Qubes 4.3 - Upgrade to Dom0 7.x kernel
I installed Qubes 4.3 on a new laptop with the default 6.18.x Dom0 kernel. I regularly update Dom0 but I am still stuck on 6.18.x. I have tried the latest repository but I am still on 6.18.x.
How do I get on the 7.x Dom0 kernel path?
Thanks in advance.
You should be able to select the newer kernel in Qubes Global Config → General → Linux Kernel.
I only see the following:
6.18.51-1.fc41
6.18.54-1.fc41
6.18.57-1.fc41
Thanks.
You need to install kernel-latest in dom0. Unless your current hardware is not working properly, I see no reason to upgrade, since security patches are backported.
