Of course, I can’t save terminal outputs and save them to a USB drive from dom0 so I had to take snapshots.
Wait, any other VM is broke too? Or just tor?
What do you make of them?
I expected there to be an issue because for snowflake to work, some changes in the had to be made and maybe this broke your tor connection.
Stupid question.
# 3. Create Whonix Gateways
whonix_gws() {
for g in "sys-whonix-A:red" "sys-whonix-B:blue"; do
n=${g%:*}; l=${g#*:}
if ! qvm-ls | grep -q "$n"; then
qvm-create --class AppVM --label "$l" --template whonix-gateway-18 "$n"
qvm-prefs "$n" provides_network true
ok "$n created"
else
info "$n already exists, skipping"
fi
done
pause
It does not define a net qube. Is your sys-whonix A even connected to sys-firewall?
As you didn’t directly answered
Do you use Snowflake?
I assume that you don’t get a tor connection at all.
Does setup-ram-pool.sh actually set up a seperate RAM pool from varlibqubes where the Live mode script puts it’s RAM DVMs? Why?
And I thought create-ram-vm.sh lets you customize a RAM VM as you create it. Instead it just sets a template, name, etc. for you. Although I could still edit the script before running it but still…
Ah. @Schnur As I was writing this, the Tor progress bar was at around 71% but when I checked again, it’s back around 20 to 30%. That’s the problem I had before with Sys-Whonix-A.
On an off-note, previously, for some reason I wasn’t able to start up any apps on untrusted-ram-dvm so I was trying to reproduce the error to take screenshots but… By some miracle, I was able to run a file explorer and plug in my USB drive. Although…
I’ve gone through the script and found nothing tampering with the template.
Try reinstalling the template in the template manager. Safe any configs if needed.
Hey @abdullah.
Since there hasn’t been an update to your script, incorporating @linuxuser1’s Live Mode updates, I decided to just copy and paste his script into yours myself and give it another test run.
About a week ago, I ran yet another fresh install of Qubes 4.3.1 and ran the script once more, albeit modified with the latest updated version of @linuxuser1’s Live Mode script at the time.
Today, I booted it up (without a clear idea what to do next) on Persistent Mode and decided, on the fly, to give it a test run.
I found that while sys-Whonix’s Tor Control Panel isn’t accessible on the panel for some reason (right clicking the icon lists sys-firewall, sys-usb and sys-net but no sys-whonix), I can access it from the app menu and found it works fine and successfully connects to Tor through the obfs4 and snowflake bridges.
Last of all, while I was running the script last week, the folders created from the Create RAM Pool Scripts and Destruction tools options have locks over their desktop icons, which I’m sure didn’t happen before.
Actually, I’m beginning to discover the problem with attaching storage flash drives might not be sys-usb’s fault but something gone wrong with my laptop itself.
Edit 15/8/26: Yeah. USB flash drives are working again. All I needed to do was remove the battery, drain away any residual power by holding the power button for a minute and then everything’s back to normal.
I thought it was a problem with sys-usb but that was a false alarm.
Sorry about that.
