Sometimes main toolbar dissapears when i click on it to open menu. Then after some time all open windows dissapears and only desktop image is visible. Need then a hard shutdown to restart the OS. Any ideas? How can I debug this? Dom0 is updated
You can try to open the dom0 terminal pressing Alt+F1 → Open Terminal Here.
You can then try to run the panel from the terminal using this command:
xfce4-panel --restart
And check the logs in dom0 using journalctl command in dom0 terminal to see why the panel crashed.
