QSB-123: AMD CPU vulnerabilities (XSA-524, XSA-525)
We have published Qubes Security Bulletin (QSB) 123: AMD CPU vulnerabilities (XSA-524, XSA-525). The text of this QSB and its accompanying cryptographic signatures are reproduced below, followed by a general explanation of this announcement and authentication instructions.
Qubes Security Bulletin 123
             ---===[ Qubes Security Bulletin 123 ]===---
                              2026-11-10
User action
Continue to update normally via the Qubes Update tool or its
command-line equivalents [1] in order to apply the security updates
described in the "Patching" section below.
Summary
On 2026-11-10, the Xen Project published the security advisories below.
XSA-524 [5] "AMD IOMMU Out-of-Bounds Device Table Read":
| With AMD IOMMUs, the OS or Hypervisor chooses the position and size of
| the Device Table, which holds the main configuration information for
| devices.
| AMD have disclosed a vulnerability in some IOMMUs, whereby under
| specific circumstances they read beyond the size chosen by the OS or
| Hypervisor.  This gets interpreted as valid configuration data for
| certain devices.
| For more information, see:
|   https://www.amd.com/en/resources/product-security/bulletin/amd-sb-3060.html
XSA-525 [6] "x86: Transient Scheduler Attacks (update)":
| AMD have discovered further properties of Transient Scheduler Attacks.
| The previously published XSA-471 dealt with two TSA variants, TSA-SQ
| and TSA-L1 on Zen3 and Zen4 CPUs.  For details, see XSA-471.
| AMD had previously said that Zen5 CPUs were not vulnerable to TSA-SQ and
| TSA-L1.  This statement has been corrected, and is being tracked as
| AMD-SB-7073 using the existing CVE-2024-36350 and CVE-2024-36357.
| AMD have also disclosed a new TSA variant, TSA-Fill, which is being
| tracked as AMD-SB-3031 and CVE-2026-0004.
|   https://xenbits.xen.org/xsa/advisory-471.html
|   https://www.amd.com/content/dam/amd/en/documents/resources/bulletin/technical-guidance-for-mitigating-transient-scheduler-attacks.pdf
|   https://www.amd.com/en/resources/product-security/bulletin/amd-sb-7073.html
|   https://www.amd.com/en/resources/product-security/bulletin/amd-sb-3031.html
Impact
XSA-524: On affected systems, a malicious qube may be able to compromise
Qubes OS by writing to arbitrary memory pages.
XSA-525: On affected systems, a malicious qube may be able to leak data
from other qubes in the system.
Affected systems
XSA-524: Some AMD EPYC CPUs are affected (see AMD-SB-3060 [7] for
details). Only systems with a specific device configuration are affected
(see XSA-524 [5] for details).
XSA-525: AMD Zen 5 CPUs are affected.
In both cases, Intel CPUs are not affected.
Patching
The following packages contain security updates that address the
vulnerabilities described in this bulletin:
  For Qubes 4.3, in dom0:
  - Xen packages, 4.19.6-4
These packages will migrate from the security-testing repositories to
the current (stable) repositories after being tested by the community.
This testing period is intended to catch bugs affecting Qubes OS
stability before the packages reach the broader userbase. By default,
the security-testing repositories are disabled in both dom0 and
templates. If you wish to receive security updates faster at the risk of
encountering more bugs, you can enable the security-testing repositories
either temporarily (for a single update) or permanently. [2] Dom0,
templates, and standalones each have their own security-testing
repositories, which can be enabled independently of one another. [3][4]
If you do not have the relevant security-testing repositories enabled
while security updates are in security-testing, you must wait until they
migrate to the current (stable) repositories, which generally takes one
to two weeks but may be expedited in urgent cases. Once the packages are
available to your Qubes OS system, you should install them as described
in the "User action" section above.
After you have installed the packages listed above, you must restart
dom0 in order for the security updates to take effect.
If you use Anti Evil Maid, you must reseal your secret passphrase to new
PCR values, as PCR18+19 changes when Xen binaries are updated.
Credits
See the original Xen Security Advisories. [5][6]
References
[1] https://doc.qubes-os.org/en/latest/user/how-to-guides/how-to-update.html
[2] https://doc.qubes-os.org/en/latest/user/downloading-installing-upgrading/testing.html#updates
[3] https://doc.qubes-os.org/en/latest/user/advanced-topics/how-to-install-software-in-dom0.html#testing-repositories
[4] https://doc.qubes-os.org/en/latest/user/how-to-guides/how-to-install-software.html#testing-repositories
[5] https://xenbits.xen.org/xsa/advisory-524.html
[6] https://xenbits.xen.org/xsa/advisory-525.html
[7] https://www.amd.com/en/resources/product-security/bulletin/amd-sb-3060.html
The Qubes Security Team
Source: qsb-123-2026.txt
Marek Marczykowski-Górecki’s PGP signature
-----BEGIN PGP SIGNATURE-----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=SJ9n
-----END PGP SIGNATURE-----
Source: qsb-123-2026.txt.sig.marmarek
Simon Gaiser (aka HW42)’s PGP signature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=w665
Source: qsb-123-2026.txt.sig.simon
What is the purpose of this announcement?
The purpose of this announcement is to inform the Qubes community that a new Qubes security bulletin (QSB) has been published.
What is a Qubes security bulletin (QSB)?
A Qubes security bulletin (QSB) is a security announcement issued by the Qubes security team. A QSB typically provides a summary and impact analysis of one or more recently-discovered software vulnerabilities, including details about patching to address them.
Why should I care about QSBs?
QSBs tell you what actions you must take in order to protect yourself from recently-discovered security vulnerabilities. In most cases, security vulnerabilities are addressed by updating normally. However, in some cases, special user action is required. In all cases, the required actions are detailed in QSBs.
What are the PGP signatures that accompany QSBs?
A PGP signature is a cryptographic digital signature made in accordance with the OpenPGP standard. PGP signatures can be cryptographically verified with programs like GNU Privacy Guard (GPG). The Qubes security team cryptographically signs all QSBs so that Qubes users have a reliable way to check whether QSBs are genuine. The only way to be certain that a QSB is authentic is by verifying its PGP signatures.
Why should I care whether a QSB is authentic?
A forged QSB could deceive you into taking actions that adversely affect the security of your Qubes OS system, such as installing malware or making configuration changes that render your system vulnerable to attack. Falsified QSBs could sow fear, uncertainty, and doubt about the security of Qubes OS or the status of the Qubes OS Project.
How do I verify the PGP signatures on a QSB?
The following command-line instructions assume a Linux system with git and gpg installed. (For Windows and Mac options, see OpenPGP software.)
  1. Obtain the Qubes Master Signing Key (QMSK), e.g.:
    $ gpg --fetch-keys https://keys.qubes-os.org/keys/qubes-master-signing-key.asc
    gpg: directory '/home/user/.gnupg' created
    gpg: keybox '/home/user/.gnupg/pubring.kbx' created
    gpg: requesting key from 'https://keys.qubes-os.org/keys/qubes-master-signing-key.asc'
    gpg: /home/user/.gnupg/trustdb.gpg: trustdb created
    gpg: key DDFA1A3E36879494: public key "Qubes Master Signing Key" imported
    gpg: Total number processed: 1
    gpg:               imported: 1
    (For more ways to obtain the QMSK, see How to import and authenticate the Qubes Master Signing Key.)
  2. View the fingerprint of the PGP key you just imported. (Note: gpg> indicates a prompt inside of the GnuPG program. Type what appears after it when prompted.)
    $ gpg --edit-key 0x427F11FD0FAA4B080123F01CDDFA1A3E36879494
    gpg (GnuPG) 2.2.27; Copyright (C) 2021 Free Software Foundation, Inc.
    This is free software: you are free to change and redistribute it.
    There is NO WARRANTY, to the extent permitted by law.
    pub  rsa4096/DDFA1A3E36879494
         created: 2010-04-01  expires: never       usage: SC
         trust: unknown       validity: unknown
    [ unknown] (1). Qubes Master Signing Key
    gpg> fpr
    pub   rsa4096/DDFA1A3E36879494 2010-04-01 Qubes Master Signing Key
     Primary key fingerprint: 427F 11FD 0FAA 4B08 0123  F01C DDFA 1A3E 3687 9494
  3. Important: At this point, you still don’t know whether the key you just imported is the genuine QMSK or a forgery. In order for this entire procedure to provide meaningful security benefits, you must authenticate the QMSK out-of-band. Do not skip this step! The standard method is to obtain the QMSK fingerprint from multiple independent sources in several different ways and check to see whether they match the key you just imported. For more information, see How to import and authenticate the Qubes Master Signing Key.
    Tip: After you have authenticated the QMSK out-of-band to your satisfaction, record the QMSK fingerprint in a safe place (or several) so that you don’t have to repeat this step in the future.
  4. Once you are satisfied that you have the genuine QMSK, set its trust level to 5 (“ultimate”), then quit GnuPG with q.
    gpg> trust
    Please decide how far you trust this user to correctly verify other users' keys
    (by looking at passports, checking fingerprints from different sources, etc.)
      1 = I don't know or won't say
      2 = I do NOT trust
      3 = I trust marginally
      4 = I trust fully
      5 = I trust ultimately
      m = back to the main menu
    Your decision? 5
    Do you really want to set this key to ultimate trust? (y/N) y
         trust: ultimate      validity: unknown
    Please note that the shown key validity is not necessarily correct
    unless you restart the program.
    gpg> q
  5. Use Git to clone the qubes-secpack repo.
    $ git clone https://github.com/QubesOS/qubes-secpack.git
    Cloning into 'qubes-secpack'...
    remote: Enumerating objects: 4065, done.
    remote: Counting objects: 100% (1474/1474), done.
    remote: Compressing objects: 100% (742/742), done.
    remote: Total 4065 (delta 743), reused 1413 (delta 731), pack-reused 2591
    Receiving objects: 100% (4065/4065), 1.64 MiB | 2.53 MiB/s, done.
    Resolving deltas: 100% (1910/1910), done.
  6. Import the included PGP keys. (See our PGP key policies for important information about these keys.)
    $ gpg --import qubes-secpack/keys/*/*
    gpg: key 063938BA42CFA724: public key "Marek Marczykowski-Górecki (Qubes OS signing key)" imported
    gpg: qubes-secpack/keys/core-devs/retired: read error: Is a directory
    gpg: no valid OpenPGP data found.
    gpg: key 8C05216CE09C093C: 1 signature not checked due to a missing key
    gpg: key 8C05216CE09C093C: public key "HW42 (Qubes Signing Key)" imported
    gpg: key DA0434BC706E1FCF: public key "Simon Gaiser (Qubes OS signing key)" imported
    gpg: key 8CE137352A019A17: 2 signatures not checked due to missing keys
    gpg: key 8CE137352A019A17: public key "Andrew David Wong (Qubes Documentation Signing Key)" imported
    gpg: key AAA743B42FBC07A9: public key "Brennan Novak (Qubes Website & Documentation Signing)" imported
    gpg: key B6A0BB95CA74A5C3: public key "Joanna Rutkowska (Qubes Documentation Signing Key)" imported
    gpg: key F32894BE9684938A: public key "Marek Marczykowski-Górecki (Qubes Documentation Signing Key)" imported
    gpg: key 6E7A27B909DAFB92: public key "Hakisho Nukama (Qubes Documentation Signing Key)" imported
    gpg: key 485C7504F27D0A72: 1 signature not checked due to a missing key
    gpg: key 485C7504F27D0A72: public key "Sven Semmler (Qubes Documentation Signing Key)" imported
    gpg: key BB52274595B71262: public key "unman (Qubes Documentation Signing Key)" imported
    gpg: key DC2F3678D272F2A8: 1 signature not checked due to a missing key
    gpg: key DC2F3678D272F2A8: public key "Wojtek Porczyk (Qubes OS documentation signing key)" imported
    gpg: key FD64F4F9E9720C4D: 1 signature not checked due to a missing key
    gpg: key FD64F4F9E9720C4D: public key "Zrubi (Qubes Documentation Signing Key)" imported
    gpg: key DDFA1A3E36879494: "Qubes Master Signing Key" not changed
    gpg: key 1848792F9E2795E9: public key "Qubes OS Release 4 Signing Key" imported
    gpg: qubes-secpack/keys/release-keys/retired: read error: Is a directory
    gpg: key D655A4F21830E06A: public key "Marek Marczykowski-Górecki (Qubes security pack)" imported
    gpg: key ACC2602F3F48CB21: public key "Qubes OS Security Team" imported
    gpg: qubes-secpack/keys/security-team/retired: read error: Is a directory
    gpg: key 4AC18DE1112E1490: public key "Simon Gaiser (Qubes Security Pack signing key)" imported
    gpg: Total number processed: 17
    gpg:               imported: 16
    gpg:              unchanged: 1
    gpg: marginals needed: 3  completes needed: 1  trust model: pgp
    gpg: depth: 0  valid:   1  signed:   6  trust: 0-, 0q, 0n, 0m, 0f, 1u
    gpg: depth: 1  valid:   6  signed:   0  trust: 6-, 0q, 0n, 0m, 0f, 0u
  7. Verify signed Git tags.
    $ cd qubes-secpack/
    $ git tag -v `git describe`
    object 266e14a6fae57c9a91362c9ac784d3a891f4d351
    type commit
    tag marmarek_sec_266e14a6
    tagger Marek Marczykowski-Górecki 1677757924 +0100
    Tag for commit 266e14a6fae57c9a91362c9ac784d3a891f4d351
    gpg: Signature made Thu 02 Mar 2023 03:52:04 AM PST
    gpg:                using RSA key 2D1771FE4D767EDC76B089FAD655A4F21830E06A
    gpg: Good signature from "Marek Marczykowski-Górecki (Qubes security pack)" [full]
    The exact output will differ, but the final line should always start with gpg: Good signature from... followed by an appropriate key. The [full] indicates full trust, which this key inherits in virtue of being validly signed by the QMSK.
  8. Verify PGP signatures, e.g.:
    $ cd QSBs/
    $ gpg --verify qsb-087-2022.txt.sig.marmarek qsb-087-2022.txt
    gpg: Signature made Wed 23 Nov 2022 04:05:51 AM PST
    $ gpg --verify qsb-087-2022.txt.sig.simon qsb-087-2022.txt
    gpg: Signature made Wed 23 Nov 2022 03:50:42 AM PST
    gpg:                using RSA key EA18E7F040C41DDAEFE9AA0F4AC18DE1112E1490
    gpg: Good signature from "Simon Gaiser (Qubes Security Pack signing key)" [full]
    $ cd ../canaries/
    $ gpg --verify canary-034-2023.txt.sig.marmarek canary-034-2023.txt
    gpg: Signature made Thu 02 Mar 2023 03:51:48 AM PST
    $ gpg --verify canary-034-2023.txt.sig.simon canary-034-2023.txt
    gpg: Signature made Thu 02 Mar 2023 01:47:52 AM PST
    Again, the exact output will differ, but the final line of output from each gpg --verify command should always start with gpg: Good signature from... followed by an appropriate key.
For this announcement (QSB-123), the commands are:
$ gpg --verify qsb-123-2026.txt.sig.marmarek qsb-123-2026.txt
$ gpg --verify qsb-123-2026.txt.sig.simon qsb-123-2026.txt
You can also verify the signatures directly from this announcement in addition to or instead of verifying the files from the qubes-secpack. Simply copy and paste the QSB-123 text into a plain text file and do the same for both signature files. Then, perform the same authentication steps as listed above, substituting the filenames above with the names of the files you just created.
This is a companion discussion topic for the original entry at https://www.qubes-os.org/news/2026/11/10/qsb-123/
