Qubes OS documentation
Don’t forgot to check out the Qubes OS documentation. If you’d like to contribute to it, it is accessible on Github here and review the contributing guidelines.
been using qubes for a couple weeks now, about a week as a daily driver, and i have been spending quite a bit of time with the documentation, as well as fumbling my way through figuring out how to adapt my workflow to qubes. while the documentation has been extremely helpful in most situtations i’ve run in to, i find myself thinking that if the internal documentation was fleshed out a bit ( i.e. tooltips and ?/help boxes ) it would definitely ease the slope of the learning curve. i sometimes find the wording in the dialog boxes to be ambiguous as well. is there an appropriate way to submit these suggestions? should i just file bug requests with screenshots of what i’m talking about? or start a forum thread?
Good stuff.
My preference would be for the discussion to take place here or in the
qubes-devel mailing list, so that a fleshed out proposal can be put to
GitHub.
If you look at qubes-issues you will see that there are some issues
that get completely bogged down in bike shedding, and never reach a
conclusion.
That’s my preference.
Tell me, is there any reasonable explanation for the disappearance of the Custom installation section from the Documentation section of the site today?
From the GitHub repo:
@andrewdavidwong
It says that the outdated content of the page was misleading.
Could you explain what was wrong with the page?
@andrewdavidwong can reply in detail, if he wishes.
My perception is that the page was outdated and there were a number of
issues raised about the content.
No one stepped up to deal with those issues, or provide improvements to
those pages.
Andrew took the not unreasonable decision that it was better to have
nothing, rather than something that contained numerous errors.
The documentation is a collaborative exercise, and any one can make
suggestions or improvements to it.
Unfortunately, very few users do this.
If any one wants to provide input to the section on Custom
Installation, then the old material can be found in Git history.
Thank you for your response
now i’m scared of what kind of errors i have in my system if i installed it according to this manual?
It’s not likely that you have any errors if you successfully
installed Qubes.
The commit message, which @ChrisA helpfully linked, and @unman’s post both explain the situation clearly. You can also read this thread for even more context:
If there is still something unclear, please be specific about what exactly is unclear, and I will do my best to clarify.
As far as I know, you couldn’t have followed those instructions when installing Qubes 4.1, since the installer had changed so much, which is why that page was so problematic.
thank you for your answer
indeed, when I first tried to install the system according to that instruction, I failed and then I slightly changed the installation, leaving the partitioning and encryption proposed in it, and somehow I already forgot that I did not follow this instruction “word-for-word”
Documentation is too old. Its very difficult to install it. We need more video tutorials! Much more!
Want to help us make some? :slight_smile:
@adw Would there ever be an interest to coordinate an in-person or online training boot camp? Something you could charge for obviously, but trying to pull together those most knowledgeable to demonstrate setup/configuration/best practices and various use cases. In turn, allowing the attendees to help distribute that knowledge if they choose to do so.
EDIT: I guess I should have read the website news a little more. :wink:
https://www.qubes-os.org/news/2023/08/25/qubes-os-summit-2023/
I don’t think the Qubes Summits are exactly what you described, but they’re probably the closest thing to it for now. I suppose this forum also serves some of the functions you have in mind (but asynchronously).
One item is “Network” for initial installation. There are extreme details in the installation instructions (including how to spot a BIOS…) but after basic installation it just says: have fun with your new system - but without any network access. Next is “update” - but again, without any network?
There is documentation for network access I have found and read but I find it more “developer level” than user.
It would be useful to equip a basic new installation with a default (recommended) setup which would also benefit security - because if I get started “hacking” my way through this I would likely build in multiple violations of the principles which Qubes is meant for in the first place.
Well, that’s because networking is just supposed to work automatically out of the box without the user having to do anything special (and, for most users, it does). If networking doesn’t work automatically, it’s probably due to a bug, such as some kind of hardware incompatibility.
Yes, that’s what I figured - but when that happens (like in my case), I find it too difficult to find out why - and as said before, I don’t have a problem fixing this sort of thing in “normal” Linux, done countless times. Some basic description of the elements, where to find them, what to look for would be useful.
It’s why there’s this forum, to help others to find a solution to their problems :wink:
Open a topic with your problems and if someone could help you, He will certainly do it.
If it is a hardware trouble, difficult to put it in documatation. But if your trouble with your hardware is resolve here, so others people who have the same trouble with the same hardware could find the resolve here :slight_smile:
