Continuing the discussion from Qubes-Firewall-Manager:
As far as I understand it, you have to have a firewall-VM or right in front of each VM for it to work.
For example: sys-net β sys-firewall β sys-vpn β work
If you apply firewall settings in the work VM it wonβt work because the firewall will only see VPN traffic coming through.
Yes, To apply Firewall rules setups should be like-
work-firewall-vpn-(sys-firewall)-(sys-net).
But What I said in original post can be of extreme use for Qubes adoption.
Thank you!
work-firewall-vpn-(sys-firewall)-(sys-net) DID WORK!
