Hello
I cannot copy,nor move files from one VM to another because my /etc/qubes-rpc/policy/qubes.FileCopy dissapeared.Now each time am trying to qvm-move-to-vmp, or qvm-copy-to-vm commands I get the error Denied:qubes.Filecopy. How can have qubes.FileCopy back?
Thanks
If you are on version 4.1 it is recommended to use The New Qrexec Policy System
Check the contents of the 90-default.policy file in the /etc/qubes/policy.d/ directory where there should be an entry for qubes.Filecopy
Be aware that at the top of the file it says "Do not modify this file, create a new policy file with a lower number in the filename instead. For example 30-user.policy."
thanks a lot
I only had to restart the system and it worked again
