Hello,
Since upgrading from Qubes OS 4.2 to 4.3.1, I’ve been getting random system freezes. The freezes most often happen when launching a qube, though the behavior is inconsistent.
For example, starting sys-net will occasionally cause the entire system to become frozen (except for the cursor), while at other times the qube starts and functions normally, but the system freezes again after a while of casual use. I’ve also occasionally happen to encounter freezes outside the qubes, as, for example, running Xfce Terminal using interface in dom0. Interestingly, I can almost always boot the qubes normally if I first launch the Xfce Terminal in dom0, input any command in it and then start the fedora-43-xfce template.
Primarly, after decrypting the LUKS disk, the system would proceed to a black screen that only had a working cursor and no user login prompt. I was able to work around this by adding the qubes.skip_autostart parameter in the GRUB menu.
What I have tried (with no success):
- At first, I suspected the Wi-Fi card (RTL8822BE) might be causing the issue. However, replacing it with a new one (AX210) did not resolve the problem, and the freezes continued.
- I’ve reinstalled the system 3 times, including installation with the newer kernel version.
- I’ve tried changing the qubes template from
fedora-43-xfcetodebian-13-xfce.
I haven’t been able to point a consistent pattern or a reliable way to reproduce the issue. Any kind of help is appreciated.
Specification:
Model: Thinkpad A485,
CPU: Ryzen 5 Pro 2500U,
RAM: 16GB DDR4,
Kernel Version: 7.0.9-1 (tried it with 6.18.31-1, same result)
