We have just published Qubes Security Bulletin (QSB) #062: Stack corruption from XSA-346 change (XSA-355). The text of this QSB is reproduced below. This QSB and its accompanying signatures will always be available in the Qubes Security Pack (qubes-secpack).
View QSB #062 in the qubes-secpack:
https://github.com/QubesOS/qubes-secpack/blob/master/QSBs/qsb-062-2020.txt
Learn about the qubes-secpack, including how to obtain, verify, and read it:
https://www.qubes-os.org/security/pack/
View all past QSBs:
https://www.qubes-os.org/security/bulletins/
View XSA-355 in the XSA Tracker:
https://www.qubes-os.org/security/xsa/#355
---===[ Qubes Security Bulletin #62 ]===---
2020-11-24
Summary
On 2020-11-24, the Xen Security Team published Xen Security Advisory
355 (XSA-355) [1] with the following description:
| One of the two changes for XSA-346 introduced an on-stack array. The
| check for guarding against overrunning this array was off by one,
| allowing for corruption of the first stack slot immediately following
| this array.
| A malicious or buggy HVM or PVH guest can cause Xen to crash, resulting
| in a Denial of Service (DoS) to the entire host. Privilege escalation
| as well as information leaks cannot be excluded.
Patching
The specific packages that resolve the problems discussed in this
bulletin are as follows:
For Qubes 4.0:
- Xen packages, version 4.8.5-27
For Qubes 4.1:
- Xen packages, version 4.14.0-8
The packages are to be installed in dom0 via the Qube Manager or via
the qubes-dom0-update command as follows:
For updates from the stable repository (not immediately available):
$ sudo qubes-dom0-update
For updates from the security-testing repository:
$ sudo qubes-dom0-update --enablerepo=qubes-dom0-security-testing
A system restart will be required afterwards.
by the community.
passphrase to new PCR values, as PCR18+19 will change due to the new
Xen binaries.
Credits
See the original Xen Security Advisory.
References
[1] https://xenbits.xen.org/xsa/advisory-355.html
The Qubes Security Team
This is a companion discussion topic for the original entry at https://www.qubes-os.org/news/2020/11/24/qsb-062/
