We have just published Qubes Security Bulletin (QSB) 075: Insufficient cleanup of passed-through device IRQs (XSA-395). The text of this QSB is reproduced below. This QSB and its accompanying signatures will always be available in the Qubes Security Pack (qubes-secpack).
View QSB-075 in the qubes-secpack:
https://github.com/QubesOS/qubes-secpack/blob/master/QSBs/qsb-075-2022.txt
In addition, you may wish to:
- Get the qubes-secpack: https://www.qubes-os.org/security/pack/
- View all past QSBs: https://www.qubes-os.org/security/qsb/
- View the XSA Tracker: https://www.qubes-os.org/security/xsa/
---===[ Qubes Security Bulletin 075 ]===---
2022-01-25
User action required
Users must install the following specific packages in order to address
the issues discussed in this bulletin:
For Qubes 4.0, in dom0:
- Xen packages, version 4.8.5-37
For Qubes 4.1, in dom0:
- Xen packages, version 4.14.3-8
by the community. [1] Once available, the packages are to be installed
via the Qubes Update tool or its command-line equivalents. [2]
effect.
passphrase to new PCR values, as PCR18+19 will change due to the new Xen
binaries.
Summary
On 2022-01-25, the Xen project published XSA-395, "Insufficient cleanup
of passed-through device IRQs" [3]:
| The management of IRQs associated with physical devices exposed to x86
| HVM guests involves an iterative operation in particular when cleaning
| up after the guest's use of the device. In the case where an
| interrupt is not quiescent yet at the time this cleanup gets invoked,
| the cleanup attempt may be scheduled to be retried. When multiple
| interrupts are involved, this scheduling of a retry may get
| erroneously skipped. At the same time pointers may get cleared
| (resulting in a de-reference of NULL) and freed (resulting in a
| use-after-free), while other code would continue to assume them to be
| valid.
Impact
The precise impact is system-specific but would typically be a denial of
service (DoS) affecting the entire host. Privilege escalation and
information leaks cannot be ruled out.
Only x86 HVM guests with one or more passed-through physical devices
using multiple physical interrupts together can exploit this
vulnerability. In Qubes, this generally applies to sys-usb and sys-net,
but whether the relevant devices use multiple interrupts together is
system-specific.
Credits
See the original Xen Security Advisory.
References
[1] https://www.qubes-os.org/doc/testing/
[2] https://www.qubes-os.org/doc/how-to-update/
[3] https://xenbits.xen.org/xsa/advisory-395.html
The Qubes Security Team
This is a companion discussion topic for the original entry at https://www.qubes-os.org/news/2022/01/25/qsb-075/
