Qubes-HCL-AZW-SER8 Beelink SER8
Ref: Beelink | Beelink SER8 AMD Ryzen™ 7 8845HS MINI PC 8C/16T Frequency up to 5.1GHz
Remarks
Partially working. IOMMU issue resulting in Xen panic which seems an old bug.
Disabling IOMMU on grub menu allows to proceed to install but with broken end state. Without IOMMU, no sys-net, can do disp VM and qvm-block to mount USB disk but no Internet, no updates
Xen BUG at drivers/passthrough/amd/iommu_init.c:1386
----[ Xen-4.17.4  x86_64  debug=n  Not tainted ]----
Panic on CPU 0:
Xen 4.17.3-3 panic on boot on Framework AMD · Issue #9030 · QubesOS/qubes-issues · GitHub (Mar-May 2024 and 4.2.3 from Sep 2024? working current qubes has Xen 4.17.5)
=> add to grub cmd: panic=0 noreboot=1 x2apic-mode=mixed
=> same
Unclear if 4.2.3 installer is patched or not (should be from timeline but maybe not).
layout:
  'hcl'
type:
  'Mini PC'
hvm:
  'yes'
iommu:
  'no'
slat:
  'yes'
tpm:
  '2.0'
remap:
  'no'
brand: |
  AZW
model: |
  SER8
bios: |
  HPT.8xxx.SER8.V029.P8C0M0C15.08.Link
cpu: |
  AMD Ryzen 7 8745HS w/ Radeon 780M Graphics
cpu-short: |
  FIXME
chipset: |
  Advanced Micro Devices, Inc. [AMD] Device [1022:14e8]
chipset-short: |
  FIXME
gpu: |
  Advanced Micro Devices, Inc. [AMD/ATI] Device [1002:1900] (rev b3) (prog-if 00 [VGA controller])
gpu-short: |
  FIXME
network: |
  Realtek Semiconductor Co., Ltd. RTL8125 2.5GbE Controller [10ec:8125] (rev 05)
  Intel Corporation Wi-Fi 6 AX200 [8086:2723] (rev 1a)
memory: |
  28457
scsi: |
usb: |
  7
certified:
  'no'
versions:
  - works:
      'partial'
    qubes: |
      R4.2.3
    xen: |
      4.17.4
    kernel: |
      6.6.48-1
    remark: |
      R4.2.3 install failing with xen panic on amd_iommu. booting with iommu=0 allows to proceed to install but broken as can't create sys-net, sys-usb... only dispVM without network will work. Without sys-net, can't update system.
    credit: |
      FIXAUTHOR
    link: |
      FIXLINK
