Qubes OS 4.3 started freezing
Recently, my system has been freezing completely, leaving me unable to use the keyboard or mouse. This has happened twice in the past three days, and I can’t recall any similar problems before this.
I suspect this might be related to some updates I applied recently. When the freeze occurs, the screen locks up, and nothing responds. I’ve tried waiting it out, but no change occurs, requiring me to perform a hard reboot.
How can I debug this issue to figure out what’s happening? When the computer is in that state, I don’t think there is anything I can do.
Is the computer fan speeding at maximum speed?
Could you try to play some sound, and see if it loops into a “BZZZZZZZZZZZZZ” or if it stops entirely? First case, it’s certainly a hardware issue, latter case, more likely to be a software/driver bug.
I don’t know if it was maximum, but the fan were running fast as if the computer was doing heavy work, so it may have been.
I don’t know how to reproduce it, so I can’t test, I didn’t notice either happening yet.
My hardware was purchased in 2022 if that matters, so it is rather new and hopefully not failing.
I noticed why it happens: if I unplug my headphones (3.5mm jack) Qubes OS will freeze in 1-2 hours.
What can I do with this information?
Currently I have similar problems with Qubes OS completly freezing. Sometimes shortly after a freeze I can set up some SysRq commands to sync and write some logs. After a reboot I was able to see some error messages inside journal
dom0 virtextend[2554]: internal error: connection closed due to keepalive timeout
dom0 kernel: rcu: INFO: rcu_preempt detected stalls on CPUs/tasks:
Usually it freezes during idle time almost every day.
I had several installations with 4.3 RCs which didn’t bring up any freezes at all. Since I was installing a fresh 4.3.0 and updating all packages it started to freeze after some time.
At the moment I am investigation this issue with two machines with identical hardware (AMD Ryzen 7 5800x + Nvidia GPU). After a fresh installation of 4.3.0 so far it’s stable without any freezes. I already played with different kernel versions but I think it’s one of the firmware packages, maybe amd-gpu-firmware, nvidia-gpu-firmware or amd-ucode-firmware.
Can you tell me how to do this? After freeze, the only thing I can do is hard reboot and fsck the disk.
However, for me the freezes only happen after I unplug my headphones. If I plug them back in, it still happens. But I notice if I never unplug them the freeze never happens.
How long do you have kept the system running with plugged in headphones? The 3.5mm jack should not have anything to do with the freezing in my opinion, but I could be wrong.
To set up some SysRq commands see following wiki entry: Magic SysRq key - Wikipedia
For example press [Alt]+[SysRq]b to sync the filesystems.
A long time, 24+ hours many times.
I thought it had to do with an update, but I only recently have a new usecase where I’m using two PCs. This is why I’ve started moving my headphones between the two computers.
I’ve noticed that the freeze only happens when I unplug my headphones and use the other PC. I haven’t been present a single time during a freeze, which is why I still can’t answer solene’s question.
I am not 100% certain either, but it seems to correlate heavily with unplugging my headphones. It never happened before, and so far I only notice it within an 1-2 hour window of me unplugging them.
I will try this, thanks.
It happened again. Computer works all day, unplug headphones, 30 minutes later the fan was loud and the entire OS had frozen.
I still have zero logs indicating a problem, but I did not have time to configure SysRq yet.
Weird question: are you using usb headphones with an audiovm?
Since everything locks up, have you had a chance to check the logs after a hard reboot? Running sudo journalctl -b -1 -p 0…3 in dom0 might show if there was a ‘last gasp’ error message (like a kernel panic or GPU hang) before it died. Also, are you on the latest kernel? Sometimes switching between the stable and kernel-latest packages helps with these random 4.3 freezes.
I just wanted to give an update on solving the problem with freezing Qubes OS. In my case it was a bug on AMD CPUs with improper C-state (power management) handling. The freezes disappeared after changing two settings inside BIOS:
I have set “Power Supply Idle Control” to " Typical Current Idle" and disabled “Global C-state Control”
Thanks @haggis. I’ve had crashes sometimes, too. Once you’ve set these options in the BIOS, everything is fine.
@michalzienia Great to hear that it’s working on your side, too
Hardware or firmware, I had that with beta Dasharo firmware, but with a stable version it’s fine.
