Hey, I’ve been building my own system as a template, now I have the problem that I can login to the system and do stuff using the terminal but I’m still not being able to start anything from the menu or qvm-run. Also, display doesn’t show up despite qubes-gui and qubes-gui-common being installed. Thus I wanted to ask about the way these functions are implemented and what it would take to manually replicate them.
Thanks for the help
okay, one part solves itself… forgot to install xorg…
