I took an old T7500 from DELL which should be able to run qubes and found wired behavior. I need to to verify the usb stick, but as dd did not throw write errors the writing should have been correct.
I said sync after dd and waited for the root prompt again #
What happened?
After long time wait for huge ecc ram to be initialized the machine booted from usb stick and started grub. Here I got a floppy seek (!) two times and an error about two missing files.
missing files:
looking for trouble:
Long time with black screen and fat blinking _ cursor, then cursor disappeared and re-appeared.
Then black screen with fat blinking _ cursor.
Badumm Tss. Kernel Panic.
As this panic is only displayed shortly I had to rush to take the photo, it does not look good but it is readable. A problem with XEN as it seems to me.
The machine rebooted quickly after displaying the panic.
@developers:
What about printf- / echo logging to line printer or rs232?
What about writing out numbers or text at the time when only the cursor can be seen.
I guess this is all XEN trying to do something.
Checks to be done, (but will not help much):
I need to run older qubes, memtest86 on the machine, also I need to verify the stick for errors.
Is there ioport 80 debugging sent while early booting? Need to grab a port 80 board somewhere.
Update:
looking for xen issues with the processor arch and ICH10 I only found this very old post.
https://lists.xen.org/archives/html/xen-devel/2011-08/msg00893.html
