So heres how it went down. I installed Qubes no errors. It wasn’t on my grub so I:
mounted my Qubes partition’s root on my Arch’s /mnt, ran os-probe, and updated the grub. It found it fine, and I rebootted.
It boots into Qubes? Great. Decrypts fine. Fails to mount anything. I modify the grub fine and make it boot on /dev/ and not /dev/env. Boots and actually loads /dev.
But now it says /system/ doesn’t look like OSTREE and… I’m stumped.
Did you install Qubes OS 4.2.1?
Did you install Qubes OS on external (USB?) disk?
How did you update the grub?
Did you mount /boot and /boot/efi (if you’re using UEFI) in mounted Qubes OS root, chrooted there and then run grub2-mkconfig -o /boot/grub2/grub.cfg?
Qubes didn’t come with it if you’re saying from inside qubes. I didn’t mount anything, I only mounted it to /mnt and modprobed. Thats it. Was i supposed to bind them?
