Hey! I need some serious help. I have been locked out of qubes after adding a LUKS2 encryption password, which works but when I enter my old one or this new one - I get this screen:
Try to boot from some LiveUSB OS and decrypt your Qubes OS encrypted LVM there. Check if the LVM is present after decryption.
Maybe you’ve entered some wrong commands to add another password and formatted your drive by mistake.
Then followed the on screen instructions and did not get any errors. Double verified the password and it worked. It is very weird. Maybe I have deleted some important TemplateVM or something? Could be a possibility since I did rinse some stuff yesterday but honestly I was 100% careful so don’t really see how that could happen…
Is this not looking good? I might lose a lot of progress
Update: When entering my disk password in the boot up menu, it takes about 4 tries for it to work even though the password is right. Very weird. Maybe I should have removed the old password and just use the new one since they might mess things up with each other.
That is the weird part. Like I said, I have the old password which still works and the new that still works. However I have to enter them multiple times before they “work” or at least get past the disk password screen to boot, but then the error comes. Does a wrong password take me here to this screen as well? I will try it.
