Qube backup fails with blank reason
I tried to backup my 4.0 qubes before upgrading to 4.1 but got a dialog with:
ERROR: Writing backup to VM {vm name} failed:
With nothing after that colon which is real strange.
I looked at Backup Fails since upgrade to 4.1 (unless qubes are all shut down) - #15 by scallyob but it isn’t the same error message I got, but it did lead me to the cli command qvm-backup, which I invoked like this:
qvm-backup --profile /etc/qubes/backup/qubes-manager-backup.conf -d dysUsb /home/user/bkup dummyNet
(dummyNet is a small qube that is currently shutdown that I am using just to test this bug)
The response told me to look in journalctl, where this seems to be the relevant line:
Sep 13 16:39:33 dom0 qubesd[2346]: permission denied for call b'admin.backup.Info'+b'/etc/qubes/backup/qubes-manager-backup.conf' (b'dom0' → b'dom0') with payload of 0 bytes
This happens when using root, or my user. Why?
Attempt the test backup without using the backup profile.
Instead, only use the command flags. Try this:
qvm-backup --verbose --dest-vm dysUsb /home/user/bkup/ dummyNet
It should prompt you to enter a password manually.
OK, that worked. Does that mean my backup profile is corrupted?
How do I get the GUI to ignore the backup profile (or do I just have to avoid the GUI entirely)?
I believe you just type the name of the profile like:
 --profile qubes-manager-backup
I got errors when including the “.conf” and it knows where to look. But enjoy using profiles now since I started using the cli to problem solve backups.
