I can’t find the logs that would tell me what is wrong either.
Here is what I do…
Click “New Qube”.
That’s it…
At that point the Qubes-Manager just vanishes.
I only have 83 qubes at the moment, so it’s not like I’m pushing things.
Root partition has 44 GB free, so no issue there for the operating system and all bases.
I have 30 MB FREE RAM for Dom0. (4GB Total set for it as it shouldn’t need much RAM at all.)
When the Qubes-Manager vanishes and dies, I have 200 MB free.
I run “Create Qubes VM” from the application menu, and it does nothing.
File "/usr/lib/python3.8/site-packages/qubesadmin/label.py", line 69, in index
qubesd_response = self.app.qubesd_call(
File "/usr/lib/python3.8/site-packages/qubesadmin/app.py", line 770, in qubesd_call
return self._parse_qubesd_response(return_data)
File "/usr/lib/python3.8/site-packages/qubesadmin/base.py", line 89, in _parse_qubesd_response
raise qubesadmin.exc.QubesDaemonAccessError(
qubesadmin.exc.QubesDaemonAccessError: Got empty response from qubesd. See journalctl in dom0 for details.
During handling of the above exception, another exception occurred:
File "/usr/lib/python3.8/site-packages/qubesmanager/qube_manager.py", line 1296, in action_createvm_triggered
create_window = create_new_vm.NewVmDlg(
File "/usr/lib/python3.8/site-packages/qubesmanager/create_new_vm.py", line 108, in __init__
utils.initialize_widget_with_labels(
File "/usr/lib/python3.8/site-packages/qubesmanager/utils.py", line 363, in initialize_widget_with_labels
labels = sorted(qubes_app.labels.values(), key=lambda l: l.index)
File "/usr/lib/python3.8/site-packages/qubesmanager/utils.py", line 363, in <lambda>
File "/usr/lib/python3.8/site-packages/qubesadmin/label.py", line 72, in index
raise qubesadmin.exc.QubesPropertyAccessError('label.index')
qubesadmin.exc.QubesPropertyAccessError: Failed to access 'label.index' property
Aborted (core dumped)
