We have just published Qubes Security Bulletin (QSB) 064: Linux: error handling issues in blkback’s grant mapping (XSA-365). The text of this QSB is reproduced below. This QSB and its accompanying signatures will always be available in the Qubes Security Pack (qubes-secpack).
View QSB-064 in the qubes-secpack:
https://github.com/QubesOS/qubes-secpack/blob/master/QSBs/qsb-064-2021.txt
Learn about the qubes-secpack, including how to obtain, verify, and read it:
https://www.qubes-os.org/security/pack/
View all past QSBs:
https://www.qubes-os.org/security/bulletins/
View XSA-365 in the XSA Tracker:
https://www.qubes-os.org/security/xsa/#365
---===[ Qubes Security Bulletin 064 ]===---
2021-02-16
Linux: error handling issues in blkback's grant mapping (XSA-365)
User action required
Users must install the following specific packages in order to address
the issues discussed in this bulletin:
For Qubes 4.0:
- Linux kernel packages, versions 5.10.16-1, 5.4.98-1, 4.19.176-1
For Qubes 4.1:
The packages are to be installed in dom0 via the Qube Manager or via
the qubes-dom0-update command as follows:
For updates from the stable repository (not immediately available):
$ sudo qubes-dom0-update
For updates from the security-testing repository:
$ sudo qubes-dom0-update --enablerepo=qubes-dom0-security-testing
A system restart will be required afterwards.
by the community.
passphrase to new PCR values, as PCR18+19 will change due to the new
Linux kernel binaries.
Summary
On 2021-02-16, the Xen Security Team published the following Xen
Security Advisory (XSA):
XSA-365 [1] "Linux: error handling issues in blkback's grant mapping"
| To service requests, the driver maps grant references provided by the
| frontend. In this process, errors may be encountered. In one case an
| error encountered earlier might be discarded by later processing,
| resulting in the caller assuming successful mapping, and hence
| subsequent operations trying to access space that wasn't mapped. In
| another case internal state would be insufficiently updated, preventing
| safe recovery from the error.
Impact
XSA-365, as described by Xen Security Team:
| A malicious or buggy frontend driver may be able to crash the
| corresponding backend driver, potentially affecting the entire domain
| running the backend driver. In configurations without driver domains
| or similar disaggregation, that is a host-wide denial of sevice.
| Privilege escalation and information leaks cannot be ruled out.
Credits
See the original Xen Security Advisories.
References
[1] https://xenbits.xen.org/xsa/advisory-365.html
The Qubes Security Team
This is a companion discussion topic for the original entry at https://www.qubes-os.org/news/2021/02/17/qsb-064/
