I am encountering a boot issue when using Qubes OS.
I am running the latest stable release of Qubes (release 4.1.2)
PC: Librem Mini v2 - https://shop.puri.sm/shop/librem-mini/
Boot: Pureboot (pureboot-librem_mini_v2-Release-27.1)
The following occurs roughly 80% of the time when booting:
Once the following appears it just sits there stuck. If I unplug one monitor and pass the initial boot screen (pictured) then plug the screen back in everything then functions normally. As stated roughly 20% of the time this issue will not occur, I did however encounter this issue once with only one screen connected.
I originally thought this was a Pureboot issue, I updated the firmware and the issue remained.
I then thought my KVM switch was causing the issue, I have since tested connecting the monitors directly to my computer however the issue remains.
I then installed Fedora and the issue disappeared, confirming for me this was caused by Qubes.
I posted about this on the Purism Forum and received this detailed response: Pureboot problem - Librem Mini v2 - Librem - Purism community
Would be very appreciative if someone could point me in the right direction.
