Hello There It’s Me Again Sorry For bothering I just Wanted to install Qube On my Pc after failed installation on my laptop so i installed Qube On My PC (Not Laptop) So After i got Reboot I can’t install Sys-USB It seems Disabled Iam Using Pc that have USB keyboard and mouse and USB Disk (adata 1TB) So any suggestions how to get USB work and thanks for taking time and read my post
Documentation for this is here: USB qubes | Qubes OS
The installer will not automatically install sys-usb when you have a USB
keyboard because you cannot continue using the OS after this point. You
will have neither a keyboard nor mouse by default.
The documentation above will guide you through both the setups, and the
potential risks involved.
Could you edit your boot commandline (if you’re in grub, just press ‘e’,
for efi you will have to edit /boot/efi/EFI/qubes/xen.efi) and add the
following:
loglevel=7 systemd.log_level=debug
This should give us some more information on what is going wrong.
This only occurs after running the initial installer with sys-net selected?
I have Run These Command
1-sudo qubesctl state.sls qvm.sys-usb
2-sudo qubesctl state.sls qvm.usb-keyboard
Then I run Sys-USB my Keyboard and mouse Freezing... And after reboot the pc got this
And Now Iam renstalling again
1-sudo qubesctl state.sls qvm.sys-usb 2-sudo qubesctl state.sls qvm.usb-keyboard Then I run Sys-USB my Keyboard and mouse Freezing... And after reboot the pc got this
The output of qvm-pci before and after these commands may also be
useful on your next install.
