Hello there,
In my appVM from Fedora-36 I followed the HowTo install snap, in order to install onlyoffice then. I managed to get the onlyoffice entry into the qubes menu, however clicking on it does not open the software.
Recreating the entry and experimenting with the fixing shortcuts did not help.
I can start the software from the appVM terminal with some warnings
[user@appVM ~]$ onlyoffice-desktopeditors
Warning: Schema “org.gnome.system.locale” has path “/system/locale/”. Paths starting with “/apps/”, “/desktop/” or “/system/” are deprecated.
Warning: Schema “org.gnome.system.proxy” has path “/system/proxy/”. Paths starting with “/apps/”, “/desktop/” or “/system/” are deprecated.
Warning: Schema “org.gnome.system.proxy.http” has path “/system/proxy/http/”. Paths starting with “/apps/”, “/desktop/” or “/system/” are deprecated.
Warning: Schema “org.gnome.system.proxy.https” has path “/system/proxy/https/”. Paths starting with “/apps/”, “/desktop/” or “/system/” are deprecated.
Warning: Schema “org.gnome.system.proxy.ftp” has path “/system/proxy/ftp/”. Paths starting with “/apps/”, “/desktop/” or “/system/” are deprecated.
Warning: Schema “org.gnome.system.proxy.socks” has path “/system/proxy/socks/”. Paths starting with “/apps/”, “/desktop/” or “/system/” are deprecated.
(DesktopEditors:1379): Gdk-CRITICAL **: 15:36:42.538: gdk_atom_intern: assertion 'atom_name != NULL' failed
and it opens and runs just fine…
What else can go wrong with these shortcuts, resulting in not starting/opening the actual software? Or is the Gdk-CRITICAL connected with the issue?
Thanks for the help in advance, hope you can support my first steps in QubesOS
clarinet
edit: snap link corrected
