Qubes OS randomly hard-freezes on Asus ROG Zephyrus G16 (Intel Ultra 9 + RTX) kernel update didn't fix it
I’m running Qubes OS on an Asus ROG Zephyrus G16 with an Intel Core Ultra 9 CPU and an RTX 5070 GPU (2025 model), installed on a external USB drive.
I’m experiencing two separate issues:
1. Random complete freeze during normal use
After a few hours of just working normally, the entire system suddenly hard-freezes no lag beforehand, no warning, it just locks up instantly. The screen freezes, the keyboard becomes completely unresponsive, and the only way out is a forced power-off. Nothing in my usage triggers it consistently it just happens randomly.
2. Sleep/wake causes a reboot
When the laptop goes into sleep mode and I open it back up, it seems to resume for about a minute and then spontaneously reboots itself.
I never had either of these issues on my older laptop or desktop PC running Qubes.
What I’ve already tried:
  • Installed the newest available kernel via sudo qubes-dom0-update kernel-latest kernel-latest-qubes-vm and set it as the global default no change to the freezing behavior
  • I can’t use the new kernel on sys-net specifically, because on any kernel newer than the oldest one, the WiFi connections don’t show up in Network Manager at all. So sys-net stays pinned to the old kernel while all other VMs use the new one.
Has anyone with the same or similar hardware (especially Intel Ultra / Meteor Lake + Nvidia RTX) found a working fix? Any help appreciated.
Like someone actualy please help me fix this, like has anyone ever had the same issue?
When your system freezes can you ctrl-alt-f2 to get to a virtual terminal?
After a forced or unexpected reboot is there anything interesting near the end of the dom0 journal for the prior boot? See: dom0$ sudo journalctl -b -1
I will check when it happens again
It says command not found when i type
Don’t type in the dom0$ part :slight_smile:
Jun 07 15:09:48 dom0 audit[8361]: USER_ACCT pid=8361 uid=1000 auid=1000 ses=3 msg=‘op=PAM:accounting grantors=pam_unix acct=“user” exe=“/usr/bin/sudo” hostname=dom0 addr=? terminal=/dev/pts/5 res=success’
Jun 07 15:09:48 dom0 kernel: audit: type=1101 audit(1780859388.397:445): pid=8361 uid=1000 auid=1000 ses=3 msg=‘op=PAM:accounting grantors=pam_unix acct=“user” exe=“/usr/bin/sudo” hostname=dom0 addr=? terminal=/dev/pts/5 res=success’
Jun 07 15:09:48 dom0 kernel: audit: type=1123 audit(1780859388.398:446): pid=8361 uid=1000 auid=1000 ses=3 msg=‘cwd=“/home/user” cmd=6A6F75726E616C63746C202D62202D31202D6E20353030 exe=“/usr/bin/sudo” terminal=pts/5 res=success’
Jun 07 15:09:48 dom0 kernel: audit: type=1110 audit(1780859388.400:447): pid=8361 uid=1000 auid=1000 ses=3 msg=‘op=PAM:setcred grantors=pam_env,pam_fprintd acct=“root” exe=“/usr/bin/sudo” hostname=dom0 addr=? terminal=/dev/pts/5 res=success’
Jun 07 15:09:48 dom0 audit[8361]: USER_CMD pid=8361 uid=1000 auid=1000 ses=3 msg=‘cwd=“/home/user” cmd=6A6F75726E616C63746C202D62202D31202D6E20353030 exe=“/usr/bin/sudo” terminal=pts/5 res=success’
Jun 07 15:09:48 dom0 audit[8361]: CRED_REFR pid=8361 uid=1000 auid=1000 ses=3 msg=‘op=PAM:setcred grantors=pam_env,pam_fprintd acct=“root” exe=“/usr/bin/sudo” hostname=dom0 addr=? terminal=/dev/pts/5 res=success’
Jun 07 15:09:48 dom0 sudo[8361]: user : TTY=pts/5 ; PWD=/home/user ; USER=root ; COMMAND=/usr/bin/journalctl -b -1 -n 500
Jun 07 15:09:48 dom0 systemd-logind[3102]: Existing logind session ID 3 used by new audit session, ignoring.
Jun 07 15:09:48 dom0 systemd-logind[3102]: New session c16 of user root.
Jun 07 15:09:48 dom0 systemd[1]: Created slice user-0.slice - User Slice of UID 0.
Jun 07 15:09:48 dom0 systemd[1]: Starting user-runtime-dir@0.service - User Runtime Directory /run/user/0…
Jun 07 15:09:48 dom0 systemd[1]: Finished user-runtime-dir@0.service - User Runtime Directory /run/user/0.
Jun 07 15:09:48 dom0 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=user-runtime-dir@0 comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
Jun 07 15:09:48 dom0 kernel: audit: type=1130 audit(1780859388.456:448): pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=user-runtime-dir@0 comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
Jun 07 15:09:48 dom0 systemd[1]: Starting user@0.service - User Manager for UID 0…
Jun 07 15:09:48 dom0 audit[8365]: USER_ACCT pid=8365 uid=0 auid=4294967295 ses=4294967295 msg=‘op=PAM:accounting grantors=pam_unix acct=“root” exe=“/usr/lib/systemd/systemd-executor” hostname=? addr=? terminal=? res=success’
Jun 07 15:09:48 dom0 audit[8365]: CRED_ACQ pid=8365 uid=0 auid=4294967295 ses=4294967295 msg=‘op=PAM:setcred grantors=? acct=“root” exe=“/usr/lib/systemd/systemd-executor” hostname=? addr=? terminal=? res=failed’
Jun 07 15:09:48 dom0 audit[8365]: SYSCALL arch=c000003e syscall=1 success=yes exit=1 a0=7 a1=7fff3970a860 a2=1 a3=0 items=0 ppid=1 pid=8365 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=7 comm=“(systemd)” exe=“/usr/lib/systemd/systemd-executor” key=(null)
Jun 07 15:09:48 dom0 audit: PROCTITLE proctitle=“(systemd)”
Jun 07 15:09:48 dom0 kernel: audit: type=1101 audit(1780859388.482:449): pid=8365 uid=0 auid=4294967295 ses=4294967295 msg=‘op=PAM:accounting grantors=pam_unix acct=“root” exe=“/usr/lib/systemd/systemd-executor” hostname=? addr=? terminal=? res=success’
Jun 07 15:09:48 dom0 kernel: audit: type=1103 audit(1780859388.482:450): pid=8365 uid=0 auid=4294967295 ses=4294967295 msg=‘op=PAM:setcred grantors=? acct=“root” exe=“/usr/lib/systemd/systemd-executor” hostname=? addr=? terminal=? res=failed’
Jun 07 15:09:48 dom0 kernel: audit: type=1006 audit(1780859388.482:451): pid=8365 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=7 res=1
Jun 07 15:09:48 dom0 kernel: audit: type=1300 audit(1780859388.482:451): arch=c000003e syscall=1 success=yes exit=1 a0=7 a1=7fff3970a860 a2=1 a3=0 items=0 ppid=1 pid=8365 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=7 comm=“(systemd)” exe=“/usr/lib/systemd/systemd-executor” key=(null)
Jun 07 15:09:48 dom0 kernel: audit: type=1327 audit(1780859388.482:451): proctitle=“(systemd)”
Jun 07 15:09:48 dom0 systemd-logind[3102]: New session 7 of user root.
Jun 07 15:09:48 dom0 (systemd)[8365]: pam_unix(systemd-user:session): session opened for user root(uid=0) by root(uid=0)
Jun 07 15:09:48 dom0 kernel: audit: type=1105 audit(1780859388.492:452): pid=8365 uid=0 auid=0 ses=7 msg=‘op=PAM:session_open grantors=pam_selinux,pam_selinux,pam_loginuid,pam_keyinit,pam_namespace,pam_systemd_home,pam_umask,pam_keyinit,pam_limits,pam_systemd,pam_unix acct=“root” exe=“/usr/lib/systemd/systemd-executor” hostname=? addr=? terminal=? res=success’
Jun 07 15:09:48 dom0 audit[8365]: USER_START pid=8365 uid=0 auid=0 ses=7 msg=‘op=PAM:session_open grantors=pam_selinux,pam_selinux,pam_loginuid,pam_keyinit,pam_namespace,pam_systemd_home,pam_umask,pam_keyinit,pam_limits,pam_systemd,pam_unix acct=“root” exe=“/usr/lib/systemd/systemd-executor” hostname=? addr=? terminal=? res=success’
Jun 07 15:09:48 dom0 audit: BPF prog-id=106 op=LOAD
Jun 07 15:09:48 dom0 audit[8365]: SYSCALL arch=c000003e syscall=321 success=yes exit=8 a0=5 a1=7fffb561cc60 a2=98 a3=0 items=0 ppid=1 pid=8365 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=7 comm=“systemd” exe=“/usr/lib/systemd/systemd” key=(null)
Jun 07 15:09:48 dom0 audit: BPF prog-id=106 op=UNLOAD
Jun 07 15:09:48 dom0 audit[8365]: SYSCALL arch=c000003e syscall=3 success=yes exit=0 a0=8 a1=7fffb561cd50 a2=98 a3=200000008 items=0 ppid=1 pid=8365 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=7 comm=“systemd” exe=“/usr/lib/systemd/systemd” key=(null)
Jun 07 15:09:48 dom0 audit: BPF prog-id=107 op=LOAD
Jun 07 15:09:48 dom0 audit[8365]: SYSCALL arch=c000003e syscall=321 success=yes exit=8 a0=5 a1=7fffb561cd10 a2=98 a3=0 items=0 ppid=1 pid=8365 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=7 comm=“systemd” exe=“/usr/lib/systemd/systemd” key=(null)
Jun 07 15:09:48 dom0 audit: BPF prog-id=107 op=UNLOAD
Jun 07 15:09:48 dom0 audit[8365]: SYSCALL arch=c000003e syscall=3 success=yes exit=0 a0=8 a1=7fffb561cd10 a2=0 a3=0 items=0 ppid=1 pid=8365 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=7 comm=“systemd” exe=“/usr/lib/systemd/systemd” key=(null)
Jun 07 15:09:48 dom0 audit: BPF prog-id=108 op=LOAD
Jun 07 15:09:48 dom0 audit[8365]: SYSCALL arch=c000003e syscall=321 success=yes exit=8 a0=5 a1=7fffb561bab0 a2=74 a3=2 items=0 ppid=1 pid=8365 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=7 comm=“systemd” exe=“/usr/lib/systemd/systemd” key=(null)
Jun 07 15:09:48 dom0 audit: BPF prog-id=108 op=UNLOAD
Jun 07 15:09:48 dom0 audit[8365]: SYSCALL arch=c000003e syscall=3 success=yes exit=0 a0=8 a1=7fffb561bab0 a2=74 a3=2 items=0 ppid=1 pid=8365 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=7 comm=“systemd” exe=“/usr/lib/systemd/systemd” key=(null)
Jun 07 15:09:48 dom0 audit: BPF prog-id=109 op=LOAD
Jun 07 15:09:48 dom0 audit[8365]: SYSCALL arch=c000003e syscall=321 success=yes exit=8 a0=5 a1=7fffb561bc20 a2=94 a3=7fffb561bd00 items=0 ppid=1 pid=8365 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=7 comm=“systemd” exe=“/usr/lib/systemd/systemd” key=(null)
Jun 07 15:09:48 dom0 audit: BPF prog-id=109 op=UNLOAD
Jun 07 15:09:48 dom0 audit[8365]: SYSCALL arch=c000003e syscall=3 success=yes exit=0 a0=8 a1=7fffb561bc20 a2=0 a3=7fffb561bd00 items=0 ppid=1 pid=8365 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=7 comm=“systemd” exe=“/usr/lib/systemd/systemd” key=(null)
Jun 07 15:09:48 dom0 audit: BPF prog-id=110 op=LOAD
Jun 07 15:09:48 dom0 audit[8365]: SYSCALL arch=c000003e syscall=321 success=yes exit=10 a0=5 a1=7fffb561caa0 a2=94 a3=2 items=0 ppid=1 pid=8365 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=7 comm=“systemd” exe=“/usr/lib/systemd/systemd” key=(null)
Jun 07 15:09:48 dom0 audit: BPF prog-id=110 op=UNLOAD
Jun 07 15:09:48 dom0 audit[8365]: SYSCALL arch=c000003e syscall=3 success=yes exit=0 a0=a a1=7fffb561caa0 a2=0 a3=2 items=0 ppid=1 pid=8365 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=7 comm=“systemd” exe=“/usr/lib/systemd/systemd” key=(null)
Jun 07 15:09:48 dom0 audit: BPF prog-id=111 op=LOAD
Jun 07 15:09:48 dom0 audit[8365]: SYSCALL arch=c000003e syscall=321 success=yes exit=11 a0=5 a1=7fffb561c800 a2=40 a3=4 items=0 ppid=1 pid=8365 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=7 comm=“systemd” exe=“/usr/lib/systemd/systemd” key=(null)
Jun 07 15:09:48 dom0 audit: BPF prog-id=111 op=UNLOAD
Jun 07 15:09:48 dom0 audit[8365]: SYSCALL arch=c000003e syscall=3 success=yes exit=0 a0=b a1=7fffb561c800 a2=40 a3=4 items=0 ppid=1 pid=8365 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=7 comm=“systemd” exe=“/usr/lib/systemd/systemd” key=(null)
Jun 07 15:09:48 dom0 audit: BPF prog-id=112 op=LOAD
Jun 07 15:09:48 dom0 audit[8365]: SYSCALL arch=c000003e syscall=321 success=yes exit=11 a0=5 a1=7fffb561c930 a2=94 a3=7fffb561ca10 items=0 ppid=1 pid=8365 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=7 comm=“systemd” exe=“/usr/lib/systemd/systemd” key=(null)
Jun 07 15:09:48 dom0 audit: BPF prog-id=112 op=UNLOAD
Jun 07 15:09:48 dom0 audit[8365]: SYSCALL arch=c000003e syscall=3 success=yes exit=0 a0=b a1=7fffb561c930 a2=0 a3=7fffb561ca10 items=0 ppid=1 pid=8365 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=7 comm=“systemd” exe=“/usr/lib/systemd/systemd” key=(null)
Jun 07 15:09:48 dom0 audit: BPF prog-id=113 op=LOAD
Jun 07 15:09:48 dom0 audit[8365]: SYSCALL arch=c000003e syscall=321 success=yes exit=11 a0=5 a1=7fffb561c160 a2=94 a3=52 items=0 ppid=1 pid=8365 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=7 comm=“systemd” exe=“/usr/lib/systemd/systemd” key=(null)
Jun 07 15:09:48 dom0 audit: BPF prog-id=114 op=LOAD
Jun 07 15:09:48 dom0 audit[8365]: SYSCALL arch=c000003e syscall=321 success=yes exit=12 a0=5 a1=7fffb561c160 a2=94 a3=52 items=0 ppid=1 pid=8365 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=7 comm=“systemd” exe=“/usr/lib/systemd/systemd” key=(null)
Jun 07 15:09:48 dom0 audit: BPF prog-id=113 op=UNLOAD
Jun 07 15:09:48 dom0 audit[8365]: SYSCALL arch=c000003e syscall=3 success=yes exit=0 a0=b a1=9 a2=0 a3=0 items=0 ppid=1 pid=8365 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=7 comm=“systemd” exe=“/usr/lib/systemd/systemd” key=(null)
Jun 07 15:09:48 dom0 audit: BPF prog-id=114 op=UNLOAD
Jun 07 15:09:48 dom0 audit[8365]: SYSCALL arch=c000003e syscall=3 success=yes exit=0 a0=c a1=55dab80646d0 a2=19 a3=55dab80646e0 items=0 ppid=1 pid=8365 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=7 comm=“systemd” exe=“/usr/lib/systemd/systemd” key=(null)
Jun 07 15:09:48 dom0 audit: BPF prog-id=115 op=LOAD
Jun 07 15:09:48 dom0 audit[8365]: SYSCALL arch=c000003e syscall=321 success=yes exit=8 a0=5 a1=7fffb561bc20 a2=94 a3=2 items=0 ppid=1 pid=8365 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=7 comm=“systemd” exe=“/usr/lib/systemd/systemd” key=(null)
Jun 07 15:09:48 dom0 audit: BPF prog-id=115 op=UNLOAD
Jun 07 15:09:48 dom0 audit[8365]: SYSCALL arch=c000003e syscall=3 success=yes exit=0 a0=8 a1=7fffb561bc20 a2=0 a3=2 items=0 ppid=1 pid=8365 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=7 comm=“systemd” exe=“/usr/lib/systemd/systemd” key=(null)
Jun 07 15:09:48 dom0 audit: BPF prog-id=116 op=LOAD
Jun 07 15:09:48 dom0 audit[8365]: SYSCALL arch=c000003e syscall=321 success=yes exit=10 a0=5 a1=7fffb561ca60 a2=94 a3=2 items=0 ppid=1 pid=8365 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=7 comm=“systemd” exe=“/usr/lib/systemd/systemd” key=(null)
Jun 07 15:09:48 dom0 audit: BPF prog-id=116 op=UNLOAD
Jun 07 15:09:48 dom0 audit[8365]: SYSCALL arch=c000003e syscall=3 success=yes exit=0 a0=a a1=7fffb561ca60 a2=0 a3=2 items=0 ppid=1 pid=8365 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=7 comm=“systemd” exe=“/usr/lib/systemd/systemd” key=(null)
Jun 07 15:09:48 dom0 audit: BPF prog-id=117 op=LOAD
Jun 07 15:09:48 dom0 audit[8365]: SYSCALL arch=c000003e syscall=321 success=yes exit=12 a0=5 a1=7fffb561c740 a2=94 a3=5 items=0 ppid=1 pid=8365 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=7 comm=“systemd” exe=“/usr/lib/systemd/systemd” key=(null)
Jun 07 15:09:48 dom0 audit: BPF prog-id=117 op=UNLOAD
Jun 07 15:09:48 dom0 audit[8365]: SYSCALL arch=c000003e syscall=3 success=yes exit=0 a0=c a1=7fffb561c740 a2=0 a3=5 items=0 ppid=1 pid=8365 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=7 comm=“systemd” exe=“/usr/lib/systemd/systemd” key=(null)
Jun 07 15:09:48 dom0 audit: BPF prog-id=118 op=LOAD
Jun 07 15:09:48 dom0 audit[8365]: SYSCALL arch=c000003e syscall=321 success=yes exit=11 a0=5 a1=7fffb561bfe0 a2=94 a3=2 items=0 ppid=1 pid=8365 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=7 comm=“systemd” exe=“/usr/lib/systemd/systemd” key=(null)
Jun 07 15:09:48 dom0 audit: BPF prog-id=118 op=UNLOAD
Jun 07 15:09:48 dom0 audit[8365]: SYSCALL arch=c000003e syscall=3 success=yes exit=0 a0=b a1=7fffb561bfe0 a2=0 a3=2 items=0 ppid=1 pid=8365 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=7 comm=“systemd” exe=“/usr/lib/systemd/systemd” key=(null)
Jun 07 15:09:48 dom0 audit: BPF prog-id=119 op=LOAD
Jun 07 15:09:48 dom0 audit[8365]: SYSCALL arch=c000003e syscall=321 success=yes exit=11 a0=5 a1=7fffb561c120 a2=94 a3=13 items=0 ppid=1 pid=8365 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=7 comm=“systemd” exe=“/usr/lib/systemd/systemd” key=(null)
Jun 07 15:09:48 dom0 audit: BPF prog-id=120 op=LOAD
Jun 07 15:09:48 dom0 audit[8365]: SYSCALL arch=c000003e syscall=321 success=yes exit=13 a0=5 a1=7fffb561bf70 a2=94 a3=2 items=0 ppid=1 pid=8365 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=7 comm=“systemd” exe=“/usr/lib/systemd/systemd” key=(null)
Jun 07 15:09:48 dom0 audit: BPF prog-id=120 op=UNLOAD
Jun 07 15:09:48 dom0 audit[8365]: SYSCALL arch=c000003e syscall=3 success=yes exit=0 a0=d a1=7fffb561bfa0 a2=0 a3=7fffb561c090 items=0 ppid=1 pid=8365 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=7 comm=“systemd” exe=“/usr/lib/systemd/systemd” key=(null)
Jun 07 15:09:48 dom0 audit: BPF prog-id=121 op=LOAD
Jun 07 15:09:48 dom0 audit[8365]: SYSCALL arch=c000003e syscall=321 success=yes exit=12 a0=5 a1=7fffb561c120 a2=94 a3=13 items=0 ppid=1 pid=8365 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=7 comm=“systemd” exe=“/usr/lib/systemd/systemd” key=(null)
Jun 07 15:09:48 dom0 audit: BPF prog-id=119 op=UNLOAD
Jun 07 15:09:48 dom0 audit: BPF prog-id=121 op=UNLOAD
Jun 07 15:09:48 dom0 audit[8365]: SYSCALL arch=c000003e syscall=3 success=yes exit=0 a0=c a1=55dab80662d0 a2=19 a3=55dab80662e0 items=0 ppid=1 pid=8365 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=7 comm=“systemd” exe=“/usr/lib/systemd/systemd” key=(null)
Jun 07 15:09:48 dom0 systemd[8365]: Queued start job for default target default.target.
Jun 07 15:09:48 dom0 systemd[8365]: Created slice app.slice - User Application Slice.
Jun 07 15:09:48 dom0 systemd[8365]: Created slice session.slice - User Core Session Slice.
Jun 07 15:09:48 dom0 systemd[8365]: grub-boot-success.timer - Mark boot as successful after the user session has run 2 minutes was skipped because of an unmet condition check (ConditionUser=!@system).
Jun 07 15:09:48 dom0 systemd[8365]: Started systemd-tmpfiles-clean.timer - Daily Cleanup of User’s Temporary Directories.
Jun 07 15:09:48 dom0 systemd[8365]: Reached target paths.target - Paths.
Jun 07 15:09:48 dom0 systemd[8365]: Reached target timers.target - Timers.
Jun 07 15:09:48 dom0 systemd[8365]: Starting dbus.socket - D-Bus User Message Bus Socket…
Jun 07 15:09:48 dom0 systemd[8365]: Listening on dirmngr.socket - GnuPG network certificate management daemon.
Jun 07 15:09:48 dom0 systemd[8365]: Listening on gnome-keyring-daemon.socket - GNOME Keyring daemon.
Jun 07 15:09:48 dom0 systemd[8365]: Listening on gpg-agent-browser.socket - GnuPG cryptographic agent and passphrase cache (access for web browsers).
Jun 07 15:09:48 dom0 systemd[8365]: Listening on gpg-agent-extra.socket - GnuPG cryptographic agent and passphrase cache (restricted).
Jun 07 15:09:48 dom0 systemd[8365]: Listening on gpg-agent-ssh.socket - GnuPG cryptographic agent (ssh-agent emulation).
Jun 07 15:09:48 dom0 systemd[8365]: Listening on gpg-agent.socket - GnuPG cryptographic agent and passphrase cache.
Jun 07 15:09:48 dom0 systemd[8365]: pipewire-pulse.socket - PipeWire PulseAudio was skipped because of an unmet condition check (ConditionUser=!root).
Jun 07 15:09:48 dom0 systemd[8365]: pipewire.socket - PipeWire Multimedia System Sockets was skipped because of an unmet condition check (ConditionUser=!root).
Jun 07 15:09:48 dom0 systemd[8365]: Listening on ssh-agent.socket - OpenSSH key agent.
Jun 07 15:09:48 dom0 systemd[8365]: Starting systemd-tmpfiles-setup.service - Create User Files and Directories…
Jun 07 15:09:48 dom0 systemd[8365]: Listening on dbus.socket - D-Bus User Message Bus Socket.
Jun 07 15:09:48 dom0 systemd[8365]: Finished systemd-tmpfiles-setup.service - Create User Files and Directories.
Jun 07 15:09:48 dom0 systemd[8365]: Reached target sockets.target - Sockets.
Jun 07 15:09:48 dom0 systemd[8365]: Starting dbus-broker.service - D-Bus User Message Bus…
Jun 07 15:09:48 dom0 dbus-broker-launch[8376]: Service file ‘/usr/share/dbus-1/services/dbus-qubes-app-menu.service’ is not named after the D-Bus name ‘org.qubesos.appmenu’.
Jun 07 15:09:48 dom0 dbus-broker-launch[8376]: Service file ‘/usr/share/dbus-1/services/org.kde.kscreen.service’ is not named after the D-Bus name ‘org.kde.KScreen’.
Jun 07 15:09:48 dom0 dbus-broker-launch[8376]: Service file ‘/usr/share/dbus-1/services/org.kde.plasma.Notifications.service’ is not named after the D-Bus name ‘org.freedesktop.Notifications’.
Jun 07 15:09:48 dom0 dbus-broker-launch[8376]: Service file ‘/usr/share/dbus-1/services/org.xfce.Thunar.FileManager1.service’ is not named after the D-Bus name ‘org.freedesktop.FileManager1’.
Jun 07 15:09:48 dom0 dbus-broker-launch[8376]: Service file ‘/usr/share/dbus-1/services/org.xfce.Tumbler.Cache1.service’ is not named after the D-Bus name ‘org.freedesktop.thumbnails.Cache1’.
Jun 07 15:09:48 dom0 dbus-broker-launch[8376]: Service file ‘/usr/share/dbus-1/services/org.xfce.Tumbler.Manager1.service’ is not named after the D-Bus name ‘org.freedesktop.thumbnails.Manager1’.
Jun 07 15:09:48 dom0 dbus-broker-launch[8376]: Service file ‘/usr/share/dbus-1/services/org.xfce.Tumbler.Thumbnailer1.service’ is not named after the D-Bus name ‘org.freedesktop.thumbnails.Thumbnailer1’.
Jun 07 15:09:48 dom0 dbus-broker-launch[8376]: Service file ‘/usr/share/dbus-1/services/org.xfce.xfce4-notifyd.Notifications.service’ is not named after the D-Bus name ‘org.freedesktop.Notifications’.
Jun 07 15:09:48 dom0 dbus-broker-launch[8376]: Policy to allow eavesdropping in /usr/share/dbus-1/session.conf +31: Eavesdropping is deprecated and ignored
Jun 07 15:09:48 dom0 dbus-broker-launch[8376]: Policy to allow eavesdropping in /usr/share/dbus-1/session.conf +33: Eavesdropping is deprecated and ignored
Jun 07 15:09:48 dom0 dbus-broker-launch[8376]: Ignoring duplicate name ‘org.freedesktop.Notifications’ in service file ‘/usr/share/dbus-1/services/org.xfce.xfce4-notifyd.Notifications.service’
Jun 07 15:09:48 dom0 dbus-broker-launch[8376]: Service file ‘/usr/share/dbus-1/services/org.xfce.xfce4-notifyd.Notifyd.service’ is not named after the D-Bus name ‘org.xfce.Notifyd’.
Jun 07 15:09:48 dom0 systemd[8365]: Started dbus-broker.service - D-Bus User Message Bus.
Jun 07 15:09:48 dom0 systemd[8365]: Reached target basic.target - Basic System.
Jun 07 15:09:48 dom0 systemd[1]: Started user@0.service - User Manager for UID 0.
Jun 07 15:09:48 dom0 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=user@0 comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
Jun 07 15:09:48 dom0 systemd[8365]: Started gnome-keyring-daemon.service - GNOME Keyring daemon.
Jun 07 15:09:48 dom0 systemd[8365]: pipewire.service - PipeWire Multimedia Service was skipped because of an unmet condition check (ConditionUser=!root).
Jun 07 15:09:48 dom0 systemd[1]: Started session-c16.scope - Session c16 of User root.
Jun 07 15:09:48 dom0 systemd[8365]: Starting unity-gtk-module.service - Unity GTK Module Environment variables…
Jun 07 15:09:48 dom0 systemd[8365]: wireplumber.service: Bound to unit pipewire.service, but unit isn’t active.
Jun 07 15:09:48 dom0 audit[8361]: USER_START pid=8361 uid=1000 auid=1000 ses=3 msg=‘op=PAM:session_open grantors=pam_keyinit,pam_limits,pam_keyinit,pam_limits,pam_systemd,pam_unix acct=“root” exe=“/usr/bin/sudo” hostname=dom0 addr=? terminal=/dev/pts/5 res=success’
Jun 07 15:09:48 dom0 sudo[8361]: pam_unix(sudo:session): session opened for user root(uid=0) by user(uid=1000)
Jun 07 15:09:48 dom0 systemd[8365]: Dependency failed for wireplumber.service - Multimedia Service Session Manager.
Jun 07 15:09:48 dom0 systemd[8365]: wireplumber.service: Job wireplumber.service/start failed with result ‘dependency’.
Jun 07 15:09:48 dom0 systemd[8365]: pipewire-pulse.service - PipeWire PulseAudio was skipped because of an unmet condition check (ConditionUser=!root).
Jun 07 15:09:48 dom0 dbus-broker-launch[8376]: Ready
Jun 07 15:09:48 dom0 gnome-keyring-daemon[8380]: GNOME_KEYRING_CONTROL=/run/user/0/keyring
Jun 07 15:09:48 dom0 systemd[8365]: Finished unity-gtk-module.service - Unity GTK Module Environment variables.
Jun 07 15:09:48 dom0 systemd[8365]: Reached target default.target - Main User Target.
Jun 07 15:09:48 dom0 systemd[8365]: Startup finished in 351ms.
Jun 07 15:09:48 dom0 sudo[8361]: pam_unix(sudo:session): session closed for user root
Jun 07 15:09:48 dom0 audit[8361]: USER_END pid=8361 uid=1000 auid=1000 ses=3 msg=‘op=PAM:session_close grantors=pam_keyinit,pam_limits,pam_keyinit,pam_limits,pam_systemd,pam_unix acct=“root” exe=“/usr/bin/sudo” hostname=dom0 addr=? terminal=/dev/pts/5 res=success’
Jun 07 15:09:48 dom0 audit[8361]: CRED_DISP pid=8361 uid=1000 auid=1000 ses=3 msg=‘op=PAM:setcred grantors=pam_env,pam_fprintd acct=“root” exe=“/usr/bin/sudo” hostname=dom0 addr=? terminal=/dev/pts/5 res=success’
Jun 07 15:09:48 dom0 systemd[1]: session-c16.scope: Deactivated successfully.
Jun 07 15:09:48 dom0 systemd-logind[3102]: Session c16 logged out. Waiting for processes to exit.
Jun 07 15:09:48 dom0 systemd-logind[3102]: Removed session c16.
Jun 07 15:09:58 dom0 kernel: exFAT-fs (sda4): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
Jun 07 15:09:58 dom0 udisksd[3103]: Mounted /dev/sda4 at /run/media/user/New Volume on behalf of uid 1000
Jun 07 15:09:59 dom0 systemd[1]: Stopping user@0.service - User Manager for UID 0…
Jun 07 15:09:59 dom0 systemd[8365]: Activating special unit exit.target…
Jun 07 15:09:59 dom0 systemd[8365]: Stopped target default.target - Main User Target.
Jun 07 15:09:59 dom0 systemd[8365]: Stopping gnome-keyring-daemon.service - GNOME Keyring daemon…
Jun 07 15:09:59 dom0 systemd[8365]: Stopping unity-gtk-module.service - Unity GTK Module Environment variables…
Jun 07 15:09:59 dom0 systemd[8365]: Stopped gnome-keyring-daemon.service - GNOME Keyring daemon.
Jun 07 15:09:59 dom0 systemd[8365]: Stopped unity-gtk-module.service - Unity GTK Module Environment variables.
Jun 07 15:09:59 dom0 systemd[8365]: Stopped target basic.target - Basic System.
Jun 07 15:09:59 dom0 systemd[8365]: Stopped target paths.target - Paths.
Jun 07 15:09:59 dom0 systemd[8365]: Stopped target sockets.target - Sockets.
Jun 07 15:09:59 dom0 systemd[8365]: Stopped target timers.target - Timers.
Jun 07 15:09:59 dom0 systemd[8365]: Stopped systemd-tmpfiles-clean.timer - Daily Cleanup of User’s Temporary Directories.
Jun 07 15:09:59 dom0 systemd[8365]: Closed dirmngr.socket - GnuPG network certificate management daemon.
Jun 07 15:09:59 dom0 systemd[8365]: Closed gnome-keyring-daemon.socket - GNOME Keyring daemon.
Jun 07 15:09:59 dom0 systemd[8365]: Closed gpg-agent-browser.socket - GnuPG cryptographic agent and passphrase cache (access for web browsers).
Jun 07 15:09:59 dom0 systemd[8365]: Closed gpg-agent-extra.socket - GnuPG cryptographic agent and passphrase cache (restricted).
Jun 07 15:09:59 dom0 systemd[8365]: Closed gpg-agent-ssh.socket - GnuPG cryptographic agent (ssh-agent emulation).
Jun 07 15:09:59 dom0 systemd[8365]: Closed gpg-agent.socket - GnuPG cryptographic agent and passphrase cache.
Jun 07 15:09:59 dom0 systemd[8365]: Closed ssh-agent.socket - OpenSSH key agent.
Jun 07 15:09:59 dom0 dbus-broker[8379]: Dispatched 312 messages @ 2(±5)μs / message.
Jun 07 15:09:59 dom0 systemd[8365]: Stopping dbus-broker.service - D-Bus User Message Bus…
Jun 07 15:09:59 dom0 systemd[8365]: Stopped systemd-tmpfiles-setup.service - Create User Files and Directories.
Jun 07 15:09:59 dom0 systemd[8365]: Stopped dbus-broker.service - D-Bus User Message Bus.
Jun 07 15:09:59 dom0 systemd[8365]: Removed slice session.slice - User Core Session Slice.
Jun 07 15:09:59 dom0 systemd[8365]: Closed dbus.socket - D-Bus User Message Bus Socket.
Jun 07 15:09:59 dom0 systemd[8365]: Removed slice app.slice - User Application Slice.
Jun 07 15:09:59 dom0 systemd[8365]: Reached target shutdown.target - Shutdown.
Jun 07 15:09:59 dom0 systemd[8365]: Finished systemd-exit.service - Exit the Session.
Jun 07 15:09:59 dom0 systemd[8365]: Reached target exit.target - Exit the Session.
Jun 07 15:09:59 dom0 systemd-logind[3102]: Removed session 7.
Jun 07 15:09:59 dom0 systemd[1]: user@0.service: Deactivated successfully.
Jun 07 15:09:59 dom0 systemd[1]: Stopped user@0.service - User Manager for UID 0.
Jun 07 15:09:59 dom0 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=user@0 comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
Jun 07 15:09:59 dom0 kernel: kauditd_printk_skb: 100 callbacks suppressed
Jun 07 15:09:59 dom0 kernel: audit: type=1131 audit(1780859399.097:489): pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=user@0 comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
Jun 07 15:09:59 dom0 systemd[1]: Stopping user-runtime-dir@0.service - User Runtime Directory /run/user/0…
Jun 07 15:09:59 dom0 systemd[1]: run-user-0.mount: Deactivated successfully.
Jun 07 15:09:59 dom0 systemd[1]: user-runtime-dir@0.service: Deactivated successfully.
Jun 07 15:09:59 dom0 systemd[1]: Stopped user-runtime-dir@0.service - User Runtime Directory /run/user/0.
Jun 07 15:09:59 dom0 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=user-runtime-dir@0 comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
Jun 07 15:09:59 dom0 kernel: audit: type=1131 audit(1780859399.122:490): pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=user-runtime-dir@0 comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
Jun 07 15:09:59 dom0 systemd[1]: Removed slice user-0.slice - User Slice of UID 0.
Jun 07 15:09:59 dom0 systemd[1]: user-0.slice: Consumed 550ms CPU time, 71.4M memory peak.
Jun 07 15:10:10 dom0 kwin_x11[6980]: kwin_core: XCB error: 152 (BadDamage), sequence: 20470, resource id: 16836020, major code: 143 (DAMAGE), minor code: 2 (Destroy)
Jun 07 15:10:10 dom0 kwin_x11[6980]: kwin_core: XCB error: 3 (BadWindow), sequence: 20471, resource id: 83967026, major code: 129 (SHAPE), minor code: 6 (Input)
Jun 07 15:10:13 dom0 systemd[6757]: Started dbus-:1.1-org.xfce.Xfconf@2.service.
Jun 07 15:10:13 dom0 systemd[6757]: Starting tumblerd.service - Thumbnailing service…
Jun 07 15:10:13 dom0 systemd[6757]: Started tumblerd.service - Thumbnailing service.
This was right before the freeze, I have shared this with a ai chatbot and it said i should hide my Nvidia Rtx gpu from dom0
Do you guys think this will work?
Hi, it looks like the part you pasted is all from boot up, and I think you’re more interested in what happens near the end of the journal, before/during the freeze. That said:
(Probably not related to the freeze, though)
Probabilistically speaking it’s not a terrible guess that the GPU would have something to do with a hard-freeze problem, on any platform. :slightly_smiling_face:
Thanks — you’re right that most of what I pasted is session startup. The freeze evidence I think is actually this line at 15:09:59, right before an 11-second log gap:
Then after 11 seconds of nothing, kwin XCB BadDamage + BadWindow errors appear at 15:10:10. My guess (and someone else suggested this too) is that the RTX 5070 being exposed to dom0 without a real driver is causing nouveau to thrash and flood the audit subsystem. Planning to try rd.qubes.hide_pci + nouveau.modeset=0 to hide it from dom0 entirely. Hardware is ASUS ROG Zephyrus G16 2025, Intel Core Ultra 9, RTX 5070, Qubes 4.3 latest kernel.
This is what my ai told me to say
And the unmount was a extra partition on my external usb so that i could extract the logs from dom0 to my other pc so i can copy paste it here so i dont think that has anything to do with the freezes
Also ive talked to another person with the exact same laptop with all the same specs and also bought from the same store and he also has all the exact same issues on Qubes os
So just to clarify, the freeze in this example happened very soon after boot up?
This time it did but most of the times it just happens randomly like very random like when im not even touching the screen sometimes when the screen is off like fully black, it is extremely random
It happens like 1-3 times a day
I just did the gpu hiding thing and my entire system does seem to be way faster at booting etc i havent had any freezes or anything yet but theres 1 issue now
My laptop is getting very hot at idle
These are the commands i used for hiding the gpu
sudo nano /etc/default/grub
rd.qubes.hide_pci=01:00.0,01:00.1 nouveau.modeset=0 rd.driver.blacklist=nouveau
Then after i tried this for disabling my gpu
echo auto | sudo tee /sys/bus/pci/devices/0000:01:00.0/power/control
sudo nano /etc/udev/rules.d/99-nvidia-powersave.rules
ACTION==“add”, SUBSYSTEM==“pci”, ATTR{vendor}==“0x10de”, ATTR{power/control}=“auto”
sudo udevadm control --reload-rules && sudo udevadm trigger
And when i typed
cat /sys/bus/pci/devices/0000:01:00.0/power/runtime_status
It did still say active and my laptop was still very hot
Might be worthwhile to take a look at the ends of the journals for a couple of the other instances of freezing and see if they reveal something more. I feel the GPU as culprit is still a guess at this point, whatever the chatbot said (but again, not a terrible guess).
Is this an old issue or is it new after the system tweaks? And not related to the system simply being up longer now?
Yeah after i did the gpu hiding
So after i removed my gpu my system became a lot faster but the random freezes still happen
I still think your best bet is to look at the ends of journalctl -b -1 (-1 meaning previous boot, -2 meaning the boot before that, …) after a freeze and see if there are any suggestive log lines.
Jun 09 10:05:11 dom0 kernel: [Firmware Bug]: CPU 1: APIC ID mismatch. CPUID: 0x0001 APIC: 0x0008
Jun 09 10:05:11 dom0 kernel: [Firmware Bug]: CPU 2: APIC ID mismatch. CPUID: 0x0002 APIC: 0x0010
Jun 09 10:05:11 dom0 kernel: [Firmware Bug]: CPU 2: APIC ID mismatch. Firmware: 0x0020 APIC: 0x0010
Jun 09 10:05:11 dom0 kernel: [Firmware Bug]: CPU 3: APIC ID mismatch. CPUID: 0x0003 APIC: 0x0012
Jun 09 10:05:11 dom0 kernel: [Firmware Bug]: CPU 3: APIC ID mismatch. Firmware: 0x0028 APIC: 0x0012
Jun 09 10:05:11 dom0 kernel: [Firmware Bug]: CPU 4: APIC ID mismatch. CPUID: 0x0004 APIC: 0x0014
Jun 09 10:05:11 dom0 kernel: [Firmware Bug]: CPU 4: APIC ID mismatch. Firmware: 0x0030 APIC: 0x0014
Jun 09 10:05:11 dom0 kernel: [Firmware Bug]: CPU 5: APIC ID mismatch. CPUID: 0x0005 APIC: 0x0016
Jun 09 10:05:11 dom0 kernel: [Firmware Bug]: CPU 5: APIC ID mismatch. Firmware: 0x0038 APIC: 0x0016
Jun 09 10:05:11 dom0 kernel: [Firmware Bug]: CPU 6: APIC ID mismatch. CPUID: 0x0006 APIC: 0x0018
Jun 09 10:05:11 dom0 kernel: [Firmware Bug]: CPU 6: APIC ID mismatch. Firmware: 0x0010 APIC: 0x0018
Jun 09 10:05:11 dom0 kernel: [Firmware Bug]: CPU 7: APIC ID mismatch. CPUID: 0x0007 APIC: 0x001a
Jun 09 10:05:11 dom0 kernel: [Firmware Bug]: CPU 7: APIC ID mismatch. Firmware: 0x0012 APIC: 0x001a
Jun 09 10:05:11 dom0 kernel: [Firmware Bug]: CPU 8: APIC ID mismatch. CPUID: 0x0008 APIC: 0x001c
Jun 09 10:05:11 dom0 kernel: [Firmware Bug]: CPU 8: APIC ID mismatch. Firmware: 0x0014 APIC: 0x001c
Jun 09 10:05:11 dom0 kernel: [Firmware Bug]: CPU 9: APIC ID mismatch. CPUID: 0x0009 APIC: 0x001e
Jun 09 10:05:11 dom0 kernel: [Firmware Bug]: CPU 9: APIC ID mismatch. Firmware: 0x0016 APIC: 0x001e
Jun 09 10:05:11 dom0 kernel: [Firmware Bug]: CPU 10: APIC ID mismatch. CPUID: 0x000a APIC: 0x0020
Jun 09 10:05:11 dom0 kernel: [Firmware Bug]: CPU 10: APIC ID mismatch. Firmware: 0x0018 APIC: 0x0020
Jun 09 10:05:11 dom0 kernel: [Firmware Bug]: CPU 11: APIC ID mismatch. CPUID: 0x000b APIC: 0x0028
Jun 09 10:05:11 dom0 kernel: [Firmware Bug]: CPU 11: APIC ID mismatch. Firmware: 0x001a APIC: 0x0028
Jun 09 10:05:11 dom0 kernel: [Firmware Bug]: CPU 12: APIC ID mismatch. CPUID: 0x000c APIC: 0x0030
Jun 09 10:05:11 dom0 kernel: [Firmware Bug]: CPU 12: APIC ID mismatch. Firmware: 0x001c APIC: 0x0030
Jun 09 10:05:11 dom0 kernel: [Firmware Bug]: CPU 13: APIC ID mismatch. CPUID: 0x000d APIC: 0x0038
Jun 09 10:05:11 dom0 kernel: [Firmware Bug]: CPU 13: APIC ID mismatch. Firmware: 0x001e APIC: 0x0038
Jun 09 10:05:11 dom0 kernel: [Firmware Bug]: CPU 14: APIC ID mismatch. CPUID: 0x000e APIC: 0x0040
Jun 09 10:05:11 dom0 kernel: [Firmware Bug]: CPU 15: APIC ID mismatch. CPUID: 0x000f APIC: 0x0042
Jun 09 10:05:12 dom0 kernel: intel_vpu 0000:00:0b.0: [drm] ERROR ivpu_fw_request(): Failed to request firmware: -2
Jun 09 10:05:12 dom0 kernel: intel_vpu 0000:00:0b.0: probe with driver intel_vpu failed with error -2
Jun 09 10:05:13 dom0 kernel: tmpfs: Unsupported parameter ‘huge’
Jun 09 14:05:29 dom0 kernel: Bluetooth: hci0: Failed to load Intel firmware file intel/ibt-0093-0291.sfi (-2)
Jun 09 14:05:29 dom0 kernel: Bluetooth: hci0: Failed to read MSFT supported features (-56)
Jun 09 14:05:30 dom0 xenstored[2587]: Checking store …
Jun 09 14:05:30 dom0 xenstored[2587]: Checking store complete.
Jun 09 14:05:33 dom0 dbus-broker-launch[4168]: Ignoring duplicate name ‘org.freedesktop.Notifications’ in service file ‘/usr/share/dbus-1/services/org.xfce.xfce4-notifyd.Notifications.service’
Jun 09 14:05:45 dom0 sddm-helper[4716]: gkr-pam: unable to locate daemon control file
Jun 09 14:05:45 dom0 dbus-broker-launch[4795]: Ignoring duplicate name ‘org.freedesktop.Notifications’ in service file ‘/usr/share/dbus-1/services/org.xfce.xfce4-notifyd.Notifications.service’
Jun 09 14:05:45 dom0 sddm-helper[4716]: gkr-pam: the password for the login keyring was invalid.
Jun 09 14:05:51 dom0 dbus-broker-launch[5388]: Ignoring duplicate name ‘org.freedesktop.Notifications’ in service file ‘/usr/share/dbus-1/services/org.xfce.xfce4-notifyd.Notifications.service’
Jun 09 14:06:24 dom0 virtxend[3188]: invalid argument: network device with mac 00:16:3e:5e:6c:00 already exists
Jun 09 14:06:56 dom0 virtxend[3188]: internal error: libxenlight failed to create new domain ‘chat’
Jun 09 21:45:37 dom0 dbus-broker-launch[11096]: Ignoring duplicate name ‘org.freedesktop.Notifications’ in service file ‘/usr/share/dbus-1/services/org.xfce.xfce4-notifyd.Notifications.service’
Jun 09 21:56:42 dom0 dbus-broker-launch[11350]: Ignoring duplicate name ‘org.freedesktop.Notifications’ in service file ‘/usr/share/dbus-1/services/org.xfce.xfce4-notifyd.Notifications.service’
Jun 09 21:57:02 dom0 dbus-broker-launch[11396]: Ignoring duplicate name ‘org.freedesktop.Notifications’ in service file ‘/usr/share/dbus-1/services/org.xfce.xfce4-notifyd.Notifications.service’
Jun 09 21:58:47 dom0 dbus-broker-launch[11443]: Ignoring duplicate name ‘org.freedesktop.Notifications’ in service file ‘/usr/share/dbus-1/services/org.xfce.xfce4-notifyd.Notifications.service’
Jun 09 22:03:28 dom0 dbus-broker-launch[11516]: Ignoring duplicate name ‘org.freedesktop.Notifications’ in service file ‘/usr/share/dbus-1/services/org.xfce.xfce4-notifyd.Notifications.service’
Jun 09 22:06:06 dom0 dbus-broker-launch[11935]: Ignoring duplicate name ‘org.freedesktop.Notifications’ in service file ‘/usr/share/dbus-1/services/org.xfce.xfce4-notifyd.Notifications.service’
Jun 09 22:07:01 dom0 dbus-broker-launch[12219]: Ignoring duplicate name ‘org.freedesktop.Notifications’ in service file ‘/usr/share/dbus-1/services/org.xfce.xfce4-notifyd.Notifications.service’
