What can be done to prevent upgrades from downgrading a dependency of an installed package, effectively resulting in the removal of that installed package?
Some details:
Immediately after installing an Epson inkjet print driver, as displayed below, there is a notification that a Fedora-30 update is available.
Performing this update downgrades the lsb package, of which the epson print driver relies. The print filter package is no longer on the system.
---- Begin Screen Dump ----
[user@fedora-30 ~]$ sudo dnf install epson-inkjet-printer-escpr-1.7.7-1lsb3.2.x86_64.rpm
Dependencies resolved.
Package Arch Version Repository Size
Downgrading:
epson-inkjet-printer-escpr x86_64 1.7.7-1lsb3.2 @commandline 3.9 M
Transaction Summary
Downgrade 1 Package
Total size: 3.9 M
Is this ok [y/N]: Y
Downloading Packages:
Running transaction check
Transaction check succeeded.
Running transaction test
Transaction test succeeded.
Running transaction
Preparing : 1/1
Running scriptlet: epson-inkjet-printer-escpr-1.7.7-1lsb3.2.x86_64 1/2
Downgrading : epson-inkjet-printer-escpr-1.7.7-1lsb3.2.x86_64 1/2
Cleanup : epson-inkjet-printer-escpr-1:1.6.41-1.1lsb3.2.fc30.x 2/2
Running scriptlet: epson-inkjet-printer-escpr-1:1.6.41-1.1lsb3.2.fc30.x 2/2
Verifying : epson-inkjet-printer-escpr-1.7.7-1lsb3.2.x86_64 1/2
Verifying : epson-inkjet-printer-escpr-1:1.6.41-1.1lsb3.2.fc30.x 2/2
Last metadata expiration check: 0:09:44 ago on Mon Sep 28 15:40:14 2020.
Notifying dom0 about installed applications
Downgraded:
Complete!
## Listing /opt shows the printer filter is installed.
[user@fedora-30 ~]$ ls /opt
epson-inkjet-printer-escpr epson-printer-utility libreoffice7.0
## Now perform the update
Updating fedora-30
fedora-30:
ID: dnf list updates --refresh >/dev/null
Function: cmd.run
Result: True
Comment: Command "dnf list updates --refresh >/dev/null" run
Started: 15:39:42.101850
Duration: 9297.107 ms
Changes:
pid:
4062
retcode:
0
stderr:
stdout:
Function: pkg.uptodate
Result: True
Comment: Upgrade ran successfully
Started: 15:39:57.038816
Duration: 49902.47 ms
Changes:
epson-inkjet-printer-escpr:
new:
old:
1.7.7-1lsb3.2
Function: cmd.run
Result: True
Comment: Command "/usr/lib/qubes/upgrades-status-notify" run
Started: 15:40:46.942306
Duration: 5538.605 ms
Changes:
pid:
6719
retcode:
0
stderr:
stdout:
Summary for fedora-30
Succeeded: 3 (changed=3)
Failed: 0
Total states run: 3
Total run time: 64.738 s
## Now listing /opt shows the print filter is missing.
— End Screen Dump —
The printer is no longer functional.
Thanks for any help,
-Andy
