Qubes in tmpfs 🤫
Juat to say a thank you, it does work but a bit of a challenge for me:
i setup dom0 with 32768 RAM value,as my laptop has 64Gb…irespective of boot selection yes or no,that value stays if persistent or not. Quite not practical if i chose to use ā€œpersistentā€ mode…
Any work around ?
And one more Q (too much Port tonight)… how the nech can i identify on which boot mode im running now… :slight_smile: !?
Again,appreciated your effort,im much obliged !
You must create templates in varlibqubes (it are created in the vm-pool by default), then you must create appVMs also in varlibqubes. Then the data will not be saved if you have entered all commands correctly.
See this comment Qubes in tmpfs 🤫 - #56 by qstateless
If someone wants to experiment with overlayfs, you can use this script as a starting point GitHub - fitu996/overlayRoot.sh: Read-only Root-FS for most linux distributions using overlayfs.
Wow! A more efficient way to run Qubes Live has been proposed on the Whonix forum! Whonix in live mode in Qubes OS! Amnesia and anti-forensics mode - #16 by bigboy - Support - Whonix Forum
Whonix and Kicksecure in Live Mode with OverlayFS in Qubes OS
Qubes in tmpfs :shushing_face: - #30 by qstateless - Community Guides - Qubes OS Forum - Method of copying to zram is very slow, less secure and has more limitations on memory usage in live mode than OverlayFS. With OverlayFS / filesystem will be read-only and launching in live mode will be very fast. and you will also have more free disk space. The original live mode in Whonix and Kicksecure works on OverlayFS.
Instructions ( do it in dom0):
  1. Disable Dom0 Swap:
sudo nano /etc/fstab
Using nano, type a # character in front of the line containing ā€œ/dev/mapper/qubes_dom0-swapā€, to comment it out and disable it, like this:
#/dev/mapper/qubes_dom0-swap ...
Press Ctrl + O and Enter
Press Ctrl + X to exit nano editor.
sudo swapoff -a
  1. Create a folder 90overlay-root in /usr/lib/dracut/modules.
    sudo mkdir /usr/lib/dracut/modules.d/90overlay-root
  2. Create two files module-setup.sh and overlay-mount.sh in this folder and make it executable.
sudo touch /usr/lib/dracut/modules.d/90overlay-root/module-setup.sh
sudo touch /usr/lib/dracut/modules.d/90overlay-root/overlay-mount.sh
sudo chmod 755 /usr/lib/dracut/modules.d/90overlay-root/module-setup.sh
sudo chmod 755 /usr/lib/dracut/modules.d/90overlay-root/overlay-mount.sh
  1. Open module-setup.sh
    sudo nano /usr/lib/dracut/modules.d/90overlay-root/module-setup.sh
    Add this code:
#!/bin/bash
check() {
    # do not add modules if the kernel does not have overlayfs support
    [ -d /lib/modules/$kernel/kernel/fs/overlayfs ] || return 1
depends() {
    # We do not depend on any modules - just some root
    return 0
# called by dracut
installkernel() {
    hostonly='' instmods overlay
install() {
    inst_hook pre-pivot 10 "$moddir/overlay-mount.sh"
  1. Open overlay-mount.sh
    sudo nano /usr/lib/dracut/modules.d/90overlay-root/overlay-mount.sh
    Add this code:
#!/bin/sh
# make a read-only nfsroot writeable by using overlayfs
# the nfsroot is already mounted to $NEWROOT
# add the parameter rootovl to the kernel, to activate this feature
. /lib/dracut-lib.sh
if ! getargbool 0 rootovl ; then
    return
fi
modprobe overlay
# a little bit tuning
mount -o remount,nolock,noatime $NEWROOT
# Move root
# --move does not always work. Google >mount move "wrong fs"< for
#     details
mkdir -p /live/image
mount --bind $NEWROOT /live/image
umount $NEWROOT
# Create tmpfs
mkdir /cow
mount -n -t tmpfs -o mode=0755,size=100% tmpfs /cow
mkdir /cow/work /cow/rw
# Merge both to new Filesystem
mount -t overlay -o noatime,lowerdir=/live/image,upperdir=/cow/rw,workdir=/cow/work,default_permissions overlay $NEWROOT
# Let filesystems survive pivot
mkdir -p $NEWROOT/live/cow
mkdir -p $NEWROOT/live/image
mount --bind /cow/rw $NEWROOT/live/cow
umount /cow
mount --bind /live/image $NEWROOT/live/image
umount /live/image
  1. Create a file dracut-lib.sh in lib and make it executable
sudo touch lib/dracut-lib.sh
sudo chmod 755 lib/dracut-lib.sh
And add this code:
#!/bin/sh
type wait_for_dev > /dev/null 2>&1 || . /lib/dracut-dev-lib.sh
export DRACUT_SYSTEMD
export NEWROOT
if [ -n "$NEWROOT" ]; then
    [ -d "$NEWROOT" ] || mkdir -p -m 0755 "$NEWROOT"
fi
# shellcheck disable=SC2153
if [ -z "$PREFIX" ]; then
    if ! [ -d /run/initramfs ]; then
        mkdir -p -m 0755 /run/initramfs/log
        ln -sfn /run/initramfs/log /var/log
    fi
    [ -d /run/lock ] || mkdir -p -m 0755 /run/lock
    [ -d /run/log ] || mkdir -p -m 0755 /run/log
fi
debug_off() {
    set +x
debug_on() {
    [ "$RD_DEBUG" = "yes" ] && set -x
# returns OK if $1 contains literal string $2 (and isn't empty)
strstr() {
    [ "${1##*"$2"*}" != "$1" ]
# returns OK if $1 matches (completely) glob pattern $2
# An empty $1 will not be considered matched, even if $2 is * which technically
# matches; as it would match anything, it's not an interesting case.
strglob() {
    [ -n "$1" -a -z "${1##$2}" ]
# returns OK if $1 contains (anywhere) a match of glob pattern $2
strglobin() {
    [ -n "$1" -a -z "${1##*$2*}" ]
# returns OK if $1 contains literal string $2 at the beginning, and isn't empty
str_starts() {
    [ "${1#"$2"*}" != "$1" ]
# returns OK if $1 contains literal string $2 at the end, and isn't empty
str_ends() {
    [ "${1%*"$2"}" != "$1" ]
trim() {
    local var="$*"
    var="${var#"${var%%[![:space:]]*}"}" # remove leading whitespace characters
    var="${var%"${var##*[![:space:]]}"}" # remove trailing whitespace characters
    printf "%s" "$var"
if [ -z "$DRACUT_SYSTEMD" ]; then
    warn() {
        check_quiet
        echo "<28>dracut Warning: $*" > /dev/kmsg
        echo "dracut Warning: $*" >&2
    info() {
        check_quiet
        echo "<30>dracut: $*" > /dev/kmsg
        if [ "$DRACUT_QUIET" != "yes" ]; then
            echo "dracut: $*" >&2
        fi
else
    warn() {
        echo "Warning: $*" >&2
    info() {
        echo "$*"
fi
vwarn() {
    while read -r line || [ -n "$line" ]; do
        warn "$line"
    done
vinfo() {
        info "$line"
    done
killall_proc_mountpoint() {
    local _pid
    local _killed=0
    for _pid in /proc/*; do
        _pid=${_pid##/proc/}
        case $_pid in
            *[!0-9]*) continue ;;
        esac
        [ -e "/proc/$_pid/exe" ] || continue
        [ -e "/proc/$_pid/root" ] || continue
        if strstr "$(ls -l -- "/proc/$_pid" "/proc/$_pid/fd" 2> /dev/null)" "$1"; then
            kill -9 "$_pid"
            _killed=1
        fi
    done
    return $_killed
getcmdline() {
    local _line
    local _i
    local CMDLINE_ETC_D
    local CMDLINE_ETC
    local CMDLINE_PROC
    unset _line
    if [ -e /etc/cmdline ]; then
        while read -r _line || [ -n "$_line" ]; do
            CMDLINE_ETC="$CMDLINE_ETC $_line"
        done < /etc/cmdline
    fi
    for _i in /etc/cmdline.d/*.conf; do
        [ -e "$_i" ] || continue
            CMDLINE_ETC_D="$CMDLINE_ETC_D $_line"
        done < "$_i"
    done
    if [ -e /proc/cmdline ]; then
            CMDLINE_PROC="$CMDLINE_PROC $_line"
        done < /proc/cmdline
    fi
    CMDLINE="$CMDLINE_ETC_D $CMDLINE_ETC $CMDLINE_PROC"
    printf "%s" "$CMDLINE"
getarg() {
    debug_off
    local _deprecated _newoption
    CMDLINE=$(getcmdline)
    export CMDLINE
    while [ $# -gt 0 ]; do
        case $1 in
            -d)
                _deprecated=1
                shift
            -y)
                if dracut-getarg "$2" > /dev/null; then
                    if [ "$_deprecated" = "1" ]; then
                        if [ -n "$_newoption" ]; then
                            warn "Kernel command line option '$2' is deprecated, use '$_newoption' instead."
                        else
                            warn "Option '$2' is deprecated."
                        fi
                    fi
                    echo 1
                    debug_on
                    return 0
                fi
                _deprecated=0
                shift 2
            -n)
                    echo 0
                            warn "Kernel command line option '$2' is deprecated, use '$_newoption=0' instead."
                        else
                        fi
                    fi
                    debug_on
                    return 1
                fi
                _deprecated=0
                shift 2
                if [ -z "$_newoption" ]; then
                    _newoption="$1"
                fi
                if dracut-getarg "$1"; then
                            warn "Kernel command line option '$1' is deprecated, use '$_newoption' instead."
                        else
                            warn "Option '$1' is deprecated."
                        fi
                    fi
                    debug_on
                    return 0
                fi
                _deprecated=0
                shift
        esac
    done
    debug_on
    return 1
# getargbool <defaultval> <args...>
# False if "getarg <args...>" returns "0", "no", or "off".
# True if getarg returns any other non-empty string.
# If not found, assumes <defaultval> - usually 0 for false, 1 for true.
# example: getargbool 0 rd.info
#   true: rd.info, rd.info=1, rd.info=xxx
#   false: rd.info=0, rd.info=off, rd.info not present (default val is 0)
getargbool() {
    local _b
    unset _b
    local _default
    _default="$1"
    shift
    _b=$(getarg "$@") || _b=${_b:-"$_default"}
    if [ -n "$_b" ]; then
        [ "$_b" = "0" ] && return 1
        [ "$_b" = "no" ] && return 1
        [ "$_b" = "off" ] && return 1
    fi
    return 0
isdigit() {
    case "$1" in
        *[!0-9]* | "") return 1 ;;
    esac
    return 0
# getargnum <defaultval> <minval> <maxval> <arg>
# Will echo the arg if it's in range [minval - maxval].
# If it's not set or it's not valid, will set it <defaultval>.
# Note all values are required to be >= 0 here.
# <defaultval> should be with [minval -maxval].
getargnum() {
    local _b
    unset _b
    local _default _min _max
    _default="$1"
    shift
    _min="$1"
    shift
    _max="$1"
    shift
    _b=$(getarg "$1") || _b=${_b:-"$_default"}
        isdigit "$_b" && _b=$((_b)) \
            && [ $_b -ge "$_min" ] && [ $_b -le "$_max" ] && echo $_b && return
    fi
    echo "$_default"
getargs() {
    debug_off
    export CMDLINE
    local _val _i _gfound _deprecated
    unset _val
    unset _gfound
    _newoption="$1"
    for _i in "$@"; do
        if [ "$_i" = "-d" ]; then
            _deprecated=1
            continue
        fi
        if _val="$(dracut-getargs "$_i")"; then
                    warn "Option '$_i' is deprecated, use '$_newoption' instead."
                else
                    warn "Option $_i is deprecated!"
                fi
            fi
            if [ -n "$_val" ]; then
                printf '%s\n' "$_val"
            fi
            _gfound=1
        fi
        _deprecated=0
    done
    if [ -n "$_gfound" ]; then
        debug_on
        return 0
    fi
    debug_on
    return 1
# Prints value of given option.  If option is a flag and it's present,
# it just returns 0.  Otherwise 1 is returned.
# $1 = options separated by commas
# $2 = option we are interested in
# Example:
# $1 = cipher=aes-cbc-essiv:sha256,hash=sha256,verify
# $2 = hash
# Output:
# sha256
getoptcomma() {
    local line=",$1,"
    local opt="$2"
    local tmp
    case "${line}" in
        *,${opt}=*,*)
            tmp="${line#*,${opt}=}"
            echo "${tmp%%,*}"
            return 0
        *,${opt},*) return 0 ;;
    esac
    return 1
# Splits given string 'str' with separator 'sep' into variables 'var1', 'var2',
# 'varN'.  If number of fields is less than number of variables, remaining are
# not set.  If number of fields is greater than number of variables, the last
# variable takes remaining fields.  In short - it acts similary to 'read'.
# splitsep sep str var1 var2 varN
# example:
#   splitsep ':' 'foo:bar:baz' v1 v2
# in result:
#   v1='foo', v2='bar:baz'
# TODO: ':' inside fields.
splitsep() {
    debug_off
    local sep="$1"
    local str="$2"
    shift 2
    local tmp
    while [ -n "$str" -a "$#" -gt 1 ]; do
        tmp="${str%%$sep*}"
        eval "$1='${tmp}'"
        str="${str#"$tmp"}"
        str="${str#$sep}"
        shift
    done
    [ -n "$str" -a -n "$1" ] && eval "$1='$str'"
    debug_on
    return 0
setdebug() {
    [ -f /usr/lib/initrd-release ] || return
    if [ -z "$RD_DEBUG" ]; then
            RD_DEBUG=no
            if getargbool 0 rd.debug -d -y rdinitdebug -d -y rdnetdebug; then
                RD_DEBUG=yes
                [ -n "$BASH" ] \
                    && export PS4='${BASH_SOURCE}@${LINENO}(${FUNCNAME[0]-}): '
            fi
        fi
        export RD_DEBUG
    fi
    debug_on
setdebug
source_all() {
    local f
    local _dir
    _dir=$1
    shift
    [ "$_dir" ] && [ -d "/$_dir" ] || return
    for f in "/$_dir"/*.sh; do
        if [ -e "$f" ]; then
            # shellcheck disable=SC1090
            # shellcheck disable=SC2240
            . "$f" "$@"
        fi
    done
hookdir=/lib/dracut/hooks
export hookdir
source_hook() {
    local _dir
    _dir=$1
    shift
    source_all "/lib/dracut/hooks/$_dir" "$@"
check_finished() {
    local f
    for f in "$hookdir"/initqueue/finished/*.sh; do
        [ "$f" = "$hookdir/initqueue/finished/*.sh" ] && return 0
        { [ -e "$f" ] && (. "$f"); } || return 1
    done
    return 0
source_conf() {
    local f
    [ "$1" ] && [ -d "/$1" ] || return
    for f in "/$1"/*.conf; do [ -e "$f" ] && . "$f"; done
die() {
        echo "<24>dracut: FATAL: $*"
        echo "<24>dracut: Refusing to continue"
    } > /dev/kmsg
        echo "warn dracut: FATAL: \"$*\""
        echo "warn dracut: Refusing to continue"
    } >> $hookdir/emergency/01-die.sh
    [ -d /run/initramfs ] || mkdir -p -- /run/initramfs
    : > /run/initramfs/.die
    if getargbool 0 "rd.shell"; then
        emergency_shell
    else
        source_hook "shutdown-emergency"
    fi
    if [ -n "$DRACUT_SYSTEMD" ]; then
        systemctl --no-block --force halt
    fi
    exit 1
check_quiet() {
    if [ -z "$DRACUT_QUIET" ]; then
        DRACUT_QUIET="yes"
        getargbool 0 rd.info -d -y rdinfo && DRACUT_QUIET="no"
        getargbool 0 rd.debug -d -y rdinitdebug && DRACUT_QUIET="no"
        getarg quiet || DRACUT_QUIET="yes"
        a=$(getarg loglevel=)
        [ -n "$a" ] && [ "$a" -ge 28 ] && DRACUT_QUIET="yes"
        export DRACUT_QUIET
    fi
check_occurances() {
    # Count the number of times the character $ch occurs in $str
    # Return 0 if the count matches the expected number, 1 otherwise
    local str="$1"
    local ch="$2"
    local expected="$3"
    local count=0
    while [ "${str#*$ch}" != "${str}" ]; do
        str="${str#*$ch}"
        count=$((count + 1))
    done
    [ $count -eq "$expected" ]
incol2() {
    debug_off
    local check
    local file="$1"
    local str="$2"
    [ -z "$file" ] && return 1
    [ -z "$str" ] && return 1
    while read -r _ check _ || [ -n "$check" ]; do
        if [ "$check" = "$str" ]; then
            debug_on
            return 0
        fi
    done < "$file"
    debug_on
    return 1
udevsettle() {
    # shellcheck disable=SC2086
    udevadm settle --exit-if-exists=$hookdir/initqueue/work $settle_exit_if_exists
udevproperty() {
    for i in "$@"; do
        udevadm control --property="$i"
    done
find_mount() {
    local dev wanted_dev
    wanted_dev="$(readlink -e -q "$1")"
    while read -r dev _ || [ -n "$dev" ]; do
        [ "$dev" = "$wanted_dev" ] && echo "$dev" && return 0
    done < /proc/mounts
    return 1
# usage: ismounted <mountpoint>
# usage: ismounted /dev/<device>
if command -v findmnt > /dev/null; then
    ismounted() {
        findmnt "$1" > /dev/null 2>&1
else
    ismounted() {
        if [ -b "$1" ]; then
            find_mount "$1" > /dev/null && return 0
            return 1
        fi
        while read -r _ m _ || [ -n "$m" ]; do
            [ "$m" = "$1" ] && return 0
        done < /proc/mounts
        return 1
fi
# Create udev rule match for a device with its device name, or the udev property
# ID_FS_UUID or ID_FS_LABEL
# example:
#   udevmatch LABEL=boot
# prints:
#   ENV{ID_FS_LABEL}="boot"
# TODO: symlinks
udevmatch() {
    case "$1" in
        UUID=????????-????-????-????-???????????? | LABEL=* | PARTLABEL=* | PARTUUID=????????-????-????-????-????????????)
            printf 'ENV{ID_FS_%s}=="%s"' "${1%%=*}" "${1#*=}"
        UUID=*)
            printf 'ENV{ID_FS_UUID}=="%s*"' "${1#*=}"
        PARTUUID=*)
            printf 'ENV{ID_FS_PARTUUID}=="%s*"' "${1#*=}"
        /dev/?*) printf -- 'KERNEL=="%s"' "${1#/dev/}" ;;
        *) return 255 ;;
    esac
label_uuid_to_dev() {
    local _dev
    _dev="${1#block:}"
    case "$_dev" in
        LABEL=*)
            echo "/dev/disk/by-label/$(echo "${_dev#LABEL=}" | sed 's,/,\\x2f,g;s, ,\\x20,g')"
        PARTLABEL=*)
            echo "/dev/disk/by-partlabel/$(echo "${_dev#PARTLABEL=}" | sed 's,/,\\x2f,g;s, ,\\x20,g')"
        UUID=*)
            echo "/dev/disk/by-uuid/${_dev#UUID=}"
        PARTUUID=*)
            echo "/dev/disk/by-partuuid/${_dev#PARTUUID=}"
            echo "$_dev"
    esac
# Prints unique path for potential file inside specified directory.  It consists
# of specified directory, prefix and number at the end which is incremented
# until non-existing file is found.
# funiq dir prefix
# example:
# # ls /mnt
# cdrom0 cdrom1
# # funiq /mnt cdrom
# /mnt/cdrom2
funiq() {
    local dir="$1"
    local prefix="$2"
    local i=0
    [ -d "${dir}" ] || return 1
    while [ -e "${dir}/${prefix}$i" ]; do
        i=$((i + 1)) || return 1
    done
    echo "${dir}/${prefix}$i"
# Creates unique directory and prints its path.  It's using funiq to generate
# path.
# mkuniqdir subdir new_dir_name
mkuniqdir() {
    local dir="$1"
    local prefix="$2"
    local retdir
    local retdir_new
    [ -d "${dir}" ] || mkdir -m 0755 -p "${dir}" || return 1
    retdir=$(funiq "${dir}" "${prefix}") || return 1
    until mkdir -m 0755 "${retdir}" 2> /dev/null; do
        retdir_new=$(funiq "${dir}" "${prefix}") || return 1
        [ "$retdir_new" = "$retdir" ] && return 1
        retdir="$retdir_new"
    done
    echo "${retdir}"
# Copy the contents of SRC into DEST, merging the contents of existing
# directories (kinda like rsync, or cpio -p).
# Creates DEST if it doesn't exist. Overwrites files with the same names.
# copytree SRC DEST
copytree() {
    local src="$1" dest="$2"
    [ -d "$src" ] || return 1
    mkdir -p "$dest" || return 1
    dest=$(readlink -e -q "$dest") || return 1
        cd "$src" || exit 1
        cp -af . -t "$dest"
# Evaluates command for UUIDs either given as arguments for this function or all
# listed in /dev/disk/by-uuid.  UUIDs doesn't have to be fully specified.  If
# beginning is given it is expanded to all matching UUIDs.  To pass full UUID to
# your command use '$___' as a place holder.  Remember to escape '$'!
# foreach_uuid_until [ -p prefix ] command UUIDs
# prefix - string to put just before $___
# command - command to be evaluated
# UUIDs - list of UUIDs separated by space
# The function returns after *first successful evaluation* of the given command
# with status 0.  If evaluation fails for every UUID function returns with
# status 1.
# Example:
# foreach_uuid_until "mount -U \$___ /mnt; echo OK; umount /mnt" \
#       "01234 f512 a235567f-12a3-c123-a1b1-01234567abcb"
foreach_uuid_until() (
    cd /dev/disk/by-uuid || return 1
    [ "$1" = -p ] && local prefix="$2" && shift 2
    local cmd="$1"
    shift
    local uuids_list="$*"
    local uuid
    local full_uuid
    local ___
    [ -n "${cmd}" ] || return 1
    for uuid in ${uuids_list:-*}; do
        for full_uuid in "${uuid}"*; do
            [ -e "${full_uuid}" ] || continue
            # shellcheck disable=SC2034
            ___="${prefix}${full_uuid}"
            eval "${cmd}" && return 0
        done
    done
    return 1
# Get kernel name for given device.  Device may be the name too (then the same
# is returned), a symlink (full path), UUID (prefixed with "UUID=") or label
# (prefixed with "LABEL=").  If just a beginning of the UUID is specified or
# even an empty, function prints all device names which UUIDs match - every in
# single line.
# NOTICE: The name starts with "/dev/".
# Example:
#   devnames UUID=123
# May print:
#   /dev/dm-1
#   /dev/sdb1
#   /dev/sdf3
devnames() {
    local dev="$1"
    local d
    local names
    case "$dev" in
        UUID=*)
            # shellcheck disable=SC2016
            dev="$(foreach_uuid_until '! blkid -U $___' "${dev#UUID=}")" \
                && return 255
            [ -z "$dev" ] && return 255
        LABEL=*) dev="$(blkid -L "${dev#LABEL=}")" || return 255 ;;
        /dev/?*) ;;
        *) return 255 ;;
    esac
    for d in $dev; do
        names="$names
$(readlink -e -q "$d")" || return 255
    done
    echo "${names#
usable_root() {
    local _i
    [ -d "$1" ] || return 1
    for _i in "$1"/usr/lib*/ld-*.so "$1"/lib*/ld-*.so; do
        [ -e "$_i" ] && return 0
    done
    for _i in proc sys dev; do
        [ -e "$1"/$_i ] || return 1
    done
    return 0
inst_hook() {
    local _hookname _unique _name _job _exe
        case "$1" in
            --hook)
                _hookname="/$2"
                shift
            --unique)
                _unique="yes"
            --name)
                _name="$2"
                shift
                break
        esac
        shift
    done
    if [ -z "$_unique" ]; then
        _job="${_name}$$"
    else
        _job="${_name:-$1}"
        _job=${_job##*/}
    fi
    _exe=$1
    shift
    [ -x "$_exe" ] || _exe=$(command -v "$_exe")
    if [ -n "$onetime" ]; then
            echo '[ -e "$_job" ] && rm -f -- "$_job"'
            echo "$_exe $*"
        } > "/tmp/$$-${_job}.sh"
    else
        echo "$_exe $*" > "/tmp/$$-${_job}.sh"
    fi
    mv -f "/tmp/$$-${_job}.sh" "$hookdir/${_hookname}/${_job}.sh"
# inst_mount_hook <mountpoint> <prio> <name> <script>
# Install a mount hook with priority <prio>,
# which executes <script> as soon as <mountpoint> is mounted.
inst_mount_hook() {
    local _prio="$2" _jobname="$3" _script="$4"
    local _hookname
    _hookname="mount-$(str_replace "$1" '/' '\\x2f')"
    [ -d "$hookdir/${_hookname}" ] || mkdir -p "$hookdir/${_hookname}"
    inst_hook --hook "$_hookname" --unique --name "${_prio}-${_jobname}" "$_script"
# wait_for_mount <mountpoint>
# Installs a initqueue-finished script,
# which will cause the main loop only to exit,
# if <mountpoint> is mounted.
wait_for_mount() {
    local _name
    _name="$(str_replace "$1" '/' '\\x2f')"
    printf '. /lib/dracut-lib.sh\nismounted "%s"\n' "$1" \
        >> "$hookdir/initqueue/finished/ismounted-${_name}.sh"
        printf 'ismounted "%s" || ' "$1"
        printf 'warn "\"%s\" is not mounted"\n' "$1"
    } >> "$hookdir/emergency/90-${_name}.sh"
killproc() {
    debug_off
    local _exe
    _exe="$(command -v "$1")"
    local _sig=$2
    local _i
    [ -x "$_exe" ] || return 1
    for _i in /proc/[0-9]*; do
        [ "$_i" = "/proc/1" ] && continue
        if [ -e "$_i"/_exe ] && [ "$_i/_exe" -ef "$_exe" ]; then
            kill "$_sig" "${_i##*/}"
        fi
    done
    debug_on
need_shutdown() {
    : > /run/initramfs/.need_shutdown
wait_for_loginit() {
    [ "$RD_DEBUG" = "yes" ] || return
    [ -e /run/initramfs/loginit.pipe ] || return
    debug_off
    echo "DRACUT_LOG_END"
    exec 0<> /dev/console 1<> /dev/console 2<> /dev/console
    # wait for loginit
    i=0
    while [ $i -lt 10 ]; do
        if [ ! -e /run/initramfs/loginit.pipe ]; then
            j=$(jobs)
            [ -z "$j" ] && break
            [ -z "${j##*Running*}" ] || break
        fi
        sleep 0.1
        i=$((i + 1))
    done
    if [ $i -eq 10 ]; then
        kill %1 > /dev/null 2>&1
        kill "$(while read -r line || [ -n "$line" ]; do echo "$line"; done < /run/initramfs/loginit.pid)"
    fi
    setdebug
    rm -f -- /run/initramfs/loginit.pipe /run/initramfs/loginit.pid
# pidof version for root
if ! command -v pidof > /dev/null 2> /dev/null; then
    pidof() {
        debug_off
        local _cmd
        local _exe
        local _rl
        local _ret=1
        local i
        _cmd="$1"
        if [ -z "$_cmd" ]; then
            debug_on
            return 1
        fi
        _exe=$(command -v "$1")
        for i in /proc/*/exe; do
            [ -e "$i" ] || continue
            if [ -n "$_exe" ]; then
                [ "$i" -ef "$_exe" ] || continue
            else
                _rl=$(readlink -f "$i")
                [ "${_rl%/$_cmd}" != "$_rl" ] || continue
            fi
            i=${i%/exe}
            echo "${i##/proc/}"
            _ret=0
        done
        debug_on
        return $_ret
fi
_emergency_shell() {
    local _name="$1"
        : > /.console_lock
        echo "PS1=\"$_name:\\\${PWD}# \"" > /etc/profile
        systemctl start dracut-emergency.service
        rm -f -- /etc/profile
        rm -f -- /.console_lock
    else
        debug_off
        source_hook "$hook"
        echo
        /sbin/rdsosreport
        echo 'You might want to save "/run/initramfs/rdsosreport.txt" to a USB stick or /boot'
        echo 'after mounting them and attach it to a bug report.'
        if ! RD_DEBUG='' getargbool 0 rd.debug -d -y rdinitdebug -d -y rdnetdebug; then
            echo
            echo 'To get more debug information in the report,'
            echo 'reboot with "rd.debug" added to the kernel command line.'
        fi
        echo
        echo 'Dropping to debug shell.'
        echo
        export PS1="$_name:\${PWD}# "
        [ -e /.profile ] || : > /.profile
        _ctty="$(RD_DEBUG='' getarg rd.ctty=)" && _ctty="/dev/${_ctty##*/}"
        if [ -z "$_ctty" ]; then
            _ctty=console
            while [ -f /sys/class/tty/$_ctty/active ]; do
                read -r _ctty < /sys/class/tty/$_ctty/active
                _ctty=${_ctty##* } # last one in the list
            done
            _ctty=/dev/$_ctty
        fi
        [ -c "$_ctty" ] || _ctty=/dev/tty1
        case "$(/usr/bin/setsid --help 2>&1)" in *--ctty*) CTTY="--ctty" ;; esac
        setsid $CTTY /bin/sh -i -l 0<> $_ctty 1<> $_ctty 2<> $_ctty
    fi
emergency_shell() {
    local _ctty
    set +e
    local _rdshell_name="dracut" action="Boot" hook="emergency"
    local _emergency_action
    if [ "$1" = "-n" ]; then
        _rdshell_name=$2
        shift 2
    elif [ "$1" = "--shutdown" ]; then
        _rdshell_name=$2
        action="Shutdown"
        hook="shutdown-emergency"
        shift 2
    fi
    echo
    echo
    warn "$*"
    echo
    _emergency_action=$(getarg rd.emergency)
    [ -z "$_emergency_action" ] \
        && [ -e /run/initramfs/.die ] \
        && _emergency_action=halt
    if getargbool 1 rd.shell -d -y rdshell || getarg rd.break -d rdbreak; then
        _emergency_shell "$_rdshell_name"
    else
        source_hook "$hook"
        warn "$action has failed. To debug this issue add \"rd.shell rd.debug\" to the kernel command line."
        [ -z "$_emergency_action" ] && _emergency_action=halt
    fi
    case "$_emergency_action" in
        reboot)
            reboot || exit 1
        poweroff)
            poweroff || exit 1
        halt)
            halt || exit 1
    esac
# Retain the values of these variables but ensure that they are unexported
# This is a POSIX-compliant equivalent of bash's "export -n"
export_n() {
    local var
    local val
    for var in "$@"; do
        eval val=\$$var
        unset $var
        [ -n "$val" ] && eval "$var=\"$val\""
    done
# returns OK if list1 contains all elements of list2, i.e. checks if list2 is a
# sublist of list1.  An order and a duplication doesn't matter.
# $1 = separator
# $2 = list1
# $3 = list2
# $4 = ignore values, separated by $1
listlist() {
    local _sep="$1"
    local _list="${_sep}${2}${_sep}"
    local _sublist="$3"
    [ -n "$4" ] && local _iglist="${_sep}${4}${_sep}"
    local IFS="$_sep"
    local _v
    [ "$_list" = "$_sublist" ] && return 0
    for _v in $_sublist; do
        if [ -n "$_v" ] && ! ([ -n "$_iglist" ] && strstr "$_iglist" "$_v"); then
            strstr "$_list" "$_v" || return 1
        fi
    done
    return 0
# returns OK if both lists contain the same values.  An order and a duplication
# doesn't matter.
# $1 = separator
# $2 = list1
# $3 = list2
are_lists_eq() {
    listlist "$1" "$2" "$3" "$4" && listlist "$1" "$3" "$2" "$4"
setmemdebug() {
    if [ -z "$DEBUG_MEM_LEVEL" ]; then
        DEBUG_MEM_LEVEL=$(getargnum 0 0 5 rd.memdebug)
        export DEBUG_MEM_LEVEL
    fi
setmemdebug
# parameters: func log_level prefix msg [trace_level:trace]...
make_trace_mem() {
    local log_level prefix msg msg_printed
    local trace trace_level trace_in_higher_levels insert_trace
    msg=$1
    shift
    prefix='[debug_mem]'
    log_level=$DEBUG_MEM_LEVEL
    if [ -z "$log_level" ] || [ "$log_level" -le 0 ]; then
        return
    fi
    # FIXME? useless echo?
    # shellcheck disable=SC2116
    msg=$(echo "$msg")
    msg_printed=0
        trace=${1%%:*}
        trace_level=${trace%%+}
        [ "$trace" != "$trace_level" ] && trace_in_higher_levels="yes"
        trace=${1##*:}
        if [ -z "$trace_level" ]; then
            trace_level=0
        fi
        insert_trace=0
        if [ -n "$trace_in_higher_levels" ]; then
            if [ "$log_level" -ge "$trace_level" ]; then
                insert_trace=1
            fi
        else
            if [ "$log_level" -eq "$trace_level" ]; then
                insert_trace=1
            fi
        fi
        if [ $insert_trace -eq 1 ]; then
            if [ $msg_printed -eq 0 ]; then
                echo "$prefix $msg"
                msg_printed=1
            fi
            show_memstats "$trace"
        fi
        shift
    done
# parameters: type
show_memstats() {
    case $1 in
        shortmem)
                str_starts "$line" "MemFree" \
                    || str_starts "$line" "Cached" \
                    || str_starts "$line" "Slab" \
                    || continue
                echo "$line"
            done < /proc/meminfo
        mem)
            cat /proc/meminfo
        slab)
            cat /proc/slabinfo
        iomem)
            cat /proc/iomem
    esac
remove_hostonly_files() {
    rm -fr /etc/cmdline /etc/cmdline.d/*.conf "$hookdir/initqueue/finished"
    if [ -f /lib/dracut/hostonly-files ]; then
            [ -e "$line" ] || [ -h "$line" ] || continue
            rm -f "$line"
        done < /lib/dracut/hostonly-files
    fi
# parameter: kernel_module [filesystem_name]
# returns OK if kernel_module is loaded
# modprobe fails if /lib/modules is not available (--no-kernel use case)
load_fstype() {
    strstr "$(cat /proc/filesystems)" "${2:-$1}" || modprobe "$1"
  1. Update dracut
    sudo dracut --force
  2. Open /etc/default/grub
    sudo nano /etc/default/grub
    add rootovl to GRUB_CMDLINE_LINUX, then change dom0_mem=max: and add 90% of your available RAM (you can find this info with command xl info | grep total_memory in terminal). For example, if you have 15 GB of available RAM, write dom0_mem=max:13312 (if you have 64 GB of RAM, you can write dom0_mem=max:59392).
    Then update grub
You will now always launch dom0 in live mode!
Next, copy Whonix and Kicksecure templates and select varlibqubes in the advanced settings. Then create new AppVMs based on the varlibqubes templates and also select varlibqubes in the advanced settings.
Templates in vm-pool will be in persistent mode (but metadata from dom0 will be deleted, so if you create a new qube in vm-pool in live mode, it will not be saved after rebooting).
To launch persistent mode for dom0 and perform updates or install new programs, do the following:
  • Press E in grub menu and remove rootovl, then press F10. This will launch a persistent session for one time.
  • To completely remove live mode, remove rootovl in /etc/default/grub and update grub in persistent mode.
A little misleading, because in dom0 free -h will only show the memory currently allocated to dom0, not the whole installed memory!
The correct way to find this information is:
[user@dom0] xl info | grep total_memory
Or… the user probably knows how much memory the system has (or can find out in the BIOS screen).
You are right
It works! I just checked it. It’s fantastic. Now we have 2 amnesic Qubes:
ZRAM Live Mode
OverlayFS Live Mode
It can be used simultaneously - either loading the first version or version with overlayfs.
Can we add this option to the first version’s prompt? Something like ā€œEnter Boot option: ZRAM (z), OverlayFS (o) or Persistent (r)ā€
Please write an instruction for running it in btrfs. Overlayfs work by default in btrfs, but require too much RAM. I can’t get it to run in btrfs and I don’t quite understand what needs to be done. I replaced mount /dev/mapper/qubes_dom0-root with my /, but that didn’t help
Hello everyone. Did anybody test working it on 4.3 Qubes is or not?
I think so, yes. Both methods are based on dracut, and there haven’t been any changes to dracut.
This root snapshot is not related to the session in an AppVM. It is stored in dom0 and cannot be preserved in live mode. For example, you can create an AppVM in varlibqubes, but run it only in a dom0 live - then you won’t see the vm-root-snap device when you run lsblk
Bash theme for dom0 that show dom0 mode - persistent (/dev/mapper/qubes_dom0-root) or live ram mode (/dev/zram0 or overlay)
Add this code into .bashrc instead of the default code:
# .bashrc
# Source global definitions
if [ -f /etc/bashrc ]; then
	. /etc/bashrc
fi
# User specific environment
if ! [[ "$PATH" =~ "$HOME/.local/bin:$HOME/bin:" ]]
then
    PATH="$HOME/.local/bin:$HOME/bin:$PATH"
fi
export PATH
export VIRTUAL_ENV_DISABLE_PROMPT=true
__qubes_update_prompt_data() {
	local RETVAL=$?
	__qubes_venv=''
	[[ -n "$VIRTUAL_ENV" ]] && __qubes_venv=$(basename "$VIRTUAL_ENV")
	__qubes_git=''
	__qubes_git_color=$(tput setaf 10)  # clean
	local git_branch=$(git --no-optional-locks rev-parse --abbrev-ref HEAD 2> /dev/null)
	if [[ -n "$git_branch" ]]; then
		local git_status=$(git --no-optional-locks status --porcelain 2> /dev/null | tail -n 1)
		[[ -n "$git_status" ]] && __qubes_git_color=$(tput setaf 11)  # dirty
		__qubes_git="‹${git_branch}›"
	fi
	__qubes_prompt_symbol_color=$(tput sgr0)
	[[ "$RETVAL" -ne 0 ]] && __qubes_prompt_symbol_color=$(tput setaf 1)
	return $RETVAL  # to preserve retcode
	PROMPT_COMMAND="$PROMPT_COMMAND; __qubes_update_prompt_data"
else
	PROMPT_COMMAND="__qubes_update_prompt_data"
fi
PS1=''
PS1+='\[$(tput setaf 7)\]$(echo -ne $__qubes_venv)\[$(tput sgr0)\]'
PS1+='\[$(tput setaf 14)\]\u'
PS1+='\[$(tput setaf 15)\] šŸ‘‘ '
PS1+='\[$(tput setaf 9)\]\h'
PS1+=" $(findmnt -n -o SOURCE /)"
PS1+='\[$(tput setaf 15)\]:'
PS1+='\[$(tput setaf 7)\]\w '
PS1+='\[$(echo -ne $__qubes_git_color)\]$(echo -ne $__qubes_git)\[$(tput sgr0)\] '
PS1+='\[$(tput setaf 8)\]\[$([[ -n "$QUBES_THEME_SHOW_TIME" ]] && echo -n "[\t]")\]\[$(tput sgr0)\]'
PS1+='\[$(tput sgr0)\]\n'
PS1+='\[$(echo -ne $__qubes_prompt_symbol_color)\]\$\[$(tput sgr0)\] '
Both live modes will not work if it is implemented in R5.0.
Need to create a new pool in dom0 or switch to btrfs
Hi @linuxuser1
Thank you for tracking the different ways of running amnesic Qubes.
A question: how would someone set up Whonix (especially, the NetVM, sys-whonix) to run on an ephemeral RAM-based qube on either approach (the OverlayFS method or the ZRAM method)?
Would I need to reinstall the Whonix templates and use the varlibqubes template pool during reinstallation somehow? Can I do it on the fly in case I already have Qubes with Whonix preinstalled? I am new to QubesOS
I am aware there are downsides to this; one being that the Tor entry guards aren’t persisted and thus you’re more susceptible to correlation attacks; but ignoring this, how would someone achieve this?
Thanks
Hi. Clone sys‑whonix and the Whonix appVMs into the varlibqubes pool. Then start Qubes, for example, using zram . Make sure to specify the cloned sys‑whonix in the update settings; otherwise Whonix won’t be able to update. You don’t need to touch the Whonix templates—my research shows that templates can reside in the VM pool without affecting the forensic threat.
Thanks @linuxuser1 !
Another question: I am facing this ā€œissueā€ Really disposable (RAM based) qubes - #218 by emacs84 and I think you went through the same Trim in templateVMs (though, in my case, I don’t mind if templates use the vmpool, only AppVMs should use varlibqubes)? I am not knowledgeable enough to know if either the ZRAM or OverlayFS approach would result in the same scenario here.
Did you ever find a way to make TRIMs possible when using varlibqubes and thus the pools don’t grow indefinitely? Or to use a different driver other than file?
Thanks
#!/bin/sh
read line
case "${line:-Nn}" in
[Tt]* )
modprobe overlay
# Move root
# details
umount $NEWROOT
# Create tmpfs
mkdir /cow
umount /cow
umount /live/image
[Zz]* )
mkdir /mnt
umount /sysroot
mount /dev/mapper/qubes_dom0-root /mnt
modprobe zram
echo 62G > /sys/block/zram0/disksize
/mnt/usr/sbin/mkfs.ext2 /dev/zram0
mount /dev/zram0 /sysroot
cp -a /mnt/* /sysroot
exit 0
[Ss]* )
exit 0
exit 1
esac
tmpfs and zram0 in dracut menu
Final Version QUBES LIVE MODES in New Topics
:point_down: :point_down:
I created a shell script based on your post and tested these scripts for 6 months to make Qubes ephemeral in RAM! I developed versions for both Qubes 4.3 and 4.2. Thank you very much; your post helped me a lot. Now everything is automated and easy to execute, with an option to restore Qubes to its original mode without live mode!
