Hi guys,
I’m dealing with the firewall limitations in Qubes OS. I’ve noticed that when I add a domain to restrict outgoing traffic, it sometimes works and sometimes doesn’t. I think this is because DNS resolution only happens when the VM starts, so if the IPs change afterward, it stops working properly — is that correct?
How do you handle this? For example, if I have a VM dedicated to accessing a specific website, I’d like to make sure it can only access that site.
Thanks!
Did you have a look at this?
I’ve just wrote this, you might be interested
Thank you, im going to look it.
Yes i saw it, but don’t like it very much
