Getting an error when trying to run qubes-task-gui:
qubes-task-gui
File “/usr/bin/qubes-task-gui”, line 15, in
from qubesadmin.tools.qubes_task import *
ModuleNotFoundError: No module named ‘qubesadmin.tools.qubes_task’
also got the following error when trying to install after adding repo:
sudo qubes-dom0-update 3isec-qubes-task-manager
Using sys-firewall as UpdateVM to download updates for Dom0; this may take some time…
3isec Qubes Dom0 Repository (updates) 79 B/s | 262 B 00:03
Errors during downloading metadata for repository ‘3isec-dom0-current’:
- Status code: 404 for https://qubes.3isec.org/rpm/r4.2/current/dom0/fc32/repodata/repomd.xml (IP: 195.10.223.181)
Error: Failed to download metadata for repo ‘3isec-dom0-current’: Cannot download repomd.xml: Cannot download repodata/repomd.xml: All mirrors were tried
unman.pub has been imported, verified, added. installed using sudo dnf after getting the .rpm for task-gui and moving it to dom0. not sure if this is a result of using rc4?
