I upgraded my R4.0 installation to R4.1, I noticed 2 things:
- When I execute qubes-dom0-update, the sys-whonix window appears and checks for updates, when it is done it immediately disappears. I filmed it with my phone and found that it outputs:
Removing dependent packages:
* a number of python2 packages *
Transaction summary
Remove 14 packages
Freed space 14MB
DNF will only download packages for the transaction
Then dom0 terminal reports no updates found. Shouldn’t it ask about removing those packages?
- When I try to install a package with qubes-dom0-update, the sys-whonix window closes early and I get an error about downloading the metadata for the cache repository:
Using sys-whonix as UpdateVM to download updates for Dom0; this may take some time...
Qubes OS Repository for Dom0 0.0 B/s | 0 B 00:00
Errors during downloading metadata for repository 'qubes-dom0-cached':
- Curl error (37): Couldn't read a file:// file for file:///var/lib/qubes/updates/repodata/repomd.xml [Couldn't open file /var/lib/qubes/updates/repodata/repomd.xml]
Error: Failed to download metadata for repo 'qubes-dom0-cached': Cannot download repomd.xml: Cannot download repodata/repomd.xml: All mirrors were tried
