The first release candidate (RC) for Qubes OS 4.3.2 is now available for testing. This patch release aims to consolidate all the security patches, bug fixes, and other updates that have occurred since the release of Qubes 4.3.1.
What’s new in Qubes 4.3.2?
- Default Fedora template upgraded to Fedora 44
kernel-latestupgraded to Linux 7.2- Numerous bug fixes
When is the stable release?
That depends on the number of bugs discovered in this RC and their severity. As explained in our release schedule documentation, our usual process after issuing a new RC is to collect bug reports, triage the bugs, and fix them. If warranted, we then issue a new RC that includes the fixes and repeat the process. We continue this iterative procedure until we’re left with an RC that’s good enough to be declared the stable release. No one can predict with certainty, at the outset, how many iterations will be required (and hence how many RCs will be needed before a stable release), but we tend to get a clearer picture of this as testing progresses.
Since the changes between 4.3.1 and 4.3.2 are relatively minor, we currently don’t anticipate any major problems requiring a second RC. We currently expect to be able to publish the stable 4.3.2 release around the end of September.
How to test Qubes 4.3.2-rc1
If you’d like to help us test this RC, the best way to do so is by performing a clean installation with the new ISO. As always, we strongly recommend making a full backup beforehand and updating Qubes OS immediately afterward in order to apply all available bug fixes.
As an alternative to a clean installation, there’s also the option of performing an in-place upgrade without reinstalling. However, since Qubes 4.3.2 is a patch release, it’s essentially Qubes 4.3 inclusive of all updates to date, which largely amounts to just using a fully-updated 4.3 installation. By contrast, a clean installation covers other areas that could also benefit from testing, such as the installation procedure, which is why it’s the recommended testing method.
Regardless of your testing method, please help us improve the eventual stable release by reporting any bugs you encounter. If you’re an experienced user, we encourage you to join the testing team.
Known issues in Qubes OS 4.3.2
It’s possible that templates restored in 4.3.2 from a pre-4.3 backup may continue to target their original Qubes OS release repos (#8701). After restoring such templates in 4.3.2, enter the following additional commands in a dom0 terminal:
sudo qubes-dom0-update -y qubes-dist-upgrade
sudo qubes-dist-upgrade --releasever=4.3 --template-standalone-upgrade -y
This will automatically choose the templates that need to be upgraded. The templates will be shut down during this process.
Fresh templates on a clean 4.3.2 installation are not affected. Users who perform an in-place upgrade from 4.2 to 4.3 (instead of restoring templates from a backup) are also not affected, since the in-place upgrade process already includes the above fix in stage 4. For more information, see issue #8701.
View the full list of known bugs affecting Qubes 4.3 in our issue tracker.
What’s a release candidate?
A release candidate (RC) is a software build that has the potential to become a stable release, unless significant bugs are discovered in testing. RCs are intended for more advanced (or adventurous!) users who are comfortable testing early versions of software that are potentially buggier than stable releases. You can read more about Qubes OS supported releases and the version scheme in our documentation.
What’s a patch release?
The Qubes OS Project uses the semantic versioning standard. Version numbers are written as [major].[minor].[patch]. Hence, we refer to releases that increment the third number as “patch releases.” A patch release does not designate a separate, new major or minor release of Qubes OS. Rather, it designates its respective major or minor release (in this case, 4.3) inclusive of all updates up to a certain point. See our supported releases for a comprehensive list of major and minor releases and our version scheme documentation for more information about how Qubes OS releases are versioned.
This is a companion discussion topic for the original entry at https://www.qubes-os.org/news/2026/09/18/qubes-os-4-3-2-rc1-available-for-testing/
