We have published Qubes Security Bulletin 093: Transient execution vulnerabilities in AMD and Intel CPUs (CVE-2023-20569/XSA-434, CVE-2022-40982/XSA-435). The text of this QSB and its accompanying cryptographic signatures are reproduced below. For an explanation of this announcement and instructions for authenticating this QSB, please see the end of this announcement.
---===[ Qubes Security Bulletin 093 ]===---
2023-08-09
User action required
Users must install the following specific packages in order to address
the issues discussed in this bulletin:
For Qubes 4.1, in dom0:
- Xen packages, version 4.14.6-1
- microcode_ctl, version 2.1-55
For Qubes 4.2, in dom0:
- Xen packages, version 4.17.2-1
Note on AMD Zen 1 and Zen 2 CPUs: The packages we previously released
for QSB-086 [1] already contain mitigations that are sufficient to
protect these CPUs from CVE-2023-20569/XSA-434. Consequently,
fully-updated [2] Qubes OS installations running on systems with these
CPUs are not affected by the vulnerabilities discussed in this bulletin.
Note on AMD Zen 3 and Zen 4 CPUs: AMD has stated that they plan to
distribute microcode updates for these CPUs to original equipment
manufacturers (OEMs), original design manufacturers (ODMs), and
motherboard manufacturers (MB). [3] These microcode updates are shipped
only as part of system firmware; loading them from the operating system
is not supported. Therefore, until the relevant OEM, ODM, or MB provides
a suitable BIOS or (U)EFI update for a system, the package updates
listed above will not be sufficient to address CVE-2023-20569/XSA-434 on
that system.
by the community. [4] Once available, the packages are to be installed
via the Qubes Update tool or its command-line equivalents. [2]
effect.
passphrase to new PCR values, as PCR18+19 will change due to the new
Xen binaries.
Summary
The Xen Project published the following security advisories on
2023-08-08:
XSA-434 [5] "x86/AMD: Speculative Return Stack Overflow"
(CVE-2023-20569):
| Researchers from ETH Zurich have extended their prior research
| (XSA-422, Branch Type Confusion, a.k.a Retbleed) and have discovered
| INCEPTION, also know as RAS (Return Address Stack) Poisoning, and
| Speculative Return Stack Overflow.
| The RAS is updated when a CALL instruction is predicted, rather than
| at a later point in the pipeline. However, the RAS is still
| fundamentally a circular stack.
| It is possible to poison the branch type and target predictions such
| that, at a point of the attackers choosing, the branch predictor
| predicts enough CALLs back-to-back to wrap around the entire RAS and
| overwrite a correct return prediction with one of the attackers
| choosing.
| This allows the attacker to control RET speculation in a victim
| context, and leak arbitrary data as a result.
| For more details, see:
| https://comsec.ethz.ch/inception
| https://www.amd.com/en/corporate/product-security/bulletin/amd-sb-7005
XSA-435 [6] "x86/Intel: Gather Data Sampling" (CVE-2022-40982):
| A researcher has discovered Gather Data Sampling, a transient
| execution side-channel whereby the AVX GATHER instructions can forward
| the content of stale vector registers to dependent instructions.
| The physical register file is a structure competitively shared between
| sibling threads. Therefore an attacker can infer data from the
| sibling thread, or from a more privileged context.
| https://www.intel.com/content/www/us/en/developer/articles/technical/software-security-guidance/technical-documentation/gather-data-sampling.html
Impact
An attacker who compromises one qube can attempt to exploit one of these
vulnerabilities (the one corresponding to the system's CPU) in order to
infer the contents of data belonging to other qubes. In systems with AMD
CPUs, successfully exploiting CVE-2023-20569/XSA-434 would allow an
attacker to infer the contents of arbitrary host memory. In systems with
Intel CPUs, successfully exploiting CVE-2022-40982/XSA-435 would allow
an attacker to infer data from different CPU contexts on the same core.
Credits
See the original Xen Security Advisories.
References
[1] https://github.com/QubesOS/qubes-secpack/blob/master/QSBs/qsb-086-2022.txt
[2] https://www.qubes-os.org/doc/how-to-update/
[3] https://www.amd.com/en/resources/product-security/bulletin/amd-sb-7005.html
[4] https://www.qubes-os.org/doc/testing/
[5] https://xenbits.xen.org/xsa/advisory-434.html
[6] https://xenbits.xen.org/xsa/advisory-435.html
The Qubes Security Team
Source: https://github.com/QubesOS/qubes-secpack/blob/main/QSBs/qsb-093-2023.txt
Marek Marczykowski-Górecki’s PGP signature
-----BEGIN PGP SIGNATURE-----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=Tbh7
-----END PGP SIGNATURE-----
Source: https://github.com/QubesOS/qubes-secpack/blob/main/QSBs/qsb-093-2023.txt.sig.marmarek
Simon Gaiser (aka HW42)’s PGP signature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=zUnR
Source: https://github.com/QubesOS/qubes-secpack/blob/main/QSBs/qsb-093-2023.txt.sig.simon
What is the purpose of this announcement?
The purpose of this announcement is to inform the Qubes community that a new Qubes security bulletin (QSB) has been published.
What is a Qubes security bulletin (QSB)?
A Qubes security bulletin (QSB) is a security announcement issued by the Qubes security team. A QSB typically provides a summary and impact analysis of one or more recently-discovered software vulnerabilities, including details about patching to address them. A list of all QSBs is available here.
Why should I care about QSBs?
QSBs tell you what actions you must take in order to protect yourself from recently-discovered security vulnerabilities. In most cases, security vulnerabilities are addressed by updating normally. However, in some cases, special user action is required. In all cases, the required actions are detailed in QSBs.
What are the PGP signatures that accompany QSBs?
A PGP signature is a cryptographic digital signature made in accordance with the OpenPGP standard. PGP signatures can be cryptographically verified with programs like GNU Privacy Guard (GPG). The Qubes security team cryptographically signs all QSBs so that Qubes users have a reliable way to check whether QSBs are genuine. The only way to be certain that a QSB is authentic is by verifying its PGP signatures.
Why should I care whether a QSB is authentic?
A forged QSB could deceive you into taking actions that adversely affect the security of your Qubes OS system, such as installing malware or making configuration changes that render your system vulnerable to attack. Falsified QSBs could sow fear, uncertainty, and doubt about the security of Qubes OS or the status of the Qubes OS Project.
How do I verify the PGP signatures on a QSB?
The following command-line instructions assume a Linux system with git and gpg installed. (See here for Windows and Mac options.)
Obtain the Qubes Master Signing Key (QMSK), e.g.:
$ gpg --fetch-keys https://keys.qubes-os.org/keys/qubes-master-signing-key.asc gpg: directory '/home/user/.gnupg' created gpg: keybox '/home/user/.gnupg/pubring.kbx' created gpg: requesting key from 'https://keys.qubes-os.org/keys/qubes-master-signing-key.asc' gpg: /home/user/.gnupg/trustdb.gpg: trustdb created gpg: key DDFA1A3E36879494: public key "Qubes Master Signing Key" imported gpg: Total number processed: 1 gpg: imported: 1(See here for more ways to obtain the QMSK.)
View the fingerprint of the PGP key you just imported. (Note:
gpg>indicates a prompt inside of the GnuPG program. Type what appears after it when prompted.)$ gpg --edit-key 0x427F11FD0FAA4B080123F01CDDFA1A3E36879494 gpg (GnuPG) 2.2.27; Copyright (C) 2021 Free Software Foundation, Inc. This is free software: you are free to change and redistribute it. There is NO WARRANTY, to the extent permitted by law. pub rsa4096/DDFA1A3E36879494 created: 2010-04-01 expires: never usage: SC trust: unknown validity: unknown [ unknown] (1). Qubes Master Signing Key gpg> fpr pub rsa4096/DDFA1A3E36879494 2010-04-01 Qubes Master Signing Key Primary key fingerprint: 427F 11FD 0FAA 4B08 0123 F01C DDFA 1A3E 3687 9494 -
Important: At this point, you still don’t know whether the key you just imported is the genuine QMSK or a forgery. In order for this entire procedure to provide meaningful security benefits, you must authenticate the QMSK out-of-band. Do not skip this step! The standard method is to obtain the QMSK fingerprint from multiple independent sources in several different ways and check to see whether they match the key you just imported. See here for more details and ideas for how to do that.
Tip: Record the genuine QMSK fingerprint in a safe place (or several) so that you don’t have to repeat this step in the future.
Once you are satisfied that you have the genuine QMSK, set its trust level to 5 (“ultimate”), then quit GnuPG with
q.gpg> trust pub rsa4096/DDFA1A3E36879494 created: 2010-04-01 expires: never usage: SC trust: unknown validity: unknown [ unknown] (1). Qubes Master Signing Key Please decide how far you trust this user to correctly verify other users' keys (by looking at passports, checking fingerprints from different sources, etc.) 1 = I don't know or won't say 2 = I do NOT trust 3 = I trust marginally 4 = I trust fully 5 = I trust ultimately m = back to the main menu Your decision? 5 Do you really want to set this key to ultimate trust? (y/N) y pub rsa4096/DDFA1A3E36879494 created: 2010-04-01 expires: never usage: SC trust: ultimate validity: unknown [ unknown] (1). Qubes Master Signing Key Please note that the shown key validity is not necessarily correct unless you restart the program. gpg> q -
Use Git to clone the qubes-secpack repo.
$ git clone https://github.com/QubesOS/qubes-secpack.git Cloning into 'qubes-secpack'... remote: Enumerating objects: 4065, done. remote: Counting objects: 100% (1474/1474), done. remote: Compressing objects: 100% (742/742), done. remote: Total 4065 (delta 743), reused 1413 (delta 731), pack-reused 2591 Receiving objects: 100% (4065/4065), 1.64 MiB | 2.53 MiB/s, done. Resolving deltas: 100% (1910/1910), done. -
Import the included PGP keys. (See our PGP key policies for important information about these keys.)
$ gpg --import qubes-secpack/keys/*/* gpg: key 063938BA42CFA724: public key "Marek Marczykowski-Górecki (Qubes OS signing key)" imported gpg: qubes-secpack/keys/core-devs/retired: read error: Is a directory gpg: no valid OpenPGP data found. gpg: key 8C05216CE09C093C: 1 signature not checked due to a missing key gpg: key 8C05216CE09C093C: public key "HW42 (Qubes Signing Key)" imported gpg: key DA0434BC706E1FCF: public key "Simon Gaiser (Qubes OS signing key)" imported gpg: key 8CE137352A019A17: 2 signatures not checked due to missing keys gpg: key 8CE137352A019A17: public key "Andrew David Wong (Qubes Documentation Signing Key)" imported gpg: key AAA743B42FBC07A9: public key "Brennan Novak (Qubes Website & Documentation Signing)" imported gpg: key B6A0BB95CA74A5C3: public key "Joanna Rutkowska (Qubes Documentation Signing Key)" imported gpg: key F32894BE9684938A: public key "Marek Marczykowski-Górecki (Qubes Documentation Signing Key)" imported gpg: key 6E7A27B909DAFB92: public key "Hakisho Nukama (Qubes Documentation Signing Key)" imported gpg: key 485C7504F27D0A72: 1 signature not checked due to a missing key gpg: key 485C7504F27D0A72: public key "Sven Semmler (Qubes Documentation Signing Key)" imported gpg: key BB52274595B71262: public key "unman (Qubes Documentation Signing Key)" imported gpg: key DC2F3678D272F2A8: 1 signature not checked due to a missing key gpg: key DC2F3678D272F2A8: public key "Wojtek Porczyk (Qubes OS documentation signing key)" imported gpg: key FD64F4F9E9720C4D: 1 signature not checked due to a missing key gpg: key FD64F4F9E9720C4D: public key "Zrubi (Qubes Documentation Signing Key)" imported gpg: key DDFA1A3E36879494: "Qubes Master Signing Key" not changed gpg: key 1848792F9E2795E9: public key "Qubes OS Release 4 Signing Key" imported gpg: qubes-secpack/keys/release-keys/retired: read error: Is a directory gpg: no valid OpenPGP data found. gpg: key D655A4F21830E06A: public key "Marek Marczykowski-Górecki (Qubes security pack)" imported gpg: key ACC2602F3F48CB21: public key "Qubes OS Security Team" imported gpg: qubes-secpack/keys/security-team/retired: read error: Is a directory gpg: no valid OpenPGP data found. gpg: key 4AC18DE1112E1490: public key "Simon Gaiser (Qubes Security Pack signing key)" imported gpg: Total number processed: 17 gpg: imported: 16 gpg: unchanged: 1 gpg: marginals needed: 3 completes needed: 1 trust model: pgp gpg: depth: 0 valid: 1 signed: 6 trust: 0-, 0q, 0n, 0m, 0f, 1u gpg: depth: 1 valid: 6 signed: 0 trust: 6-, 0q, 0n, 0m, 0f, 0u -
Verify signed Git tags.
$ cd qubes-secpack/ $ git tag -v `git describe` object 266e14a6fae57c9a91362c9ac784d3a891f4d351 type commit tag marmarek_sec_266e14a6 tagger Marek Marczykowski-Górecki 1677757924 +0100 Tag for commit 266e14a6fae57c9a91362c9ac784d3a891f4d351 gpg: Signature made Thu 02 Mar 2023 03:52:04 AM PST gpg: using RSA key 2D1771FE4D767EDC76B089FAD655A4F21830E06A gpg: Good signature from "Marek Marczykowski-Górecki (Qubes security pack)" [full]The exact output will differ, but the final line should always start with
gpg: Good signature from...followed by an appropriate key. The[full]indicates full trust, which this key inherits in virtue of being validly signed by the QMSK. -
Verify PGP signatures, e.g.:
$ cd QSBs/ $ gpg --verify qsb-087-2022.txt.sig.marmarek qsb-087-2022.txt gpg: Signature made Wed 23 Nov 2022 04:05:51 AM PST gpg: using RSA key 2D1771FE4D767EDC76B089FAD655A4F21830E06A gpg: Good signature from "Marek Marczykowski-Górecki (Qubes security pack)" [full] $ gpg --verify qsb-087-2022.txt.sig.simon qsb-087-2022.txt gpg: Signature made Wed 23 Nov 2022 03:50:42 AM PST gpg: using RSA key EA18E7F040C41DDAEFE9AA0F4AC18DE1112E1490 gpg: Good signature from "Simon Gaiser (Qubes Security Pack signing key)" [full] $ cd ../canaries/ $ gpg --verify canary-034-2023.txt.sig.marmarek canary-034-2023.txt gpg: Signature made Thu 02 Mar 2023 03:51:48 AM PST gpg: using RSA key 2D1771FE4D767EDC76B089FAD655A4F21830E06A gpg: Good signature from "Marek Marczykowski-Górecki (Qubes security pack)" [full] $ gpg --verify canary-034-2023.txt.sig.simon canary-034-2023.txt gpg: Signature made Thu 02 Mar 2023 01:47:52 AM PST gpg: using RSA key EA18E7F040C41DDAEFE9AA0F4AC18DE1112E1490 gpg: Good signature from "Simon Gaiser (Qubes Security Pack signing key)" [full]Again, the exact output will differ, but the final line of output from each
gpg --verifycommand should always start withgpg: Good signature from...followed by an appropriate key.
For this announcement (QSB-093), the commands are:
$ gpg --verify qsb-093-2023.txt.sig.marmarek qsb-093-2023.txt
$ gpg --verify qsb-093-2023.txt.sig.simon qsb-093-2023.txt
You can also verify the signatures directly from this announcement in addition to or instead of verifying the files from the qubes-secpack. Simply copy and paste the QSB-093 text into a plain text file and do the same for both signature files. Then, perform the same authentication steps as listed above, substituting the filenames above with the names of the files you just created.
This is a companion discussion topic for the original entry at https://www.qubes-os.org/news/2023/08/09/qsb-093/
