Qubes installation not working please help 😕
Hi please help i m trying to install qubes for last 4 days tried everything nthg is working getting this error and nthg is working
I m sharing 2 screenshots 1. Is the installation options i m getting and even if i leave them as it is as defaults to go with it still not working giving me error
These are the options i m getting and even using defaults to start with doesnt work
Based on the templates versions it seems you’re installing the Qubes OS 4.1.
Can you install the latest Qubes OS 4.2.1 version?
Its the same error i get whatever version i try
Can you login into dom0 and try to start sys-net manually?
Since you’ve installed the Qubes OS on USB drive then if the drive is very slow It could be that the sys-net is failing to start because of timeout if it couldn’t start within 60 seconds.
You can increase the sys-net timeout and start it for a test. For this you need to run this command in dom0 terminal:
qvm-prefs sys-net qrexec_timeout 3600
There is no internet connection on qubes os i m using ethernet and tried to see even wifi can work but i dont see any internet 🛜 option on it i need to have internet working both ethernet and wifi
The internet is provided by sys-net qube. Your ethernet and wireless PCI controllers are attached to this VM and you need to run sys-net first to make internet work.
So when i start using the code u given it will start working do i need anything any command or way to start using internet i need wifi most of the time as ethernet cable is short
If the sys-net will start successfully and nothing will be wrong with your ethernet/wireless controller drivers/firmware then you’ll be able to start using the internet without any commands.
You’ll see the NetworkManager applet in the system tray where you’ll be able to connect to your wifi AP.
