Qubes OS Overhauling Questions
I’ve been wondering if it’s possible to switch the distro used for Dom0, as I dislike Fedora pretty heavily, as well as it being extremely hard to minimize in terms of packages count. If it’s not possible, is there any way to build a version of Qubes to use a different dom0? If that’s not possible, is there at least any effort going into there being multiple dom0 options?
Ideally, I want to use something like Alpine or Gentoo for dom0, as I can minimize it as much as possible. If not, what are my other options for doing so?
How far do you want to overhaul Qubes OS?
Honestly? I want to change the majority of what Qubes is based on, in terms of templates and dom0. I already changed the desktop environment to KDE Plasma, but might go a step further and make a separate GUI qube to not have dom0 as heavy as it is with KDE in it when I get the chance.
I already changed to using custom debian-13-kde templates, but I’ve been dissatisfied with both Debian and Fedora in general, so I want to use something like Void or Gentoo for my templates. I don’t know if there’s a hard-built reliance on systemd, but if there is, then I would probably change my template list to accommodate that.
Since they aren’t officially offered yet, though, I might either do a manual Void install through its iso, or I might try using the Qubes builder to do Gentoo. I would just use the archlinux template, but it comes pre-conditioned with xfce unless built manually, and I’m not a fan of Arch in general, especially where I want a (somewhat) reliable system.
I would most likely change dom0 to be Alpine, Tiny Core, or something extremely minimal, if possible. If I can’t, then Debian would suffice, as long as I don’t have to mess with it often. I just dislike using Fedora due to the extremely slow package speeds, poor experiences with it in the past (I tend to have a much easier time building my own systems from scratch/near scratch than trimming an already existing system to my specifications).
All in all, though, it’s more of a project than anything actually serious. I do have a legitimate use case for Qubes, though. I use it for public networks as I don’t want to use a regular distro on potentially sketchy networks. Also opening potentially malicious USBs/Storage Volumes for investigation/data retrieval.
If all of the stuff that I’m asking for is crazy or excessive, which it honestly probably is, then I would most likely stick with my setup as it is. I’m mostly just trying to see if I can get it to work in the way that I’m envisioning. Since I typically use Gentoo on my other systems, having the ability to do all of this would make my experience using Qubes nearly seamless with Gentoo, excluding all of the virtualization.
Okay, start with this:
Also, see https://spectrum-os.org/
The only thing that would make sense is switching to declarative (nixOS). Another “normal” distribution is matter of taste and waste of time.
Related:
Alright, made a bit of headway, and backed up the data that I got from gentoo-minimal. I
I want to ask about sys-gui-gpu, as I haven’t had success with it yet. I’ve gotten to the point where I (sometimes) have a bootable sys-gui-gpu, but the screen is extremely dark and unusable. Additionally, it never launches on boot, even after assigning the PCI device to the sys-gui-gpu qube alongside and setting default_guide to sys-gui-gpu.
Any relevant logs I should be reading through, or any troubleshooting steps I can try? I will try literally anything since I ended up just using my USB to reinstall QubesOS as I wanted to wipe the slate clean for sys-gui-gpu
Edit: for reference since it seemed very relevant, I am on a corebooted (SeaBIOS) Thinkpad T580, i7-8550u, no dGPU module. I do have a working thunderbolt port on my model as well, if that’s also relevant as a PCI device?
