Hello, I upgraded from Qubes 4.2 to 4.3 and wanted to add the local printer again as I did in Qubes 4.2, using
$ sudo dnf install cups
in the DruckerVM settings, I added the cups service.
$ sudo dnf install system-config-printer was already installed.
$ system-config-printer there were problems
[user@Drucker ~]$ system-config-printer
/usr/share/system-config-printer/system-config-printer.py:325: DeprecationWarning: Gtk.ActionGroup.list_actions is deprecated
for action in printer_manager_action_group.list_actions ():
/usr/share/system-config-printer/system-config-printer.py:326: DeprecationWarning: Gtk.Action.set_sensitive is deprecated
action.set_sensitive (False)
/usr/share/system-config-printer/system-config-printer.py:334: DeprecationWarning: Gtk.ActionGroup.get_action is deprecated
act = printer_manager_action_group.get_action (action)
There is no printer in the window that opens. If you know the password (I don’t), you can enter a device URI.
Use $ lsusb to check whether the printer is recognized in the DruckerVM. Yes, Epson WF-4820
Checked for activity in the DruckerVM with $ sudo systemctl status cups, result: activ (running), triggeredBy: cups.socket
No printer is found in the DruckerVM with Firefox and http://localhost:631 in the Printer tab.
How can I install a local printer in Qubes 4.3?
I haven’t found anything that works.
