32/1443): libbpf-0.8.0-2.fc37.x86_64.rpm 252 kB/s | 172 kB 00:00
(33/1443): libcbor-0.7.0-7.fc37.x86_64.rpm 76 kB/s | 56 kB 00:00
(34/1443): libcloudproviders-0.3.1-6.fc37.x86_64.rpm 73 kB/s | 44 kB 00:00
(35/1443): libfido2-1.11.0-3.fc37.x86_64.rpm 146 kB/s | 97 kB 00:00
(36/1443): libfsverity-1.4-8.fc37.x86_64.rpm 31 kB/s | 19 kB 00:00
(37/1443): libgexiv2-0.14.0-4.fc37.x86_64.rpm 138 kB/s | 94 kB 00:00
(38/1443): libglvnd-opengl-1.5.0-1.fc37.x86_64.rpm 66 kB/s | 42 kB 00:00
(39/1443): libgrss-0.7.0-15.fc37.x86_64.rpm 107 kB/s | 63 kB 00:00
(40/1443): libgsf-1.14.47-6.fc37.x86_64.rpm 155 kB/s | 255 kB 00:01
(41/1443): libgtop2-2.40.0-9.fc37.x86_64.rpm 63 kB/s | 162 kB 00:02
(42/1443): libgxps-0.3.2-4.fc37.x86_64.rpm 30 kB/s | 78 kB 00:02
(43/1443): libibverbs-41.0-1.fc37.x86_64.rpm 175 kB/s | 412 kB 00:02
(44/1443): libiptcdata-1.0.5-12.fc37.x86_64.rpm 46 kB/s | 61 kB 00:01
(45/1443): libkcapi-fipscheck-1.4.0-2.fc37.x86_64.rpm 18 kB/s | 22 kB 00:01
(46/1443): libldac-2.0.2.3-11.fc37.x86_64.rpm 9.5 kB/s | 41 kB 00:04
(47/1443): libmanette-0.2.6-5.fc37.x86_64.rpm 12 kB/s | 49 kB 00:04
(48/1443): libmpc-1.2.1-5.fc37.x86_64.rpm 14 kB/s | 61 kB 00:04
(49/1443): libproxy-duktape-0.4.18-3.fc37.x86_64.rpm 21 kB/s | 18 kB 00:00
(50/1443): libusb-compat-0.1-0.1.7-9.fc37.x86_64.rpm 35 kB/s | 29 kB 00:00
(51/1443): libusb1-1.0.25-9.fc37.x86_64.rpm 73 kB/s | 74 kB 00:01
(52/1443): lilv-libs-0.24.14-3.fc37.x86_64.rpm 68 kB/s | 58 kB 00:00
(53/1443): libvmaf-2.3.0-4.fc37.x86_64.rpm 156 kB/s | 180 kB 00:01
(54/1443): lv2-1.18.8-2.fc37.x86_64.rpm 40 kB/s | 104 kB 00:02
(55/1443): malcontent-libs-0.11.0-1.fc37.x86_64.rpm 23 kB/s | 47 kB 00:02
(56/1443): mkfontscale-1.2.2-2.fc37.x86_64.rpm 17 kB/s | 32 kB 00:01
(57/1443): mpdecimal-2.5.1-4.fc37.x86_64.rpm 106 kB/s | 102 kB 00:00
(58/1443): nano-default-editor-6.4-1.fc37.noarch.rpm 10 kB/s | 10 kB 00:00
(59/1443): pam-libs-1.5.2-14.fc37.x86_64.rpm 22 kB/s | 58 kB 00:02
(60/1443): pcsc-lite-1.9.9-1.fc37.x86_64.rpm 18 kB/s | 95 kB 00:05
(61/1443): openssl1.1-1.1.1q-2.fc37.x86_64.rpm 176 kB/s | 1.5 MB 00:08
(62/1443): pcsc-lite-libs-1.9.9-1.fc37.x86_64.rpm 5.6 kB/s | 28 kB 00:04
(63/1443): pcsc-lite-ccid-1.5.0-2.fc37.x86_64.rpm 54 kB/s | 319 kB 00:05
(64/1443): openblas-openmp-0.3.21-3.fc37.x86_64.rpm 291 kB/s | 5.1 MB 00:17
(65/1443): protobuf-c-1.4.1-2.fc37.x86_64.rpm 11 kB/s | 39 kB 00:03
(66/1443): pt-sans-fonts-20141121-22.fc37.noarch.rpm 212 kB/s | 898 kB 00:04
(67/1443): python3-charset-normalizer-2.1.0-2.fc37.noarch.rpm 80 kB/s | 102 kB 00:01
(68/1443): python3-gobject-base-noarch-3.42.2-2.fc37.noarch.rpm 91 kB/s | 195 kB 00:02
(69/1443): python3-packaging-21.3-6.fc37.noarch.rpm 104 kB/s | 98 kB 00:00
(70/1443): python3-jmespath-1.0.0-5.fc37.noarch.rpm 61 kB/s | 61 kB 00:00
(71/1443): rgb-1.0.6-44.fc37.x86_64.rpm 31 kB/s | 18 kB 00:00
(72/1443): python3-pyparsing-3.0.9-2.fc37.noarch.rpm 91 kB/s | 262 kB 00:02
(73/1443): sessreg-1.1.2-5.fc37.x86_64.rpm 7.4 kB/s | 17 kB 00:02
(74/1443): rsyslog-logrotate-8.2204.0-3.fc37.x86_64.rpm 3.4 kB/s | 10 kB 00:02
(75/1443): setxkbmap-1.3.3-3.fc37.x86_64.rpm 6.6 kB/s | 22 kB 00:03
(76/1443): totem-pl-parser-3.26.6-5.fc37.x86_64.rpm 29 kB/s | 144 kB 00:05
(77/1443): uchardet-0.0.6-16.fc37.x86_64.rpm 29 kB/s | 94 kB 00:03
(78/1443): util-linux-core-2.38.1-1.fc37.x86_64.rpm 121 kB/s | 470 kB 00:03
(79/1443): wireless-regdb-2022.06.06-2.fc37.noarch.rpm 12 kB/s | 16 kB 00:01
(80/1443): xdpyinfo-1.3.3-2.fc37.x86_64.rpm 12 kB/s | 26 kB 00:02
(81/1443): svt-av1-libs-1.1.0-2.fc37.x86_64.rpm 139 kB/s | 2.0 MB 00:14
(82/1443): xev-1.2.4-5.fc37.x86_64.rpm 24 kB/s | 24 kB 00:01
(83/1443): xgamma-1.0.6-5.fc37.x86_64.rpm 21 kB/s | 17 kB 00:00
(84/1443): xhost-1.0.8-4.fc37.x86_64.rpm 16 kB/s | 20 kB 00:01
(85/1443): xinput-1.6.3-5.fc37.x86_64.rpm 26 kB/s | 37 kB 00:01
(86/1443): urw-base35-fonts-legacy-20200910-15.fc37.noarch.rpm 227 kB/s | 3.0 MB 00:13
(87/1443): xkbcomp-1.4.5-4.fc37.x86_64.rpm 46 kB/s | 100 kB 00:02
(88/1443): xisxwayland-1-4.fc37.x86_64.rpm 5.6 kB/s | 14 kB 00:02
(89/1443): xkill-1.0.5-5.fc37.x86_64.rpm 31 kB/s | 17 kB 00:00
(90/1443): xlsatoms-1.1.3-2.fc37.x86_64.rpm 25 kB/s | 15 kB 00:00
(91/1443): xlsclients-1.1.4-5.fc37.x86_64.rpm 25 kB/s | 19 kB 00:00
(92/1443): xlsfonts-1.0.7-2.fc37.x86_64.rpm 32 kB/s | 20 kB 00:00
(93/1443): xmodmap-1.0.11-2.fc37.x86_64.rpm 49 kB/s | 31 kB 00:00
(94/1443): xprop-1.2.5-2.fc37.x86_64.rpm 51 kB/s | 35 kB 00:00
(95/1443): xrandr-1.5.1-5.fc37.x86_64.rpm 78 kB/s | 45 kB 00:00
(96/1443): xrdb-1.2.1-4.fc37.x86_64.rpm 44 kB/s | 29 kB 00:00
(97/1443): xrefresh-1.0.7-2.fc37.x86_64.rpm 39 kB/s | 24 kB 00:00
(98/1443): xset-1.2.4-5.fc37.x86_64.rpm 46 kB/s | 28 kB 00:00
(99/1443): xsetroot-1.1.2-5.fc37.x86_64.rpm 32 kB/s | 19 kB 00:00
(100/1443): xstdcmap-1.0.4-7.fc37.x86_64.rpm 40 kB/s | 25 kB 00:00
(101/1443): xvinfo-1.1.4-2.fc37.x86_64.rpm 29 kB/s | 17 kB 00:00
(102/1443): xwininfo-1.1.5-5.fc37.x86_64.rpm 15 kB/s | 32 kB 00:02
(103/1443): NetworkManager-initscripts-ifcfg-rh-1.40.18-1.fc37.x86_64.rpm 43 kB/s | 122 kB 00:02
(104/1443): NetworkManager-initscripts-updown-1.40.18-1.fc37.noarch.rpm 1.5 kB/s | 14 kB 00:08
(105/1443): SDL2-2.26.3-1.fc37.x86_64.rpm 89 kB/s | 689 kB 00:07
(106/1443): SDL2_ttf-2.20.1-1.fc37.x86_64.rpm 5.8 kB/s | 43 kB 00:07
(107/1443): alsa-ucm-1.2.9-1.fc37.noarch.rpm 50 kB/s | 176 kB 00:03
(108/1443): appstream-0.16.1-1.fc37.x86_64.rpm 80 kB/s | 724 kB 00:09
[MIRROR] cpp-12.3.1-1.fc37.x86_64.rpm: Curl error (28): Timeout was reached for https://mirrors.xtom.de/fedora/updates/37/Everything/x86_64/Packages/c/cpp-12.3.1-1.fc37.x86_64.rpm [Operation too slow. Less than 1000 bytes/sec transferred the last 30 seconds]
[MIRROR] cxl-libs-78-1.fc37.x86_64.rpm: Curl error (28): Timeout was reached for https://mirrors.xtom.de/fedora/updates/37/Everything/x86_64/Packages/c/cxl-libs-78-1.fc37.x86_64.rpm [Operation too slow. Less than 1000 bytes/sec transferred the last 30 seconds]
(109/1443): cxl-libs-78-1.fc37.x86_64.rpm 1.5 kB/s | 58 kB 00:37
(110/1443): exiv2-0.27.6-4.fc37.x86_64.rpm 165 kB/s | 982 kB 00:05
(111/1443): exiv2-libs-0.27.6-4.fc37.x86_64.rpm 206 kB/s | 798 kB 00:03
(112/1443): flexiblas-3.3.1-5.fc37.x86_64.rpm 36 kB/s | 33 kB 00:00
(113/1443): flexiblas-atlas-3.3.1-5.fc37.x86_64.rpm 6.0 kB/s | 17 kB 00:02
(114/1443): appstream-data-37-9.fc37.noarch.rpm 203 kB/s | 13 MB 01:07
(115/1443): flexiblas-openblas-openmp-3.3.1-5.fc37.x86_64.rpm 9.8 kB/s | 17 kB 00:01
(116/1443): flexiblas-openblas-threads-3.3.1-5.fc37.x86_64.rpm 26 kB/s | 17 kB 00:00
(117/1443): gettext-envsubst-0.21.1-1.fc37.x86_64.rpm 27 kB/s | 36 kB 00:01
(118/1443): gettext-runtime-0.21.1-1.fc37.x86_64.rpm 21 kB/s | 117 kB 00:05
(119/1443): giflib-5.2.1-17.fc37.x86_64.rpm 20 kB/s | 51 kB 00:02
(120/1443): flexiblas-netlib-3.3.1-5.fc37.x86_64.rpm 146 kB/s | 3.1 MB 00:22
(121/1443): gjs-1.74.3-2.fc37.x86_64.rpm 125 kB/s | 505 kB 00:04
(122/1443): glibmm2.4-2.66.6-1.fc37.x86_64.rpm 161 kB/s | 682 kB 00:04
(123/1443): cpp-12.3.1-1.fc37.x86_64.rpm 127 kB/s | 11 MB 01:25
(124/1443): glibc-gconv-extra-2.36-18.fc37.x86_64.rpm 255 kB/s | 1.7 MB 00:06
(125/1443): google-noto-sans-vf-fonts-20201206^1.git0c78c8329-8.fc37.noarch.rpm 327 kB/s | 728 kB 00:02
(126/1443): gtksourceview4-4.8.4-1.fc37.x86_64.rpm 251 kB/s | 887 kB 00:03
(127/1443): highway-1.0.7-1.fc37.x86_64.rpm 97 kB/s | 499 kB 00:05
(128/1443): imath-3.1.9-1.fc37.x86_64.rpm 24 kB/s | 99 kB 00:04
(129/1443): inih-57-1.fc37.x86_64.rpm 12 kB/s | 27 kB 00:02
(130/1443): iniparser-4.1-11.fc37.x86_64.rpm 13 kB/s | 19 kB 00:01
(131/1443): initscripts-service-10.19-1.fc37.noarch.rpm 7.3 kB/s | 14 kB 00:01
(132/1443): initscripts-rename-device-10.19-1.fc37.x86_64.rpm 6.2 kB/s | 17 kB 00:02
(133/1443): iptables-compat-1.8.8-5.fc37.x86_64.rpm 7.6 kB/s | 8.1 kB 00:01
(134/1443): iptables-legacy-libs-1.8.8-5.fc37.x86_64.rpm 23 kB/s | 37 kB 00:01
(135/1443): iptables-legacy-1.8.8-5.fc37.x86_64.rpm 26 kB/s | 51 kB 00:01
(136/1443): iptables-utils-1.8.8-5.fc37.x86_64.rpm 12 kB/s | 40 kB 00:03
(137/1443): gtk4-4.8.3-1.fc37.x86_64.rpm 126 kB/s | 4.9 MB 00:39
(138/1443): jxl-pixbuf-loader-0.7.0-5.fc37.x86_64.rpm 56 kB/s | 56 kB 00:01
(139/1443): libaom-3.7.0-1.fc37.x86_64.rpm 151 kB/s | 1.8 MB 00:12
(140/1443): libatomic-12.3.1-1.fc37.x86_64.rpm 69 kB/s | 48 kB 00:00
(141/1443): libavif-0.11.1-4.fc37.x86_64.rpm 104 kB/s | 83 kB 00:00
(142/1443): libcue-2.2.1-13.fc37.x86_64.rpm 39 kB/s | 33 kB 00:00
(143/1443): libdav1d-1.2.1-1.fc37.x86_64.rpm 181 kB/s | 619 kB 00:03
(144/1443): libdecor-0.1.1-1.fc37.x86_64.rpm 31 kB/s | 42 kB 00:01
(145/1443): javascriptcoregtk4.1-2.42.2-1.fc37.x86_64.rpm 196 kB/s | 8.4 MB 00:43
(146/1443): libeconf-0.5.2-1.fc37.x86_64.rpm 41 kB/s | 30 kB 00:00
(147/1443): javascriptcoregtk4.0-2.42.2-1.fc37.x86_64.rpm 183 kB/s | 8.4 MB 00:46
(148/1443): libgfapi0-10.5-1.fc37.x86_64.rpm 132 kB/s | 91 kB 00:00
(149/1443): libgfchangelog0-10.5-1.fc37.x86_64.rpm 53 kB/s | 36 kB 00:00
(150/1443): libgfrpc0-10.5-1.fc37.x86_64.rpm
(151/1443): libglusterd0-10.5-1.fc37.x86_64.rpm 22 kB/s | 12 kB 00:00
(152/1443): libgfxdr0-10.5-1.fc37.x86_64.rpm 42 kB/s | 28 kB 00:00
(153/1443): libglusterfs0-10.5-1.fc37.x86_64.rpm 365 kB/s | 299 kB 00:00
(154/1443): libhandy-1.8.2-1.fc37.x86_64.rpm 372 kB/s | 410 kB 00:01
(155/1443): libosinfo-1.10.0-5.fc37.x86_64.rpm 269 kB/s | 321 kB 00:01
(156/1443): libjxl-0.7.0-5.fc37.x86_64.rpm 269 kB/s | 1.1 MB 00:04
(157/1443): libsoup3-3.2.2-3.fc37.x86_64.rpm 125 kB/s | 387 kB 00:03
(158/1443): libtraceevent-1.7.2-1.fc37.x86_64.rpm 101 kB/s | 270 kB 00:02
(159/1443): liburing-2.3-1.fc37.x86_64.rpm 8.3 kB/s | 26 kB 00:03
(160/1443): libva-2.16.0-1.fc37.x86_64.rpm 28 kB/s | 105 kB 00:03
(161/1443): libtracker-sparql-3.4.2-1.fc37.x86_64.rpm 65 kB/s | 358 kB 00:05
(162/1443): libxmlb-0.3.11-1.fc37.x86_64.rpm 51 kB/s | 116 kB 00:02
(163/1443): libzstd-devel-1.5.5-1.fc37.x86_64.rpm 28 kB/s | 51 kB 00:01
(164/1443): ntfs-3g-libs-2022.10.3-1.fc37.x86_64.rpm 98 kB/s | 175 kB 00:01
(165/1443): openexr-libs-3.1.10-1.fc37.x86_64.rpm 125 kB/s | 1.1 MB 00:09
(166/1443): openssh-clients-8.8p1-11.fc37.x86_64.rpm 117 kB/s | 696 kB 00:05
(167/1443): mesa-va-drivers-23.0.3-1.fc37.x86_64.rpm 162 kB/s | 3.4 MB 00:21
(168/1443): osinfo-db-20231027-1.fc37.noarch.rpm 100 kB/s | 433 kB 00:04
(169/1443): perl-AutoLoader-5.74-494.fc37.noarch.rpm 20 kB/s | 22 kB 00:01
(170/1443): osinfo-db-tools-1.10.0-6.fc37.x86_64.rpm 61 kB/s | 76 kB 00:01
(171/1443): mozjs102-102.15.1-1.fc37.x86_64.rpm 200 kB/s | 4.5 MB 00:23
(172/1443): perl-B-1.83-494.fc37.x86_64.rpm 133 kB/s | 182 kB 00:01
(173/1443): perl-Class-Struct-0.66-494.fc37.noarch.rpm 18 kB/s | 23 kB 00:01
(174/1443): perl-DynaLoader-1.52-494.fc37.x86_64.rpm 27 kB/s | 27 kB 00:01
(175/1443): perl-Fcntl-1.15-494.fc37.x86_64.rpm 46 kB/s | 21 kB 00:00
(176/1443): perl-File-Basename-2.85-494.fc37.noarch.rpm 32 kB/s | 18 kB 00:00
(177/1443): perl-File-stat-1.12-494.fc37.noarch.rpm 7.0 kB/s | 18 kB 00:02
(178/1443): perl-FileHandle-2.03-494.fc37.noarch.rpm 4.7 kB/s | 16 kB 00:03
(179/1443): perl-Getopt-Std-1.13-494.fc37.noarch.rpm 4.8 kB/s | 17 kB 00:03
(180/1443): perl-IPC-Open3-1.22-494.fc37.noarch.rpm 16 kB/s | 24 kB 00:01
(181/1443): perl-NDBM_File-1.15-494.fc37.x86_64.rpm 23 kB/s | 23 kB 00:00
(182/1443): perl-SelectSaver-1.02-494.fc37.noarch.rpm 11 kB/s | 13 kB 00:01
(183/1443): perl-POSIX-2.03-494.fc37.x86_64.rpm 43 kB/s | 98 kB 00:02
(184/1443): perl-Symbol-1.09-494.fc37.noarch.rpm 11 kB/s | 15 kB 00:01
(185/1443): perl-base-2.27-494.fc37.noarch.rpm 12 kB/s | 17 kB 00:01
(186/1443): perl-if-0.61.000-494.fc37.noarch.rpm 27 kB/s | 15 kB 00:00
(187/1443): perl-lib-0.65-494.fc37.x86_64.rpm 21 kB/s | 16 kB 00:00
(188/1443): perl-locale-1.10-494.fc37.noarch.rpm 26 kB/s | 15 kB 00:00
(189/1443): perl-mro-1.26-494.fc37.x86_64.rpm 47 kB/s | 30 kB 00:00
(190/1443): perl-overload-1.35-494.fc37.noarch.rpm 62 kB/s | 47 kB 00:00
(191/1443): perl-overloading-0.02-494.fc37.noarch.rpm 17 kB/s | 14 kB 00:00
(192/1443): perl-subs-1.04-494.fc37.noarch.rpm 25 kB/s | 13 kB 00:00
(193/1443): perl-vars-1.05-494.fc37.noarch.rpm 25 kB/s | 14 kB 00:00
(194/1443): pipewire-jack-audio-connection-kit-0.3.84-1.fc37.x86_64.rpm 26 kB/s | 15 kB 00:00
(195/1443): pipewire-alsa-0.3.84-1.fc37.x86_64.rpm 58 kB/s | 63 kB 00:01
(196/1443): pipewire-jack-audio-connection-kit-libs-0.3.84-1.fc37.x86_64.rpm 101 kB/s | 141 kB 00:01
(197/1443): plocate-1.1.17-1.fc37.x86_64.rpm 111 kB/s | 165 kB 00:01
(198/1443): poppler-glib-22.08.0-5.fc37.x86_64.rpm 96 kB/s | 174 kB 00:01
(199/1443): python3-looseversion-1.2.0-1.fc37.noarch.rpm 15 kB/s | 19 kB 00:01
(200/1443): python3-urllib3+socks-1.26.18-1.fc37.noarch.rpm 2.1 kB/s | 9.6 kB 00:04
(201/1443): poppler-22.08.0-5.fc37.x86_64.rpm 137 kB/s | 1.2 MB 00:08
(202/1443): rit-meera-new-fonts-1.5.2-1.fc37.noarch.rpm 60 kB/s | 150 kB 00:02
(203/1443): rav1e-libs-0.6.6-3.fc37.x86_64.rpm 133 kB/s | 1.0 MB 00:08
(204/1443): sdl12-compat-1.2.68-1.fc37.x86_64.rpm 82 kB/s | 91 kB 00:01
(205/1443): rit-rachana-fonts-1.4.6-1.fc37.noarch.rpm 141 kB/s | 982 kB 00:06
(206/1443): systemd-boot-unsigned-251.19-1.fc37.x86_64.rpm 48 kB/s | 97 kB 00:02
(207/1443): systemd-networkd-251.19-1.fc37.x86_64.rpm 196 kB/s | 610 kB 00:03
(208/1443): systemd-resolved-251.19-1.fc37.x86_64.rpm 143 kB/s | 275 kB 00:01
(209/1443): tpm2-tss-3.2.2-1.fc37.x86_64.rpm 80 kB/s | 603 kB 00:07
(210/1443): tpm2-tools-5.4-1.fc37.x86_64.rpm 98 kB/s | 799 kB 00:08
(211/1443): tracker-3.4.2-1.fc37.x86_64.rpm 173 kB/s | 573 kB 00:03
(212/1443): unbound-anchor-1.18.0-1.fc37.x86_64.rpm 42 kB/s | 35 kB 00:00
(213/1443): tracker-miners-3.4.6-1.fc37.x86_64.rpm 226 kB/s | 945 kB 00:04
(214/1443): vim-data-9.0.2120-1.fc37.noarch.rpm 17 kB/s | 23 kB 00:01
(215/1443): vl-gothic-fonts-20220612-2.fc37.noarch.rpm 114 kB/s | 2.1 MB 00:19
(216/1443): python2.7-2.7.18-35.fc37.x86_64.rpm 190 kB/s | 13 MB 01:12
(217/1443): wireplumber-0.4.14-1.fc37.x86_64.rpm 48 kB/s | 96 kB 00:01
(218/1443): wireplumber-libs-0.4.14-1.fc37.x86_64.rpm 113 kB/s | 355 kB 00:03
(219/1443): xxd-9.0.2120-1.fc37.x86_64.rpm 23 kB/s | 36 kB 00:01
(220/1443): xxhash-libs-0.8.2-1.fc37.x86_64.rpm 37 kB/s | 39 kB 00:01
(221/1443): qubes-desktop-linux-menu-1.2.0-1.fc37.noarch.rpm 11 kB/s | 108 kB 00:10
(222/1443): qubes-utils-selinux-4.2.15-1.fc37.x86_64.rpm 15 kB/s | 24 kB 00:01
(223/1443): xscreensaver-gl-base-6.08-1.fc37.x86_64.rpm 10 kB/s | 16 kB 00:01
(224/1443): kernel-6.6.31-1.qubes.fc37.x86_64.rpm 130 kB/s | 12 MB 01:34
(225/1443): webkit2gtk4.0-2.42.2-1.fc37.x86_64.rpm 146 kB/s | 24 MB 02:47
(226/1443): webkit2gtk4.1-2.42.2-1.fc37.x86_64.rpm 142 kB/s | 24 MB 02:52
(227/1443): kernel-devel-6.6.31-1.qubes.fc37.x86_64.rpm 158 kB/s | 14 MB 01:31
(228/1443): 3isec-qubes-cacher-1.15-2.fc37.x86_64.rpm 11 kB/s | 30 kB 00:02
(229/1443): 3isec-qubes-task-manager-0.2-2.x86_64.rpm 36 kB/s | 25 kB 00:00
[MIRROR] GConf2-3.2.6-36.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for http://ftp.halifax.rwth-aachen.de/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/GConf2-3.2.6-36.fc37.x86_64.rpm [Could not resolve host: ftp.halifax.rwth-aachen.de]
[MIRROR] GConf2-3.2.6-36.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for https://ftp.halifax.rwth-aachen.de/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/GConf2-3.2.6-36.fc37.x86_64.rpm [Could not resolve host: ftp.halifax.rwth-aachen.de]
(230/1443): GConf2-3.2.6-36.fc37.x86_64.rpm 103 kB/s | 977 kB 00:09
[MIRROR] Thunar-4.16.11-2.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for http://ftp.halifax.rwth-aachen.de/fedora/linux/releases/37/Everything/x86_64/os/Packages/t/Thunar-4.16.11-2.fc37.x86_64.rpm [Could not resolve host: ftp.halifax.rwth-aachen.de]
[MIRROR] Thunar-4.16.11-2.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for https://ftp.halifax.rwth-aachen.de/fedora/linux/releases/37/Everything/x86_64/os/Packages/t/Thunar-4.16.11-2.fc37.x86_64.rpm [Could not resolve host: ftp.halifax.rwth-aachen.de]
(231/1443): kernel-qubes-vm-6.6.31-1.qubes.fc37.x86_64.rpm 260 kB/s | 18 MB 01:10
[MIRROR] abattis-cantarell-fonts-0.301-8.fc37.noarch.rpm: Curl error (6): Couldn’t resolve host name for https://ftp.halifax.rwth-aachen.de/fedora/linux/releases/37/Everything/x86_64/os/Packages/a/abattis-cantarell-fonts-0.301-8.fc37.noarch.rpm [Could not resolve host: ftp.halifax.rwth-aachen.de ]
[MIRROR] abattis-cantarell-fonts-0.301-8.fc37.noarch.rpm: Curl error (6): Couldn’t resolve host name for http://ftp.halifax.rwth-aachen.de/fedora/linux/releases/37/Everything/x86_64/os/Packages/a/abattis-cantarell-fonts-0.301-8.fc37.noarch.rpm [Could not resolve host: ftp.halifax.rwth-aachen.de]
(232/1443): abattis-cantarell-fonts-0.301-8.fc37.noarch.rpm 43 kB/s | 270 kB 00:06
(233/1443): Thunar-4.16.11-2.fc37.x86_64.rpm 184 kB/s | 1.5 MB 00:08
[MIRROR] accountsservice-22.08.8-2.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for http://ftp.halifax.rwth-aachen.de/fedora/linux/releases/37/Everything/x86_64/os/Packages/a/accountsservice-22.08.8-2.fc37.x86_64.rpm [Could not resolve host: ftp.halifax.rwth-aachen.de]
[MIRROR] acl-2.3.1-4.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for http://ftp.halifax.rwth-aachen.de/fedora/linux/releases/37/Everything/x86_64/os/Packages/a/acl-2.3.1-4.fc37.x86_64.rpm [Could not resolve host: ftp.halifax.rwth-aachen.de]
(234/1443): acl-2.3.1-4.fc37.x86_64.rpm 12 kB/s | 71 kB 00:06
(235/1443): accountsservice-22.08.8-2.fc37.x86_64.rpm 16 kB/s | 127 kB 00:07
(236/1443): adobe-mappings-pdf-20190401-2.fc37.noarch.rpm 113 kB/s | 697 kB 00:06
(237/1443): kernel-modules-6.6.31-1.qubes.fc37.x86_64.rpm 314 kB/s | 72 MB 03:55
(238/1443): adwaita-cursor-theme-43-1.fc37.noarch.rpm 113 kB/s | 633 kB 00:05
(239/1443): adwaita-gtk2-theme-3.28-15.fc37.x86_64.rpm 76 kB/s | 193 kB 00:02
(240/1443): adwaita-icon-theme-43-1.fc37.noarch.rpm 111 kB/s | 4.9 MB 00:45
(241/1443): albatross-gtk2-theme-1.7.4-13.fc37.noarch.rpm 16 kB/s | 25 kB 00:01
(242/1443): albatross-gtk3-theme-1.7.4-13.fc37.noarch.rpm 15 kB/s | 52 kB 00:03
(243/1443): albatross-xfwm4-theme-1.7.4-13.fc37.noarch.rpm 53 kB/s | 72 kB 00:01
(244/1443): anaconda-user-help-26.2-3.fc37.noarch.rpm 75 kB/s | 308 kB 00:04
(245/1443): at-3.2.5-4.fc37.x86_64.rpm 12 kB/s | 62 kB 00:05
(246/1443): adobe-source-han-sans-tw-fonts-2.004-3.fc37.noarch.rpm 153 kB/s | 29 MB 03:13
(247/1443): at-spi2-atk-2.38.0-5.fc37.x86_64.rpm 31 kB/s | 85 kB 00:02
(248/1443): at-spi2-core-2.44.1-2.fc37.x86_64.rpm 36 kB/s | 192 kB 00:05
(249/1443): atk-2.38.0-2.fc37.x86_64.rpm 41 kB/s | 289 kB 00:07
(250/1443): atkmm-2.28.3-1.fc37.x86_64.rpm 19 kB/s | 94 kB 00:04
(251/1443): attr-2.5.1-5.fc37.x86_64.rpm 8.9 kB/s | 62 kB 00:07
(252/1443): augeas-libs-1.13.0-3.fc37.x86_64.rpm 35 kB/s | 444 kB 00:12
(253/1443): autogen-libopts-5.18.16-11.fc37.x86_64.rpm 19 kB/s | 74 kB 00:03
(254/1443): basesystem-11-14.fc37.noarch.rpm 2.6 kB/s | 7.0 kB 00:02
(255/1443): bc-1.07.1-16.fc37.x86_64.rpm 26 kB/s | 118 kB 00:04
(256/1443): bcache-tools-1.1-3.fc37.x86_64.rpm 14 kB/s | 57 kB 00:04
(257/1443): bluebird-gtk2-theme-1.3-9.fc37.noarch.rpm 7.1 kB/s | 53 kB 00:07
(258/1443): bluebird-gtk3-theme-1.3-9.fc37.noarch.rpm 38 kB/s | 111 kB 00:02
(259/1443): bluebird-xfwm4-theme-1.3-9.fc37.noarch.rpm 19 kB/s | 47 kB 00:02
(260/1443): bridge-utils-1.7.1-5.fc37.x86_64.rpm 16 kB/s | 35 kB 00:02
(261/1443): bubblewrap-0.5.0-3.fc37.x86_64.rpm 31 kB/s | 54 kB 00:01
(262/1443): bzip2-1.0.8-12.fc37.x86_64.rpm 36 kB/s | 52 kB 00:01
(263/1443): bzip2-libs-1.0.8-12.fc37.x86_64.rpm 27 kB/s | 41 kB 00:01
(264/1443): cairo-1.17.6-2.fc37.x86_64.rpm 106 kB/s | 676 kB 00:06
(265/1443): cairo-gobject-1.17.6-2.fc37.x86_64.rpm 9.6 kB/s | 18 kB 00:01
(266/1443): cdparanoia-libs-10.2-40.fc37.x86_64.rpm 12 kB/s | 54 kB 00:04
(267/1443): atlas-3.10.3-20.fc37.x86_64.rpm 88 kB/s | 6.5 MB 01:15
(268/1443): colord-libs-1.4.6-2.fc37.x86_64.rpm 34 kB/s | 233 kB 00:06
(269/1443): comps-extras-24-12.fc37.noarch.rpm 65 kB/s | 83 kB 00:01
(270/1443): compat-readline5-5.2-42.fc37.x86_64.rpm 93 kB/s | 138 kB 00:01
(271/1443): cpio-2.13-13.fc37.x86_64.rpm 88 kB/s | 277 kB 00:03
(272/1443): cracklib-2.9.7-30.fc37.x86_64.rpm 29 kB/s | 92 kB 00:03
(273/1443): adobe-source-han-sans-cn-fonts-2.004-3.fc37.noarch.rpm 149 kB/s | 42 MB 04:48
(274/1443): cronie-1.6.1-3.fc37.x86_64.rpm 65 kB/s | 116 kB 00:01
(275/1443): cronie-anacron-1.6.1-3.fc37.x86_64.rpm 31 kB/s | 32 kB 00:01
(276/1443): crontabs-1.11-28.20190603git.fc37.noarch.rpm 17 kB/s | 18 kB 00:01
(277/1443): crypto-policies-20220815-1.gite4ed860.fc37.noarch.rpm 47 kB/s | 86 kB 00:01
(278/1443): crypto-policies-scripts-20220815-1.gite4ed860.fc37.noarch.rpm 60 kB/s | 110 kB 00:01
(279/1443): cyrus-sasl-2.1.28-8.fc37.x86_64.rpm 64 kB/s | 73 kB 00:01
(280/1443): cyrus-sasl-gssapi-2.1.28-8.fc37.x86_64.rpm 24 kB/s | 26 kB 00:01
(281/1443): cyrus-sasl-md5-2.1.28-8.fc37.x86_64.rpm 45 kB/s | 43 kB 00:00
(282/1443): cracklib-dicts-2.9.7-30.fc37.x86_64.rpm 440 kB/s | 3.6 MB 00:08
(283/1443): dbus-glib-0.112-4.fc37.x86_64.rpm 29 kB/s | 124 kB 00:04
(284/1443): cyrus-sasl-lib-2.1.28-8.fc37.x86_64.rpm 145 kB/s | 792 kB 00:05
(285/1443): dbusmenu-qt-0.9.3-0.29.20160218.fc37.x86_64.rpm 29 kB/s | 80 kB 00:02
(286/1443): dconf-0.40.0-7.fc37.x86_64.rpm 110 kB/s | 109 kB 00:00
(287/1443): dejavu-sans-mono-fonts-2.37-19.fc37.noarch.rpm 112 kB/s | 469 kB 00:04
(288/1443): deltarpm-3.6.3-4.fc37.x86_64.rpm 8.0 kB/s | 89 kB 00:11
(289/1443): dejavu-sans-fonts-2.37-19.fc37.noarch.rpm 87 kB/s | 1.3 MB 00:15
(290/1443): dejavu-serif-fonts-2.37-19.fc37.noarch.rpm 70 kB/s | 1.0 MB 00:14
(291/1443): desktop-file-utils-0.26-7.fc37.x86_64.rpm 17 kB/s | 72 kB 00:04
(292/1443): dhcp-common-4.4.3-4.P1.fc37.noarch.rpm 54 kB/s | 127 kB 00:02
(293/1443): dhcp-client-4.4.3-4.P1.fc37.x86_64.rpm 117 kB/s | 806 kB 00:06
(294/1443): device-mapper-persistent-data-0.9.0-8.fc37.x86_64.rpm 103 kB/s | 781 kB 00:07
(295/1443): diffutils-3.8-3.fc37.x86_64.rpm 174 kB/s | 378 kB 00:02
(296/1443): dmidecode-3.4-2.fc37.x86_64.rpm 53 kB/s | 91 kB 00:01
(297/1443): dmraid-1.0.0.rc16-53.fc37.x86_64.rpm 35 kB/s | 39 kB 00:01
(298/1443): dmraid-events-1.0.0.rc16-53.fc37.x86_64.rpm 29 kB/s | 15 kB 00:00
(299/1443): dnfdaemon-0.3.20-10.fc37.noarch.rpm 148 kB/s | 79 kB 00:00
(300/1443): dnfdaemon-selinux-0.3.20-10.fc37.noarch.rpm
(306/1443): enchant-1.6.0-31.fc37.x86_64.rpm 28 kB/s | 60 kB 00:02
(307/1443): exo-4.16.4-2.fc37.x86_64.rpm 156 kB/s | 465 kB 00:02
(308/1443): fdk-aac-free-2.0.0-9.fc37.x86_64.rpm 97 kB/s | 332 kB 00:03
(309/1443): file-5.42-4.fc37.x86_64.rpm 19 kB/s | 49 kB 00:02
(310/1443): fftw-libs-double-3.3.10-3.fc37.x86_64.rpm 149 kB/s | 918 kB 00:06
(311/1443): file-libs-5.42-4.fc37.x86_64.rpm 45 kB/s | 676 kB 00:14
(312/1443): findutils-4.9.0-2.fc37.x86_64.rpm 35 kB/s | 492 kB 00:13
(313/1443): fonts-filesystem-2.0.5-9.fc37.noarch.rpm 2.9 kB/s | 7.9 kB 00:02
(314/1443): fribidi-1.0.12-2.fc37.x86_64.rpm 40 kB/s | 89 kB 00:02
(315/1443): filesystem-3.18-2.fc37.x86_64.rpm 56 kB/s | 1.1 MB 00:19
(316/1443): freetype-2.12.1-3.fc37.x86_64.rpm 97 kB/s | 407 kB 00:04
(317/1443): fros-1.1-30.fc37.noarch.rpm 32 kB/s | 35 kB 00:01
(318/1443): fuse-2.9.9-15.fc37.x86_64.rpm 73 kB/s | 79 kB 00:01
(319/1443): fuse-common-3.10.5-5.fc37.x86_64.rpm 15 kB/s | 8.2 kB 00:00
(320/1443): fuse-libs-2.9.9-15.fc37.x86_64.rpm 125 kB/s | 97 kB 00:00
(321/1443): garcon-4.16.1-6.fc37.x86_64.rpm 86 kB/s | 244 kB 00:02
(322/1443): gc-8.0.6-4.fc37.x86_64.rpm 49 kB/s | 103 kB 00:02
(323/1443): gconfmm26-2.28.3-62.fc37.x86_64.rpm 25 kB/s | 42 kB 00:01
(324/1443): gcr-3.92.0-1.fc37.x86_64.rpm 33 kB/s | 54 kB 00:01
(325/1443): gawk-5.1.1-4.fc37.x86_64.rpm 188 kB/s | 1.0 MB 00:05
(326/1443): gdbm-libs-1.23-2.fc37.x86_64.rpm 31 kB/s | 56 kB 00:01
(327/1443): gdbm-1.23-2.fc37.x86_64.rpm 63 kB/s | 154 kB 00:02
(328/1443): gdisk-1.0.9-4.fc37.x86_64.rpm 94 kB/s | 250 kB 00:02
(329/1443): gdk-pixbuf2-modules-2.42.10-1.fc37.x86_64.rpm 36 kB/s | 85 kB 00:02
(330/1443): gdk-pixbuf2-2.42.10-1.fc37.x86_64.rpm 150 kB/s | 485 kB 00:03
(331/1443): gdk-pixbuf2-xlib-2.40.2-5.fc37.x86_64.rpm 60 kB/s | 57 kB 00:00
(332/1443): geoclue2-2.6.0-3.fc37.x86_64.rpm 32 kB/s | 144 kB 00:04
(333/1443): gentoo-0.20.7-16.fc37.x86_64.rpm 75 kB/s | 656 kB 00:08
(334/1443): glade-libs-3.40.0-1.fc37.x86_64.rpm 124 kB/s | 784 kB 00:06
(335/1443): glib-networking-2.74.0-1.fc37.x86_64.rpm 85 kB/s | 200 kB 00:02
(336/1443): glx-utils-8.4.0-14.20210504git0f9e7d9.fc37.x86_64.rpm 26 kB/s | 41 kB 00:01
(337/1443): geolite2-country-20191217-7.fc37.noarch.rpm 107 kB/s | 1.6 MB 00:15
(338/1443): gmp-6.2.1-3.fc37.x86_64.rpm 75 kB/s | 315 kB 00:04
(339/1443): gnome-packagekit-3.32.0-10.fc37.x86_64.rpm 3.2 kB/s | 7.2 kB 00:02
(340/1443): gnome-packagekit-common-3.32.0-10.fc37.x86_64.rpm 64 kB/s | 1.0 MB 00:16
(341/1443): gnome-packagekit-installer-3.32.0-10.fc37.x86_64.rpm 48 kB/s | 86 kB 00:01
(342/1443): gnome-packagekit-updater-3.32.0-10.fc37.x86_64.rpm 30 kB/s | 79 kB 00:02
(343/1443): gnome-themes-extra-3.28-15.fc37.x86_64.rpm 29 kB/s | 26 kB 00:00
(344/1443): gnu-free-fonts-common-20120503-27.fc37.noarch.rpm 46 kB/s | 122 kB 00:02
(345/1443): gnu-free-mono-fonts-20120503-27.fc37.noarch.rpm 72 kB/s | 691 kB 00:09
(346/1443): gnu-free-sans-fonts-20120503-27.fc37.noarch.rpm 72 kB/s | 1.3 MB 00:18
(347/1443): gnu-free-serif-fonts-20120503-27.fc37.noarch.rpm 118 kB/s | 2.5 MB 00:21
(348/1443): gobject-introspection-1.74.0-1.fc37.x86_64.rpm 40 kB/s | 259 kB 00:06
(349/1443): gnome-icon-theme-3.12.0-18.fc37.noarch.rpm 100 kB/s | 9.9 MB 01:42
(350/1443): google-droid-sans-fonts-20200215-13.fc37.noarch.rpm 129 kB/s | 2.7 MB 00:21
(351/1443): gpgme-1.17.0-4.fc37.x86_64.rpm 40 kB/s | 210 kB 00:05
(352/1443): gpm-libs-1.20.7-41.fc37.x86_64.rpm 2.2 kB/s | 20 kB 00:09
(353/1443): graphene-1.10.6-4.fc37.x86_64.rpm 6.2 kB/s | 62 kB 00:09
(354/1443): graphite2-1.3.14-10.fc37.x86_64.rpm 13 kB/s | 95 kB 00:07
(355/1443): grep-3.7-4.fc37.x86_64.rpm 43 kB/s | 273 kB 00:06
(356/1443): greybird-dark-theme-3.23.1-3.fc37.noarch.rpm 33 kB/s | 150 kB 00:04
(357/1443): greybird-light-theme-3.23.1-3.fc37.noarch.rpm 30 kB/s | 178 kB 00:06
(358/1443): greybird-xfwm4-theme-3.23.1-3.fc37.noarch.rpm 39 kB/s | 219 kB 00:05
(359/1443): groff-base-1.22.4-10.fc37.x86_64.rpm 94 kB/s | 1.1 MB 00:11
(360/1443): grubby-8.40-66.fc37.x86_64.rpm 15 kB/s | 33 kB 00:02
(361/1443): gsettings-desktop-schemas-43.0-1.fc37.x86_64.rpm 64 kB/s | 732 kB 00:11
(362/1443): gsm-1.0.22-1.fc37.x86_64.rpm 3.7 kB/s | 35 kB 00:09
(363/1443): gssproxy-0.9.1-4.fc37.x86_64.rpm 15 kB/s | 114 kB 00:07
(364/1443): gtk-murrine-engine-0.98.2-24.fc37.x86_64.rpm 58 kB/s | 141 kB 00:02
(365/1443): graphviz-5.0.0-4.fc37.x86_64.rpm 67 kB/s | 5.0 MB 01:16
(366/1443): gtk-unico-engine-1.0.3-0.20.20140109bzr152.fc37.x86_64.rpm 11 kB/s | 25 kB 00:02
(367/1443): geolite2-city-20191217-7.fc37.noarch.rpm 97 kB/s | 23 MB 03:58
(368/1443): gtk-xfce-engine-3.2.0-16.fc37.x86_64.rpm 4.0 kB/s | 102 kB 00:25
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for http://mirror.23m.com/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: mirror.23m.com]
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for http://ftp.halifax.rwth-aachen.de/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: ftp.halifax.rwth-aachen.de]
(369/1443): gts-0.7.6-42.20121130.fc37.x86_64.rpm 45 kB/s | 241 kB 00:05
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for https://ftp.halifax.rwth-aachen.de/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: ftp.halifax.rwth-aachen.de]
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for https://mirror.23m.com/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: mirror.23m.com]
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for https://mirrors.xtom.de/fedora/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: mirrors.xtom.de]
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for http://mirrors.xtom.de/fedora/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: mirrors.xtom.de]
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for http://mirror.dogado.de/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: mirror.dogado.de]
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for https://mirror.dogado.de/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: mirror.dogado.de]
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for http://ftp.uni-bayreuth.de/linux/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: ftp.uni-bayreuth.de]
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for http://fedora.tu-chemnitz.de/pub/linux/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: fedora.tu-chemnitz.de]
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for http://mirror.de.leaseweb.net/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: mirror.de.leaseweb.net]
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for https://ftp-stud.hs-esslingen.de/pub/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: ftp-stud.hs-esslingen.de]
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for http://ftp-stud.hs-esslingen.de/pub/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: ftp-stud.hs-esslingen.de]
(370/1443): gtk2-2.24.33-10.fc37.x86_64.rpm 70 kB/s | 3.5 MB 00:51
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for http://ftp.fau.de/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: ftp.fau.de]
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for https://ftp.fau.de/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: ftp.fau.de]
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for https://ftp.plusline.net/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: ftp.plusline.net]
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for http://ftp.plusline.net/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: ftp.plusline.net]
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for https://level66.mm.fcix.net/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: level66.mm.fcix.net]
(371/1443): guile-2.0.14-29.fc37.x86_64.rpm 130 kB/s | 3.5 MB 00:27
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for http://level66.mm.fcix.net/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: level66.mm.fcix.net]
(372/1443): gupnp-igd-1.2.0-6.fc37.x86_64.rpm 22 kB/s | 34 kB 00:01
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for http://mirror.netzwerge.de/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: mirror.netzwerge.de]
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for https://mirror.netzwerge.de/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: mirror.netzwerge.de]
(373/1443): gzip-1.12-2.fc37.x86_64.rpm 81 kB/s | 166 kB 00:02
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for http://mirror.bahnhof.net/pub/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: mirror.bahnhof.net]
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for https://mirror.bahnhof.net/pub/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: mirror.bahnhof.net]
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for https://mirrors.xtom.ee/fedora/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: mirrors.xtom.ee]
(374/1443): harfbuzz-5.2.0-1.fc37.x86_64.rpm 113 kB/s | 801 kB 00:07
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for http://mirrors.xtom.ee/fedora/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: mirrors.xtom.ee]
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for http://www.nic.funet.fi/pub/mirrors/fedora.redhat.com/pub/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: www.nic.funet.fi]
(375/1443): harfbuzz-icu-5.2.0-1.fc37.x86_64.rpm 3.8 kB/s | 16 kB 00:04
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for http://mirror.it4i.cz/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: mirror.it4i.cz]
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for https://mirror.it4i.cz/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: mirror.it4i.cz]
(376/1443): hddtemp-0.3-0.51.beta15.fc37.x86_64.rpm 24 kB/s | 63 kB 00:02
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for http://mirror.accum.se/mirror/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: mirror.accum.se]
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for https://mirror.accum.se/mirror/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: mirror.accum.se]
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for http://mirror.vpsnet.com/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: mirror.vpsnet.com]
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for https://mirror.vpsnet.com/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: mirror.vpsnet.com]
(377/1443): hfsplus-tools-540.1.linux3-27.fc37.x86_64.rpm 32 kB/s | 163 kB 00:05
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for https://fedora.ip-connect.vn.ua/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: fedora.ip-connect.vn.ua]
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for http://fedora.ip-connect.vn.ua/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: fedora.ip-connect.vn.ua]
(378/1443): hicolor-icon-theme-0.17-14.fc37.noarch.rpm 24 kB/s | 66 kB 00:02
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for https://mirror.netsite.dk/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: mirror.netsite.dk]
(379/1443): hostname-3.23-7.fc37.x86_64.rpm 14 kB/s | 27 kB 00:01
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for http://mirror.netsite.dk/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: mirror.netsite.dk]
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for http://mirror.yandex.ru/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: mirror.yandex.ru]
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for https://mirror.yandex.ru/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: mirror.yandex.ru]
(380/1443): hunspell-1.7.0-21.fc37.x86_64.rpm 73 kB/s | 281 kB 00:03
(381/1443): guile22-2.2.7-6.fc37.x86_64.rpm 176 kB/s | 6.5 MB 00:37
(382/1443): hunspell-en-US-0.20140811.1-23.fc37.noarch.rpm 117 kB/s | 176 kB 00:01
(383/1443): hyphen-2.8.8-18.fc37.x86_64.rpm 27 kB/s | 29 kB 00:01
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for https://mirror.init7.net/fedora/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: mirror.init7.net]
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for http://mirror.init7.net/fedora/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: mirror.init7.net]
(384/1443): ima-evm-utils-1.4-6.fc37.x86_64.rpm 45 kB/s | 63 kB 00:01
(385/1443): ilmbase-2.3.0-9.fc37.x86_64.rpm 62 kB/s | 133 kB 00:02
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for http://ftp.fi.muni.cz/pub/linux/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: ftp.fi.muni.cz]
(386/1443): info-6.8-4.fc37.x86_64.rpm 88 kB/s | 225 kB 00:02
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for http://fedora.ipacct.com/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: fedora.ipacct.com]
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for https://fedora.ipacct.com/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: fedora.ipacct.com]
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for https://ask4.mm.fcix.net/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: ask4.mm.fcix.net]
(387/1443): iproute-5.18.0-2.fc37.x86_64.rpm 86 kB/s | 768 kB 00:08
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for http://ask4.mm.fcix.net/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: ask4.mm.fcix.net]
(388/1443): iproute-tc-5.18.0-2.fc37.x86_64.rpm 61 kB/s | 466 kB 00:07
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for http://mirror.nl.leaseweb.net/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: mirror.nl.leaseweb.net]
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for https://ftp.icm.edu.pl/pub/Linux/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: ftp.icm.edu.pl]
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for http://ftp.icm.edu.pl/pub/Linux/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: ftp.icm.edu.pl]
(389/1443): iscsi-initiator-utils-6.2.1.4-6.git2a8f9d8.fc37.x86_64.rpm 62 kB/s | 387 kB 00:06
(390/1443): iscsi-initiator-utils-iscsiuio-6.2.1.4-6.git2a8f9d8.fc37.x86_64.rpm 16 kB/s | 94 kB 00:05
(391/1443): isns-utils-libs-0.101-5.fc37.x86_64.rpm 110 kB/s | 105 kB 00:00
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for http://mirror.ihost.md/fedora/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: mirror.ihost.md]
(392/1443): isomd5sum-1.2.3-17.fc37.x86_64.rpm 26 kB/s | 30 kB 00:01
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for https://mirror.ihost.md/fedora/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: mirror.ihost.md]
(393/1443): jansson-2.13.1-5.fc37.x86_64.rpm 28 kB/s | 44 kB 00:01
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for https://mirror.karneval.cz/pub/linux/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: mirror.karneval.cz]
(394/1443): jasper-libs-3.0.6-1.fc37.x86_64.rpm 99 kB/s | 162 kB 00:01
(395/1443): jbig2dec-libs-0.19-7.fc37.x86_64.rpm 51 kB/s | 73 kB 00:01
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for http://fedora.ip-connect.info/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: fedora.ip-connect.info]
(396/1443): jbigkit-libs-2.1-24.fc37.x86_64.rpm 49 kB/s | 53 kB 00:01
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for https://fedora.ip-connect.info/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: fedora.ip-connect.info]
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for http://mirror.telepoint.bg/fedora/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: mirror.telepoint.bg]
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for https://mirror.telepoint.bg/fedora/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: mirror.telepoint.bg]
(397/1443): iso-codes-4.11.0-1.fc37.noarch.rpm 285 kB/s | 3.4 MB 00:12
(398/1443): jomolhari-fonts-0.003-36.fc37.noarch.rpm 120 kB/s | 528 kB 00:04
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for http://ftp.dei.uc.pt/pub/linux/fedora/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: ftp.dei.uc.pt]
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for http://mirroronet.pl/pub/mirrors/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: mirroronet.pl]
(399/1443): json-glib-1.6.6-3.fc37.x86_64.rpm 45 kB/s | 162 kB 00:03
(400/1443): js-jquery-3.6.0-3.fc37.noarch.rpm
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for https://mirrors.dotsrc.org/fedora-enchilada/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: mirrors.dotsrc.org]
(402/1443): julietaula-montserrat-fonts-7.222-3.fc37.noarch.rpm 170 kB/s | 1.6 MB 00:09
(403/1443): kbd-legacy-2.5.1-3.fc37.noarch.rpm 81 kB/s | 551 kB 00:06
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for http://ftp.nluug.nl/pub/os/Linux/distr/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: ftp.nluug.nl]
(404/1443): kde-filesystem-4-68.fc37.x86_64.rpm 17 kB/s | 47 kB 00:02
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for https://fedora.mirrorservice.org/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: fedora.mirrorservice.org]
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for http://fedora.mirrorservice.org/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: fedora.mirrorservice.org]
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for https://ftp.upjs.sk/pub/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: ftp.upjs.sk]
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for http://ftp.upjs.sk/pub/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: ftp.upjs.sk]
(405/1443): keybinder3-0.3.2-14.fc37.x86_64.rpm 5.0 kB/s | 20 kB 00:03
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for https://ftp.lysator.liu.se/pub/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: ftp.lysator.liu.se]
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for http://ftp.lysator.liu.se/pub/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: ftp.lysator.liu.se]
(406/1443): keyutils-1.6.1-5.fc37.x86_64.rpm 17 kB/s | 63 kB 00:03
(407/1443): kbd-misc-2.5.1-3.fc37.noarch.rpm 147 kB/s | 1.6 MB 00:11
(408/1443): keyutils-libs-1.6.1-5.fc37.x86_64.rpm 30 kB/s | 31 kB 00:01
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for http://ftp.tudelft.nl/download.fedora.redhat.com/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: ftp.tudelft.nl]
(409/1443): kmod-30-2.fc37.x86_64.rpm 95 kB/s | 120 kB 00:01
(410/1443): kmod-libs-30-2.fc37.x86_64.rpm 42 kB/s | 68 kB 00:01
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for http://creeperhost.mm.fcix.net/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: creeperhost.mm.fcix.net]
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for https://creeperhost.mm.fcix.net/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: creeperhost.mm.fcix.net]
(411/1443): lame-libs-3.100-13.fc37.x86_64.rpm 83 kB/s | 335 kB 00:04
(412/1443): langpacks-core-font-en-3.0-26.fc37.noarch.rpm 2.7 kB/s | 10 kB 00:03
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for http://fedora.mirror.wearetriple.com/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: fedora.mirror.wearetriple.com]
(413/1443): lasi-1.1.3-9.fc37.x86_64.rpm 58 kB/s | 54 kB 00:00
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for https://fedora.mirror.wearetriple.com/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: fedora.mirror.wearetriple.com]
(414/1443): libICE-1.0.10-9.fc37.x86_64.rpm 40 kB/s | 71 kB 00:01
(415/1443): libSM-1.2.3-11.fc37.x86_64.rpm 34 kB/s | 42 kB 00:01
(416/1443): libXScrnSaver-1.2.3-11.fc37.x86_64.rpm 28 kB/s | 24 kB 00:00
(417/1443): libXau-1.0.10-1.fc37.x86_64.rpm 33 kB/s | 31 kB 00:00
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for http://fedora-mirror02.rbc.ru/pub/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: fedora-mirror02.rbc.ru]
(418/1443): libXaw-1.0.14-3.fc37.x86_64.rpm 94 kB/s | 203 kB 00:02
(419/1443): libXcomposite-0.4.5-8.fc37.x86_64.rpm 13 kB/s | 23 kB 00:01
(420/1443): libXcursor-1.2.1-2.fc37.x86_64.rpm 37 kB/s | 30 kB 00:00
(421/1443): libXdamage-1.1.5-8.fc37.x86_64.rpm 23 kB/s | 22 kB 00:00
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for https://ipng.mm.fcix.net/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: ipng.mm.fcix.net]
(422/1443): libXdmcp-1.1.3-9.fc37.x86_64.rpm 38 kB/s | 35 kB 00:00
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for http://ipng.mm.fcix.net/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: ipng.mm.fcix.net]
(423/1443): libXext-1.3.4-9.fc37.x86_64.rpm 38 kB/s | 39 kB 00:01
(424/1443): libXfixes-6.0.0-4.fc37.x86_64.rpm 22 kB/s | 19 kB 00:00
(425/1443): libXfont-1.5.4-13.fc37.x86_64.rpm 107 kB/s | 150 kB 00:01
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for https://fr2.rpmfind.net/linux/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: fr2.rpmfind.net]
(426/1443): libXfont2-2.0.3-13.fc37.x86_64.rpm 48 kB/s | 143 kB 00:02
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for http://fr2.rpmfind.net/linux/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: fr2.rpmfind.net]
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for https://mirror.datacenter.by/pub/fedoraproject.org/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: mirror.datacenter.by]
(427/1443): libXi-1.8-3.fc37.x86_64.rpm 13 kB/s | 39 kB 00:02
(428/1443): libXft-2.3.4-3.fc37.x86_64.rpm 12 kB/s | 62 kB 00:05
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for http://mirror.datacenter.by/pub/fedoraproject.org/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: mirror.datacenter.by]
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for https://mirror.hyperdedic.ru/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: mirror.hyperdedic.ru]
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for http://mirror.hyperdedic.ru/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: mirror.hyperdedic.ru]
(429/1443): libXinerama-1.1.4-11.fc37.x86_64.rpm 3.4 kB/s | 14 kB 00:04
(430/1443): libXmu-1.1.3-9.fc37.x86_64.rpm 17 kB/s | 74 kB 00:04
(431/1443): libXpresent-1.0.0-17.fc37.x86_64.rpm 21 kB/s | 17 kB 00:00
(432/1443): libXrandr-1.5.2-9.fc37.x86_64.rpm 38 kB/s | 27 kB 00:00
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for http://mirror.linux-ia64.org/fedora/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: mirror.linux-ia64.org]
(433/1443): libXrender-0.9.10-17.fc37.x86_64.rpm 37 kB/s | 27 kB 00:00
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for https://mirror.linux-ia64.org/fedora/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: mirror.linux-ia64.org]
(434/1443): libXres-1.2.1-3.fc37.x86_64.rpm 17 kB/s | 15 kB 00:00
(435/1443): libXt-1.2.1-3.fc37.x86_64.rpm 108 kB/s | 180 kB 00:01
(436/1443): libXtst-1.2.3-17.fc37.x86_64.rpm 15 kB/s | 20 kB 00:01
(437/1443): libXv-1.0.11-17.fc37.x86_64.rpm 19 kB/s | 18 kB 00:00
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for https://divergentnetworks.mm.fcix.net/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: divergentnetworks.mm.fcix.net]
(438/1443): libXvMC-1.0.12-8.fc37.x86_64.rpm 24 kB/s | 23 kB 00:00
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for http://divergentnetworks.mm.fcix.net/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: divergentnetworks.mm.fcix.net]
(439/1443): libXxf86dga-1.1.5-9.fc37.x86_64.rpm 24 kB/s | 20 kB 00:00
(440/1443): libXxf86misc-1.0.4-12.fc37.x86_64.rpm 26 kB/s | 21 kB 00:00
(441/1443): libXxf86vm-1.1.4-19.fc37.x86_64.rpm 25 kB/s | 18 kB 00:00
(442/1443): libacl-2.3.1-4.fc37.x86_64.rpm 31 kB/s | 23 kB 00:00
(443/1443): libaio-0.3.111-14.fc37.x86_64.rpm 34 kB/s | 23 kB 00:00
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for http://distrib-coffee.ipsl.jussieu.fr/pub/linux/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: distrib-coffee.ipsl.jussieu.fr]
(444/1443): libappstream-glib-0.8.1-1.fc37.x86_64.rpm 176 kB/s | 404 kB 00:02
(445/1443): libargon2-20190702-1.fc37.x86_64.rpm 15 kB/s | 28 kB 00:01
(446/1443): libassuan-2.5.5-5.fc37.x86_64.rpm 87 kB/s | 67 kB 00:00
(447/1443): libasyncns-0.8-23.fc37.x86_64.rpm 39 kB/s | 30 kB 00:00
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for http://mirror.etf.bg.ac.rs/fedora/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: mirror.etf.bg.ac.rs]
(448/1443): libatasmart-0.19-23.fc37.x86_64.rpm 68 kB/s | 47 kB 00:00
(449/1443): libatomic_ops-7.6.12-3.fc37.x86_64.rpm 48 kB/s | 36 kB 00:00
(450/1443): libattr-2.5.1-5.fc37.x86_64.rpm 27 kB/s | 18 kB 00:00
(451/1443): libavc1394-0.5.4-18.fc37.x86_64.rpm 73 kB/s | 55 kB 00:00
(452/1443): libbabeltrace-1.5.8-12.fc37.x86_64.rpm 136 kB/s | 189 kB 00:01
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for https://b4sh.mm.fcix.net/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: b4sh.mm.fcix.net]
(453/1443): libbasicobjects-0.1.1-52.fc37.x86_64.rpm 16 kB/s | 26 kB 00:01
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for http://b4sh.mm.fcix.net/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: b4sh.mm.fcix.net]
(454/1443): libblkid-2.38.1-1.fc37.x86_64.rpm 117 kB/s | 107 kB 00:00
(455/1443): libblockdev-2.28-2.fc37.x86_64.rpm 95 kB/s | 86 kB 00:00
(456/1443): libblockdev-btrfs-2.28-2.fc37.x86_64.rpm 40 kB/s | 23 kB 00:00
(457/1443): libblockdev-crypto-2.28-2.fc37.x86_64.rpm 52 kB/s | 32 kB 00:00
(458/1443): libblockdev-dm-2.28-2.fc37.x86_64.rpm 25 kB/s | 22 kB 00:00
(459/1443): libblockdev-fs-2.28-2.fc37.x86_64.rpm 59 kB/s | 36 kB 00:00
(460/1443): libblockdev-kbd-2.28-2.fc37.x86_64.rpm 40 kB/s | 27 kB 00:00
(461/1443): libblockdev-loop-2.28-2.fc37.x86_64.rpm 28 kB/s | 20 kB 00:00
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for http://ftp.otenet.gr/linux/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: ftp.otenet.gr]
(462/1443): libblockdev-lvm-2.28-2.fc37.x86_64.rpm 62 kB/s | 37 kB 00:00
(463/1443): libblockdev-mdraid-2.28-2.fc37.x86_64.rpm 43 kB/s | 26 kB 00:00
(464/1443): libblockdev-mpath-2.28-2.fc37.x86_64.rpm 36 kB/s | 21 kB 00:00
(465/1443): libblockdev-nvdimm-2.28-2.fc37.x86_64.rpm 45 kB/s | 22 kB 00:00
(466/1443): libblockdev-part-2.28-2.fc37.x86_64.rpm 49 kB/s | 29 kB 00:00
(467/1443): libblockdev-plugins-all-2.28-2.fc37.x86_64.rpm 22 kB/s | 13 kB 00:00
(468/1443): libblockdev-swap-2.28-2.fc37.x86_64.rpm 32 kB/s | 21 kB 00:00
(469/1443): libblockdev-utils-2.28-2.fc37.x86_64.rpm 42 kB/s | 30 kB 00:00
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for http://mirror.library.ucy.ac.cy/linux/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: mirror.library.ucy.ac.cy]
(470/1443): libbrotli-1.0.9-9.fc37.x86_64.rpm 107 kB/s | 315 kB 00:02
(471/1443): libcanberra-0.30-29.fc37.x86_64.rpm 31 kB/s | 87 kB 00:02
[MIRROR] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: Curl error (6): Couldn’t resolve host name for http://download.fedoraproject.org/pub/fedora/linux/releases/37/Everything/x86_64/os/Packages/g/gtk2-engines-2.20.2-25.fc37.x86_64.rpm [Could not resolve host: download.fedoraproject.org]
[FAILED] gtk2-engines-2.20.2-25.fc37.x86_64.rpm: No more mirrors to try - All mirrors were already tried without success
(473-474/1443): libcap-2.48-5.fc37.x86_64.rpm 38% [==================================================== ] 202 kB/s | 487 MB 65:31 ETA
The downloaded packages were saved in cache until the next successful transaction.
You can remove cached packages by executing ‘dnf clean packages’.
Error: Error downloading packages:
gtk2-engines-2.20.2-25.fc37.x86_64: Cannot download, all mirrors were already tried without success
All of these errors pertaining to failed requests to mirrors were solved by switching to an
obfs4 (automatic) bridge connection.
Now there is a new error pertaining to a python library dependency:
Error: Transaction test error:
file /usr/share/doc/python-systemd/NEWS from install of python3-systemd-235-1.fc37.x86_64 conflicts with file from package python2-systemd-234-5.1.fc25.x86_64
file /usr/share/doc/python-systemd/README.md from install of python3-systemd-235-1.fc37.x86_64 conflicts with file from package python2-systemd-234-5.1.fc25.x86_64
Did you upgrade your system in-place from Qubes OS 4.0 to Qubes OS 4.1 and now to Qubes OS 4.2?
There seems to be a package left from Qubes OS 4.0 based on fc25 part.
Maybe try to remove the package manually:
sudo dnf remove python2-systemd
