Having technical problem with Qubes-Task-Gui errors. Posted in reply under general, but still no suggestions. This is unofficial @unman application that can install VMs. It seems to download file, but I am unable to locate it, including using thunar in dom0, and can’t install it.
After running it:
qubes-task-gui
Using sys-whonix as UpdateVM to download updates for Dom0; this may take some time…
*** ERROR while receiving updates:
Error canonicalizing /var/tmp/qubes-updates-tmpb_velomxz.UNTRUSTED/3isec-qubes-sys-multimedia-2.1-1.fc32.x86_64.rpm
→ if you want to use packages that were downloaded correctly, use dnf directly now
Getting errors during sh to download:
qubes-task-gui
Error canonicalizing /var/tmp/qubes-updates-tmpya23_z6z.UNTRUSTED/3isec-qubes-sys-vpn-1.1-1.fc32.x86_64.rpm
In [sys-whonix] sh, I get errors:
“Unable to detect release version (use ‘–releasever’ to specify release version)”
It lists repositories, and downloads successfully
then:
"Installing:
3i-sec-qubes-cacher…
3i-sec-qibes-sys-vpn
Get error that they are already downloaded
Then “NO KEY” error:
warning: /var/lib…/3isec-qbes-cacher…rpm: Header… Key ID… NO KEY
“Key imported successfully
Complete!”
The downloaded packages were saved in cache until the next successful transaction.
‘usr/lib/qubes/qrexec-client-vm dom-0 qubes.ReceiveUpdates /usr/lib/qubes/qfile-agent /var/lib/qubes/dom0-updates/pacakages/*rpm’ failed with exit code 1
Fetching update failed with code 1; press Enter to exit
