Failed to import module localemod, this is due most likely to a syntax error:
→ AttributeError: module ‘salt.utils.decorators’ has no attribute ‘which’
local:
qubes-input-proxy
qubes-input-proxy-receiver
Not helpful without any context.
What are you doing?
What triggers the error?
the command was in dom0 → sudo qubesctl --show-output state.sls update.qubes-dom0
was just trying to update dom0
don’t recognise this error
