hello
i am trying to call remote pkcs11 service via qrexec. i believe it worked with a different smart card before, but i changed it and it works no more (trying with yubikey now)
i call qrexec-client-vm to liteqube.pkcs11 from p11-kit-client.so module, and on the smartcard side i run “p11-kit remote /usr/lib64/opensc-pkcs11.so”.
If I do it on the same vm (no qrexec, just running the same command line from the module definition), everything works, but if i try to wrap it to qrexec socket, i get random failures in the middle on operation – some operations succeed, some fail.
I suspected premature socket close and added sleep 1 at the end of the service, but it changed nothing.
Both are unlikely to be relevant. But socket sharing works, unlike this (as i did it in first version of split-pkcs11), but i do not want to go back to socket sharing, i want to find the root cause and fix it properly (I found that sockets tend to stuck sometimes in open state, and remote module provides atomic state for transactions)
