Hi, I’m on Qubes R4.1. I updated dom0 with current-testing repo today. My Qube Manager version is 4.1.23-1. Just found that whenever I enter “Global Settings” in Qube Manager, the manager always crashes. The relevant log I could find was this line:
“Exception: Cannot detect enabled ITL template update repositories”.
Is it a bug, or is there any way to solve this?
enmus
March 5, 2022, 11:31pm
2
$ sudo qubes-dom0-update --enablerepo=qubes-templates-itl
Error: unknown repo: qubes-templates-itl
Hi @enmus
I suggest you to use qvm-template for templates , not qubes-dom0-update:
Context
The #7133 and #7170 tagged as solved for qvm-template . Qubesos-bot published the core-admin-client v4.1.20 (r4.1) package for dom0.
Installation
See testing-repositories , you should install the qubes-core-admin-client and python3-qubesadmin packages from the current-testing repository.
Testing report
qvm-template repolist displays the enabled repositories
qvm-template --enablerepo=qubes-templates-itl-testing list lists the debian-9 and fedora…
.. program:: qvm-template
:program:`qvm-template` -- Manage template VMs
Synopsis
:command:`qvm-template` [-h] [--repo-files *REPO_FILES*] [--keyring *KEYRING*] [--updatevm *UPDATEVM*] [--enablerepo *REPOID*] [--disablerepo *REPOID*] [--repoid *REPOID*] [--releasever *RELEASEVER*] [--refresh] [--cachedir *CACHEDIR*] [--yes] [--quiet] *SUBCOMMAND*
See Section `Commands`_ for available subcommands.
Options
.. option:: --help, -h
Show help message and exit.
.. option:: --repo-files REPO_FILES
This file has been truncated. show original
enmus
March 6, 2022, 1:30pm
4
Oh Gee, was I myself? Thank you so much @ludovic for the correction, rather than it was suggestion
I’m banging my head to make apt-cacher to work for fedora at the moment, and obviously nothing else works, hahaha.
unman
March 6, 2022, 1:36pm
5
If you use qubes-dom0-update it will operate via qvm-template.
Hi @ycgrobo ,
ycgrobo:
Did you change the dom0 yum repositories?
Information from my current system (but with qubes-manager from current repo not current-testing ):
[user@dom0 ~]$ rpm -qf $(which qubes-qube-manager )
qubes-manager-4.1.22-1.fc32.noarch
[user@dom0 ~]$ cat /etc/yum.repos.d/qubes-templates.repo
[qubes-templates-itl]
name = Qubes Templates repository
#baseurl = https://yum.qubes-os.org/r$releasever/templates-itl
#baseurl = http://yum.qubesosfasa4zl44o4tws22di6kepyzfeqv3tg4e3ztknltfxqrymdad.onion/r$releasever/templates-itl
metalink = https://yum.qubes-os.org/r$releasever/templates-itl/repodata/repomd.xml.metalink
enabled = 1
fastestmirror = 1
metadata_expire = 7d
gpgcheck = 1
gpgkey = file:///etc/pki/rpm-gpg/RPM-GPG-KEY-qubes-$releasever-primary
[qubes-templates-itl-testing]
#baseurl = https://yum.qubes-os.org/r$releasever/templates-itl-testing
#baseurl = http://yum.qubesosfasa4zl44o4tws22di6kepyzfeqv3tg4e3ztknltfxqrymdad.onion/r$releasever/templates-itl-testing
metalink = https://yum.qubes-os.org/r$releasever/templates-itl-testing/repodata/repomd.xml.metalink
enabled = 0
fastestmirror = 1
gpgcheck = 1
[qubes-templates-community]
name = Qubes Community Templates repository
#baseurl = https://yum.qubes-os.org/r$releasever/templates-community
#baseurl = http://yum.qubesosfasa4zl44o4tws22di6kepyzfeqv3tg4e3ztknltfxqrymdad.onion/r$releasever/templates-community
metalink = https://yum.qubes-os.org/r$releasever/templates-community/repodata/repomd.xml.metalink
enabled = 0
fastestmirror = 1
gpgcheck = 1
gpgkey = file:///etc/pki/rpm-gpg/RPM-GPG-KEY-qubes-$releasever-templates-community
[qubes-templates-community-testing]
#baseurl = https://yum.qubes-os.org/r$releasever/templates-community-testing
#baseurl = http://yum.qubesosfasa4zl44o4tws22di6kepyzfeqv3tg4e3ztknltfxqrymdad.onion/r$releasever/templates-community-testing
metalink = https://yum.qubes-os.org/r$releasever/templates-community-testing/repodata/repomd.xml.metalink
enabled = 0
fastestmirror = 1
gpgcheck = 1
[user@dom0 ~]$ rpm -qf /etc/yum.repos.d/qubes-templates.repo
qubes-release-4.1-0.27.noarch
Compare with your system.
Also look the changelog for manager v4.1.23-1 and qubes-release v4.1-1 .
enmus
March 6, 2022, 1:41pm
7
Unfortunately it doesn’t work for me, while qvm-template works… am I hijacking this topic? I posted it because at the moment I thought it was related setting the same repository?
The content of my /etc/yum.repos.d/qubes-template.repo is:
### This file is no longer used
### Template repositories are configured now in
### /etc/qubes/repo-templates/qubes-templates.repo
The change was made in qubes-release v4.1-1 update.
I’m guessing Qube Manager still reads repo info from old path?
Following report: after copying /etc/qubes/repo-templates/qubes-templates.repo to /etc/yum.repos.d/qubes-template.repo, Qube Manager acted normally. I think Qube Manager needs to be updated to adapt to the qubes-release v4.1-1 change.
