i had a problem with the dual boot where i installed qubes and for some reason i am not able to access to Qubes. I restored the boot and the efi but the keyboard does not work to enter the password it works to enter the passphrase.
i would like to recover the informatin cointained in some qubes. so my question is.
how can i recover that information using the rescue mode?
regards
Do you use a USB keyboard? - and if so, could it be “hidden” from dom0 by a kernel option from the GRUB menu?
If so, does this work:
thank you very much.
It worked
yes, i did not say it. I have an usb keyboard.
