Hello,
Since upgrading to 4.3 / Whonix 18 I can’t attach USB to Whonix 18. It does seem to thankfully work in Fedora 42, however attaching to Whonix 18 I get the error when I try to open it:
Not authorized to perform this operation.
The device does seem to attach succesfully, I just don’t have permissions to open it for some reason.
Thanks a lot
corny
February 12, 2026, 3:16pm
2
I don’t use whonix appVM for mounting USB but anything sudo related can no longer be run by user in whonix 18.
Run as root and try again. Or cli mount it to a folder in home instead of /mnt etc
This is expected. This is a part of new hardening of Whonix Workstation templates and introduction of sysmaint account. Here are more information on sysmaint account.
To have sudo access to new Whonix Workstation (and Kicksecure) templates, open a terminal with sysmaint account in them:
qvm-run -u sysmaint TEMPLATENAME xterm
or
qvm-run -u sysmaint TEMPLATENAME xfce4-terminal
Then you can use sudo
sudo/root issue? → sysmaint - System Maintenance User
USBGuard issue? →
Note:
What is the best option to transfer files between Whonix 18 and VMs?
QVM-COPY/MOVE (then use USB Storage in the VM)
USB Storage in Whonix
Unspecific to Qubes-Whonix. Same as for Qubes.
dkzkz
February 20, 2026, 11:27am
6
it doesn’t matter it’s just a file
