Qubes FIDO2/CTAP2 proxy for Passkey authenticaiton with hardware devices?
I am currently using a password manager solution for Passkeys in Qubes OS:
  • Air-gapped KeepassXC vault qube
  • Client qube with Firefox browser and KeepassXC extension
  • This extension connects via qrexec to vault for Passkey registration/authentication
This works fine so far. I thought, it would be a good idea to also connect a FIDO2 hardware token (Nitrokey) to store Passkeys securely.
Qubes Global Config → USB Devices has a section “U2F devices”. But this proxy is only for legacy U2F/CTAP1 protocol and does not work for Passkeys, correct?
Hence kindly asking about recommended solution in Qubes:
  • Attach USB-connected Nitrokey from USB qube to client qube demanding Passkeys? Does this work well?
  • Do devs have a roadmap in the pipeline to extend CTAP1 proxy to CTAP2 for passkeys?
For passkeys I would not treat the U2F setting as equivalent to full CTAP2/WebAuthn support. U2F is the older/simple case; passkeys often need CTAP2 features, especially resident/discoverable credentials, so a proxy that only covers U2F can fail in confusing ways.
The safest practical test is with a disposable or low-value browser qube first: attach the Nitrokey only to that client qube, try both registration and login, then detach it again. If that works, it is usable, but it is a different trust trade-off from a qrexec proxy because the client qube talks to the token directly. I would avoid attaching the token to the vault qube unless the vault really needs it.
Yeah, I just saw Not recognizing Yubikey for setting up challenge response with KeepassXC as well.
So it actually seems possible to use CTAP2 via proxy (is it?). I think, this still is a legitimate question: Qubes Global Config explicitely names that section “U2F devices” and “U2F proxy”. U2F is a legacy standard and not compatible to Passkeys, which require FIDO2 with WebAuthn + CTAP2:
WebAuthn and CTAP provide a complete replacement for U2F, which has been renamed “CTAP1” in the latest version of the FIDO2 standard.[37] The WebAuthn protocol is backward-compatible (via the AppID extension) with U2F-only security keys[38] but the U2F protocol is not compatible with a WebAuthn-only authenticator
See also CTAP:
The CTAP specification refers to two protocol versions, the CTAP1/U2F protocol and the CTAP2 protocol.
Yes, exactly. That’s why I asked, if Qubes CTAP proxy also support CTAP2 for Passkeys.
Unfortunately I don’t have a hardware device to test things out at the moment.
I would keep the two cases separate: the Qubes UI label may still say U2F, but passkeys usually mean CTAP2 resident/discoverable credentials, so I would not assume the existing proxy covers that path. If nobody with a Nitrokey answers, the lowest-risk check is exactly a disposable/low-value browser qube with the token attached only for the registration/login test, then detached again. That at least tells you whether direct USB attach works before deciding if the proxy/roadmap question matters for your setup.
