Qubes r4.2 repo missing kernel 6.18.26
I’m unable to update any dom0 packages because the update thinks there is an available kernel update when none is available in the repo.
  • Searching for “6.18.26” comes up empty in the repo.
  • dom0 update thinks kernel version 6.18.26-2 is availalable, but fails to find the packages. Since I’m using the onion repo, it doesn’t actually try any other mirrors.
Checking for available updates for dom0...
Using sys-whonix as UpdateVM for Dom0
Checking for dom0 updates...
Available updates:
Fedora 37 - x86_64                              1.7 kB/s | 4.0 kB     00:02
Fedora 37 - x86_64 - Updates                    1.6 kB/s | 4.0 kB     00:02
Qubes Host Repository (updates)                 678  B/s | 2.0 kB     00:02
kernel.x86_64                     1000:6.18.26-2.qubes.fc37   qubes-dom0-current
kernel-devel.x86_64               1000:6.18.26-2.qubes.fc37   qubes-dom0-current
kernel-modules.x86_64             1000:6.18.26-2.qubes.fc37   qubes-dom0-current
kernel-qubes-vm.x86_64            1000:6.18.26-2.qubes.fc37   qubes-dom0-current
Installing:
 kernel                     x86_64  1000:6.18.26-2.qubes.fc37 qubes-dom0-current   14 M
 kernel-devel               x86_64  1000:6.18.26-2.qubes.fc37 qubes-dom0-current   16 M
 kernel-modules             x86_64  1000:6.18.26-2.qubes.fc37 qubes-dom0-current   87 M
 kernel-qubes-vm            x86_64  1000:6.18.26-2.qubes.fc37 qubes-dom0-current   20 M
[MIRROR] kernel-6.18.26-2.qubes.fc37.x86_64.rpm: Status code: 404 for http://yum.qubesosfasa4zl44o4tws22di6kepyzfeqv3tg4e3ztknltfxqrymdad.onion/r4.2/current/host/fc37/rpm/kernel-6.18.26-2.qubes.fc37.x86_64.rpm (IP: 127.42.42.0)
[FAILED] kernel-6.18.26-2.qubes.fc37.x86_64.rpm: No more mirrors to try - All mirrors were already tried without success
The downloaded packages were saved in cache until the next successful transaction.
You can remove cached packages by executing 'dnf clean packages'.
Error: Error downloading packages:
  kernel-1000:6.18.26-2.qubes.fc37.x86_64: Cannot download, all mirrors were already tried without success
It’s present in the non-onion stable and testing repos, but for the onion mirror it’s only in the testing repo.
That’s the vm/ repo URL. dom0 uses host/
It seems to be in the current repo.
Perhaps some glitch with the mirroring, or perhaps natural mid mirror
hits?
