Qubes OS is now successfully installed and ready for you to use!
Go ahead and reboot your system to start using it!
[Reboot System]
and after the reboot, you are asked to select between the boot-options:
Qubes, with Xen hypervisor
Advanced options for Qubes (with Xen hypervisor)
(?) - and after booting Qubes, you are asked to “Please complete items marked with this icon before continuing to the next step” (where you can select Templates Configuration)?
If you get the “select templates to install”, then it sounds like a normal install … where the first part creates the filesystem on the drive, copies the files for dom0 to the SSD and the reboots to finish the initial setup.
I installed just standard Debian, fedora and Whonix, but when they install I get an error message saying ‘error occured unpacking rpm package malcontent libs’, and then it makes me exit.
