Qubes 4.2 Does Not Properly Install
Hello everyone.
I installed Qubes 4.2 on a 64GIB USB memory, but it takes an extremely long time to start up and perform all actions, and I can’t even connect to the Internet (the WI-FI icon doesn’t even appear). Also, although I installed it with the default settings, there is no search engine installed in Work, Whonix, etc. How can I resolve these issues?
If it’s a USB capacity issue, I have a 128GB USB, so I can use that to install again. :grinning:
Sorry, no one has replied before now.
Uh, Can you tell us what means you used to install Qubes ISO to USB?
Qubes can be difficult to get to USB properly sometimes.
What is the hardware specifications of what you are trying to install to.
Have you set the BIOS/EFI to Legacy, and are you sure Virtualization is turned on.
What exactly are you seeing on the screen? At what point does it seem to slow down?
