Qubes-dist-upgrade error: "there are no enabled repositories..."
Why when I upgrade qubes4.2 to 4.3, I follow the official documentation and I can execute the command
sudo qubes-dist-upgrade --releasever=4.3 -y --all-pre-reboot
Error reported:
there are no enabled repossitories in “/etc/yu.real.repos.d”
The independent vm cannot be updated. The netvm of the independent vm is none. I can update it after connecting to sys-whonix, but I don’t think this is the right approach at all. The purpose of the independent vm is that the data is more important, so it needs to be disconnected, right?
ping -c 4 yum.qubes-os.org reports Temporary failure in name resolution
ping -c 4 8.8.8.8 error, network unreachable
Why do I get so many errors? I kneel down and reinstall honestly by downloading the iso file. But I still want to understand why. Can anyone answer it? What went wrong? How to solve it?
独立虚拟机默认不联网,所以在其中直接升级 Qubes 会失败,必须临时连接 NetVM 或通过离线方式更新
Assume you don’t have “qubes-dist-upgrade” yet installed to get it working. You first have to do:
sudo qubes-dom0-update --enablerepo=qubes-templates-community-testing -y qubes-dist-upgrade
Have you tried this before…?
I don’t intend animosity; but is “–enablerepo…” necessary? Qubes docs do not include that, just “sudo qubes-dom0-update -y qubes-dist-upgrade.” Not super important, but I think better to not enable the unnecessary repo in dom0.
Yes, could be a command from the “rc” days of 4.3, when qubes-dist-upgrade wasn’t available for the usual update/upgrade crowd and maybe it’s now available for all via
Not necessarily, he gave the option to skip it. If the independent VM must be connected to the Internet to upgrade, then why create an independent VM? For example: What is the encryption private key stored in your independent VM?
I upgraded by referring to the official documentation, but I still got a lot of errors. I don’t know if it was a problem with my environment or something else. Your command did not appear in the official documentation. In fact, if I don’t know much about the technology, I would prefer to strictly follow the official documentation. Unfortunately, there were still a lot of errors. In the end, I spent a day re-downloading and installing. It was so fucked.
yes, was very similar for me (in December) and the commands from the official documentation didn’t work that way and so I searched the forum here getting the command, which was grabbing the qubes-dist-upgrade function from the test repositories, so I got it installed and I was able to do the entire in-place-upgrade procedure after then.
But fact: if I’m a newly QubesOS user I always would follow (and prefer) not to do a in-place-upgrade, but a new and fresh install instead. And for the reason (not to destroy my old 4.2 system) I rather would buy a new device (if I have the money) or just buy a new SSD which I’ll use for the new 4.3 install to keep the old 4.2 SSD alive for a fall back.
