We have just published Qubes Security Bulletin (QSB) 085: Xenstore: Guests can crash xenstored (XSA-414). The text of this QSB is reproduced below. This QSB and its accompanying signatures will always be available in the Qubes Security Pack (qubes-secpack). More information about QSBs, including a complete historical list, is available here.
             ---===[ Qubes Security Bulletin 085 ]===---
                             2022-11-01
User action required
Users must install the following specific packages in order to address
the issues discussed in this bulletin:
  For Qubes 4.1, in dom0:
  - Xen packages, version 4.14.5-12
by the community. [1] Once available, the packages are to be installed
via the Qubes Update tool or its command-line equivalents. [2]
effect.
passphrase to new PCR values, as PCR18+19 will change due to the new
Xen binaries.
Summary
On 2022-11-01, the Xen Project published XSA-414, "Xenstore: Guests
can crash xenstored" [3]:
| Due to a bug in the fix of XSA-115 a malicious guest can cause
| xenstored to use a wrong pointer during node creation in an error
| path, resulting in a crash of xenstored or a memory corruption in
| xenstored causing further damage.
| Entering the error path can be controlled by the guest e.g. by
| exceeding the quota value of maximum nodes per domain.
Impact
The Xen Project's impact description also applies to Qubes OS:
| A malicious guest can cause xenstored to crash, resulting in the
| inability to create new guests or to change the configuration of
| running guests.
| Memory corruption in xenstored or privilege escalation of a guest
| can't be ruled out.
(Note: In Qubes terminology, a Xen guest is referred to as a "qube.")
Credits
See the original Xen Security Advisory.
References
[1] https://www.qubes-os.org/doc/testing/
[2] https://www.qubes-os.org/doc/how-to-update/
[3] https://xenbits.xen.org/xsa/advisory-414.html
The Qubes Security Team
This is a companion discussion topic for the original entry at https://www.qubes-os.org/news/2022/11/01/qsb-085/
