Qubes OS updates Weekly Review - Y2025-W06
Introduction
Weekly review of new packages uploaded to Qubes OS repositories. Link to previous version here.
i3_4.23-2+deb12u1_amd64.deb
i3-4.23-2.fc37.x86_64.rpm
i3-4.23-2.fc40.x86_64.rpm
i3-4.23-2.fc41.x86_64.rpm
i3_4.23-2+jammy1_amd64.deb
i3_4.23-2+noble1_amd64.deb
i3-devel-4.23-2.fc37.x86_64.rpm
i3-devel-4.23-2.fc40.x86_64.rpm
i3-devel-4.23-2.fc41.x86_64.rpm
i3-devel-doc-4.23-2.fc37.noarch.rpm
i3-devel-doc-4.23-2.fc40.noarch.rpm
i3-devel-doc-4.23-2.fc41.noarch.rpm
i3-doc-4.23-2.fc37.noarch.rpm
i3-doc-4.23-2.fc40.noarch.rpm
i3-doc-4.23-2.fc41.noarch.rpm
i3-wm_4.23-2+deb12u1_amd64.deb
i3-wm_4.23-2+jammy1_amd64.deb
i3-wm_4.23-2+noble1_amd64.deb
i3-wm-dbg_4.23-2+deb12u1_amd64.deb
i3-wm-dbg_4.23-2+jammy1_amd64.deb
i3-wm-dbg_4.23-2+noble1_amd64.deb
libqrexec-utils4_4.3.2-1+deb12u1_amd64.deb
libqrexec-utils4_4.3.2-1+deb13u1_amd64.deb
libqrexec-utils4_4.3.2-1+jammy1_amd64.deb
libqrexec-utils4_4.3.2-1+noble1_amd64.deb
libqrexec-utils4-dbgsym_4.3.2-1+deb12u1_amd64.deb
libqrexec-utils4-dbgsym_4.3.2-1+deb13u1_amd64.deb
libqrexec-utils-dev_4.3.2-1+deb12u1_amd64.deb
libqrexec-utils-dev_4.3.2-1+deb13u1_amd64.deb
libqrexec-utils-dev_4.3.2-1+jammy1_amd64.deb
libqrexec-utils-dev_4.3.2-1+noble1_amd64.deb
python3-qrexec_4.3.2-1+deb12u1_amd64.deb
python3-qrexec_4.3.2-1+deb13u1_amd64.deb
python3-qrexec_4.3.2-1+jammy1_amd64.deb
python3-qrexec_4.3.2-1+noble1_amd64.deb
qubes-core-qrexec_4.3.2-1+deb12u1_amd64.deb
qubes-core-qrexec_4.3.2-1+deb13u1_amd64.deb
qubes-core-qrexec-4.3.2-1.fc40.x86_64.rpm
qubes-core-qrexec-4.3.2-1.fc41.x86_64.rpm
qubes-core-qrexec_4.3.2-1+jammy1_amd64.deb
qubes-core-qrexec_4.3.2-1+noble1_amd64.deb
qubes-core-qrexec-dbgsym_4.3.2-1+deb12u1_amd64.deb
qubes-core-qrexec-dbgsym_4.3.2-1+deb13u1_amd64.deb
qubes-core-qrexec-devel-4.3.2-1.fc40.x86_64.rpm
qubes-core-qrexec-devel-4.3.2-1.fc41.x86_64.rpm
qubes-core-qrexec-dom0-4.3.2-1.fc41.x86_64.rpm
qubes-core-qrexec-libs-4.3.2-1.fc40.x86_64.rpm
qubes-core-qrexec-libs-4.3.2-1.fc41.x86_64.rpm
qubes-core-qrexec-vm-4.3.2-1.fc40.x86_64.rpm
qubes-core-qrexec-vm-4.3.2-1.fc41.x86_64.rpm
qubes-core-qrexec-vm-selinux-4.3.2-1.fc40.x86_64.rpm
qubes-core-qrexec-vm-selinux-4.3.2-1.fc41.x86_64.rpm
qubes-vm-qrexec-4.3.2-1-x86_64.pkg.tar.zst
Highlights
- Major qrexec performance improvements
Details
core-admin v4.3.17 (r4.3)
. This one is actually released today. See epilogue for more information.
. qrexec policy evaluation will use cached data. This will have considerable performance improvements. The cache will be invalidated on specific events. Examples are starting/shutting-down domains, adding/removing tags, changing domain labels, …
. Fixing Thunderbird support on Fedora 41 -
(qubes) manager v4.3.8-1 (r4.3)
. While this was released at the latest hours of 2025-W06, build of actual packages happened today.
. Mostly bug fixes. Notable one is fixing a bug in cloning Qubes to other storage pools. The CLI counterpart (qvm-clone) was not affected.
. The old Qt basedqubes-vm-createdialog is deprecated. -
core-qrexec v4.3.2 & v4.3.3 (r4.3)
. Yet another SELinux patch for the Fedora 41 memory ballooning issue.
. Only for Qubes OS R4.3, RPC calls will be directly executed from c code andqubes-rpc-multiplexeris no longer used. It will remain for legacy use cases. This will have some considerable performance improvements. -
desktop-linux-i3 v4.23-2 (r4.2)
The patch from May 2024 which has been tested on R4.3. Allowing i3 users to change default border width (default is 3 pixels).
Epilogue
Since major qrexec improvements are somewhat related, I decided to include both of them in this week’s report. Even though the core-admin one is actually released today.
